My goal is to make a component that read from some sensors. Due to the requirements of the project, the code must be in C++ cause I need to use some pattern design, but the project(Main and other components, should be write with C).
file1.c-----Calls static function---->file2..cpp-----Create an A class----->A
when I try to compile, it simply doesn't work. The .cpp(file2) is not C++ code. And when I try to include into file2 class A, it says that it doesn't find the file(I Tripled check that its ok). #ifdef __cplusplus macro is not defined.
Inside the .mk files I have defined the:
COMPONENT_ADD_LDFLAGS=-lstdc++ -l$(COMPONENT_NAME)
It can not even include <string>, it says that it doesn't find the file.
What am I missing?
Thanks for the support!
Including C++ code into C project
madscientist_42
Re: Including C++ code into C project
Just because it's not C++ code, if you're putting it in a .cpp file, you're subjected to the C++ rules for everything, including name mangling.Hi,
What am I missing?
Unless you tell it otherwise, the C++ compiler (which is what you're using with a .cpp per normal makefile or SCons rules (presuming you're using PlatformIO there...) is presuming it is ALL C++ (C code within C++ is simply viewed as classless C++ code with all the rules that apply, including Name Mangling) and name mangling your code so that the linker can't find the references the C compiler makes within your block of code.
Bracket the .h file's for file2.cpp's definitions with an 'extern "C" { }' block for all C functions you're defining and make sure that that .h file is the first thing you include in file2.cpp. At the minimum, this should work right. Failing that, bracket the C functions and variables you're referencing in the .cpp file with the same in the .cpp file. This will turn name mangling off for those functions and variables.
Thats not the problem I think. I've test the code in a simple C++ app and it works.
I think that there is smth about the environment cause __cplusplus is not defined.
SensorTask.c
SensorsController.h
SensorsController.cpp
SensorsController_Wrapper.h
SensorsController_Wrapper.cc
The problem is that there is no function called newSensorsController or deleteSensorsController. More precisely this is the error:
And that's should be smth about cplusplus or the includes(mk files or smth)
SensorTask.c
#include "../Task/SensorsTask.h"
#include "../Controller/SensorsController_Wrapper.h"
static xTaskHandle Sensors_Readings_task_hdl;
* This function is gonna be the one that handle all the request from other task asking for sensor readings
void sensorsReadingsTask(void *pvParameters)
while(1){
vTaskDelete(Sensors_Readings_task_hdl);
void sensors_Readings_Init() {
ESP_LOGI("Sensors", "Initializing Sensor_Readings Task");
struct SensorsController* c = newSensorsController();
deleteSensorsController(c);
/* Start BT configuration task*/
xTaskCreate(sensorsReadingsTask, "SensorReadings Task", 8192, NULL, 5,&Sensors_Readings_task_hdl);
SensorsController.h
#include "freertos/task.h"
#include "esp_log.h"
class SensorsController {
public:
virtual ~SensorsController();
SensorsController::SensorsController() {
ESP_LOGI("GasSensorsController", "*******************SIIIIIIIIIIIIIIIIIIIIII***************");
SensorsController::~SensorsController() {
// TODO Auto-generated destructor stub
#ifdef __cplusplus
extern "C" {
#endif
typedef struct SensorsController SensorsController;
SensorsController* newSensorsController();
void deleteSensorsController(SensorsController* v);
#ifdef __cplusplus
#endif
#include "SensorsController.h"
#include "SensorsController_Wrapper.h"
extern "C" {
SensorsController* newSensorsController() {
return new SensorsController();
void deleteSensorsController(SensorsController* v) {
delete v;
$ make -j8
CC src/Task/SensorsTask.o
AR libSensorsReadings.a
LD app-template.elf
.../build/SensorsReadings\libSensorsReadings.a(SensorsTask.o):(.literal.sensors_Readings_Init+0x18): undefined reference to `newSensorsController'
...SensorsReadings\libSensorsReadings.a(SensorsTask.o):(.literal.sensors_Readings_Init+0x1c): undefined reference to `deleteSensorsController'
.../SensorsReadings\libSensorsReadings.a(SensorsTask.o): In function `sensors_Readings_Init':
.../SensorsReadings/src/Task/SensorsTask.c:41: undefined reference to `newSensorsController'
.../components/SensorsReadings/src/Task/SensorsTask.c:42: undefined reference to `deleteSensorsController'
make: *** [.../project.mk:323: ..../build/app-template.elf] Error 1
I think the SensorsController_Wrapper.cc file doesn't get compiled at all. ESP-IDF build system assumes .c extension for C source files and .cpp for C++ source files. You can explicitly list the source files for the given component if you'd like, please see the build system documentation for that.
Yes, it was the .cc extension.
Thanks for evrthng. This was really frustrating. I'm sort of newby chip programmer, I'm used to plain C++ development.
Cheers!
Cheers!
Users browsing this forum: Applebot, Bytespider and 1 guest
