I started with the i2s_adc_dac example then added the wifi station example. However, when I hit esp_wifi_start() my ADC reading goes to 0.
Documentation clearly states ADC2 can not be used with Wifi but I'm using ADC1.
Any idea's on what is going on?
Can Not Use I2S ADC with Wifi
Re: Can Not Use I2S ADC with Wifi
I get data for the first couple executions of i2s_read then it outputs a single value, see below. The value it settles on is different each time I reset the esp32. Again, this only happens when running wifi at the same time.
I tried changing wifi settings in menuconfig like optimizations, cores, flash, but saw no change.
Is there something I can try in menuconfig or is this a more fundamental problem?
0f 37 0f 37 f9 36 f9 36
ff 36 ff 36 ff 36 ff 36
13 37 13 37 d9 36 d9 36
f7 36 f7 36 d9 36 d9 36
3e 37 3e 37 d5 36 d5 36
1a 37 1a 37 3f 37 3f 37
e3 36 e3 36 e7 36 e7 36
c7 36 c7 36 ff 36 ff 36
I (2405) wifi:state: init -> auth (b0)
I (2415) wifi:state: auth -> assoc (0)
I (2425) wifi:state: assoc -> run (10)
I (2445) wifi:connected with Echo_42, aid = 2, channel 6, BW20, bssid = 80:2a:a8:41:64:cd
I (2445) wifi:security type: 4, phy: bgn, rssi: -45
I (2445) wifi:pm start, type: 1
I (2505) wifi:AP's beacon interval = 102400 us, DTIM period = 1
I (3105) esp_netif_handlers: sta ip: 192.168.1.66, mask: 255.255.255.0, gw: 192.168.1.1
I (3105) wifi station: got ip:192.168.1.66
I (3105) wifi station: connected to ap SSID:Echo_42 password:qscwdvpk
EC Reading: 4345 Value: 979
Free memory: 157392 bytes
1d 38 1d 38 c5 38 c5 38
7f 38 7f 38 f0 38 f0 38
e0 38 e0 38 7f 38 7f 38
53 38 53 38 a7 37 a7 37
60 37 60 37 a7 36 a7 36
00 36 00 36 8e 35 8e 35
ff 34 ff 34 ff 34 ff 34
c7 34 c7 34 d8 34 d8 34
EC Reading: 5105 Value: 587
Free memory: 157388 bytes
7e 37 7e 37 7e 37 7e 37
EC Reading: 5561 Value: 352
EC Reading: 5834 Value: 211
EC Reading: 5999 Value: 126
Also tried wrapping i2s_read() in i2s_adc_enable and i2s_adc_disable but that did not work.
Here is the entire striped down example file I am using. You can see where I launch the wifi station at the bottom of app_main
#include <stdio.h>
#include <string.h>
#include "freertos/task.h"
#include "esp_spi_flash.h"
#include "esp_err.h"
#include "esp_log.h"
#include "esp_partition.h"
#include "driver/i2s.h"
#include "driver/adc.h"
#include "audio_example_file.h"
#include "esp_adc_cal.h"
static const char* TAG = "ad/da";
#include "station/station_example_main.c"
#define V_REF 1100
#define ADC1_TEST_CHANNEL (ADC1_CHANNEL_7)
#define EXAMPLE_I2S_NUM (0)
#define EXAMPLE_I2S_SAMPLE_RATE (16000)
#define EXAMPLE_I2S_SAMPLE_BITS (16)
#define EXAMPLE_I2S_BUF_DEBUG (1)
#define EXAMPLE_I2S_READ_LEN (16 * 1024)
#define EXAMPLE_I2S_FORMAT (I2S_CHANNEL_FMT_RIGHT_LEFT)
#define EXAMPLE_I2S_CHANNEL_NUM ((EXAMPLE_I2S_FORMAT < I2S_CHANNEL_FMT_ONLY_RIGHT) ? (2) : (1))
#define I2S_ADC_UNIT ADC_UNIT_1
#define I2S_ADC_CHANNEL ADC1_CHANNEL_7
void example_i2s_init(void)
int i2s_num = EXAMPLE_I2S_NUM;
i2s_config_t i2s_config = {
.mode = I2S_MODE_MASTER | I2S_MODE_RX | I2S_MODE_TX | I2S_MODE_DAC_BUILT_IN | I2S_MODE_ADC_BUILT_IN,
.sample_rate = EXAMPLE_I2S_SAMPLE_RATE,
.bits_per_sample = EXAMPLE_I2S_SAMPLE_BITS,
.communication_format = I2S_COMM_FORMAT_PCM,
.channel_format = EXAMPLE_I2S_FORMAT,
.intr_alloc_flags = 0,
.dma_buf_count = 2,
.dma_buf_len = 1024,
.use_apll = 1,
//install and start i2s driver
i2s_driver_install(i2s_num, &i2s_config, 0, NULL);
i2s_set_dac_mode(I2S_DAC_CHANNEL_BOTH_EN);
i2s_set_adc_mode(I2S_ADC_UNIT, I2S_ADC_CHANNEL);
void example_disp_buf(uint8_t* buf, int length)
#if EXAMPLE_I2S_BUF_DEBUG
printf("======\n");
for (int i = 0; i < length; i++) {
printf("%02x ", buf[i]);
if ((i + 1) % 8 == 0) {
printf("\n");
printf("======\n");
#endif
int example_i2s_dac_data_scale(uint8_t* d_buff, uint8_t* s_buff, uint32_t len)
uint32_t j = 0;
#if (EXAMPLE_I2S_SAMPLE_BITS == 16)
for (int i = 0; i < len; i++) {
d_buff[j++] = 0;
d_buff[j++] = s_buff[i];
return (len * 2);
#else
d_buff[j++] = 0;
d_buff[j++] = 0;
d_buff[j++] = 0;
return (len * 4);
#endif
void example_i2s_adc_dac(void*arg)
int i2s_read_len = EXAMPLE_I2S_READ_LEN;
int flash_wr_size = 0;
size_t bytes_read, bytes_written;
uint8_t* flash_read_buff = (uint8_t*) calloc(i2s_read_len, sizeof(char));
uint8_t* i2s_write_buff = (uint8_t*) calloc(i2s_read_len, sizeof(char));
while (1) {
printf("Playing file example: \n");
int offset = 0;
int tot_size = sizeof(audio_table);
while (offset < tot_size) {
int play_len = ((tot_size - offset) > (4 * 1024)) ? (4 * 1024) : (tot_size - offset);
int i2s_wr_len = example_i2s_dac_data_scale(i2s_write_buff, (uint8_t*)(audio_table + offset), play_len);
i2s_write(EXAMPLE_I2S_NUM, i2s_write_buff, i2s_wr_len, &bytes_written, portMAX_DELAY);
offset += play_len;
void adc_read_task(void* arg)
size_t bytes_read;
char* i2s_read_buff = (char*) calloc(i2s_read_len, sizeof(char));
while(1) {
// i2s_adc_enable(EXAMPLE_I2S_NUM);
i2s_read(EXAMPLE_I2S_NUM, (void*) i2s_read_buff, i2s_read_len, &bytes_read, portMAX_DELAY);
example_disp_buf((uint8_t*) i2s_read_buff, 64);
// i2s_adc_disable(EXAMPLE_I2S_NUM);
esp_err_t app_main(void)
example_i2s_init();
esp_log_level_set("I2S", ESP_LOG_INFO);
xTaskCreate(example_i2s_adc_dac, "example_i2s_adc_dac", 1024 * 2, NULL, 5, NULL);
xTaskCreate(adc_read_task, "ADC read task", 2048, NULL, 5, NULL);
station_main();
return ESP_OK;
Users browsing this forum: Applebot, Qwantbot and 2 guests
