Changing the default UART pins
Palonso
Postby Palonso » Thu May 28, 2020 5:32 pm
I've seen in many places that you can change the UART pins to any other available pin with practically no restriction (apart from being output capability for TX), but I would like to know if there is any issue with the performance of it.
For example, I'm working with WROVER-B, is the same if I set the UART0 for GPIO1 and GPIO3 as for the GPIO27 and GPIO14?
Best regards,
P
WiFive
Re: Changing the default UART pins
Postby WiFive » Fri May 29, 2020 1:23 am
You get an extra clock cycle of delay from the pins but uart is asynchronous anyway
Users browsing this forum: Bytespider and 2 guests
