Having trouble getting i2c slave to ACK
Cantonius99
Postby Cantonius99 » Fri Jun 05, 2020 1:53 am
Been having issues trying to get the SHT31 Slave to ACK after initiating a Read. I am able to Initialize, Soft Reset, and Start a Measurement, but once I try to Read the Measurement I get a NACK from the Slave.
ESP-IDF returns a ESP_ERR_TIMEOUT or ESP_FAIL.
Here's sample code of the Soft-Reset, Init, Status Register, Heater, Start Measurement (Single Shot) and Reading after the Measurement.
It's worth noting that I'm able to get everything working using Arduino Code (using Adafruits SHT Library). But am migrating everything to ESP-IDF and am running into this issue :(.
esp_err_t reset() {
i2c_cmd_handle_t cmd = i2c_cmd_link_create();
i2c_master_start(cmd);
i2c_master_write_byte(cmd, (SHT31_ADDRESS << 1) | I2C_MASTER_WRITE, SHT31_ACK_CHECK_EN);
i2c_master_write_byte(cmd, 0x30, SHT31_ACK_CHECK_EN);
i2c_master_write_byte(cmd, 0xA2, SHT31_ACK_CHECK_EN);
i2c_master_stop(cmd);
esp_err_t ret = i2c_master_cmd_begin(SHT31_NUM, cmd, 1000 / portTICK_RATE_MS);
i2c_cmd_link_delete(cmd);
ESP_LOGI(tag, "SHT31 Soft-Reset");
if (ret == ESP_OK) {
ESP_LOGI(tag, "Success");
} else if (ret == ESP_ERR_INVALID_ARG) {
ESP_LOGI(tag, "Parameter error");
} else if (ret == ESP_FAIL) {
ESP_LOGI(tag, "Sending command error, slave doesn’t ACK the transfer.");
} else if (ret == ESP_ERR_INVALID_STATE) {
ESP_LOGI(tag, "I2C driver not installed or not in master mode.");
} else if (ret == ESP_ERR_TIMEOUT) {
ESP_LOGI(tag, "Operation timeout because the bus is busy.");
return ESP_OK;
void init() {
i2c_config_t conf;
conf.mode = I2C_MODE_MASTER;
conf.sda_io_num = SHT31_SDA_IO;
conf.scl_io_num = SHT31_SCL_IO;
conf.sda_pullup_en = GPIO_PULLUP_ENABLE;
conf.scl_pullup_en = GPIO_PULLUP_ENABLE;
conf.master.clk_speed = SHT31_FREQ_HZ;
ESP_ERROR_CHECK(i2c_param_config(SHT31_NUM, &conf));
ESP_ERROR_CHECK(i2c_set_timeout(SHT31_NUM, 100000));
ESP_ERROR_CHECK(i2c_driver_install(SHT31_NUM, conf.mode, SHT31_RX_BUF_DISABLE, SHT31_TX_BUF_DISABLE, 0));
vTaskDelay(200 / portTICK_PERIOD_MS);
reset();
vTaskDelay(10 / portTICK_PERIOD_MS);
void status_register_read() {
uint8_t readBuffer;
i2c_master_write_byte(cmd, (SHT31_ADDRESS << 1) | I2C_MASTER_READ, SHT31_ACK_CHECK_EN);
i2c_master_read_byte(cmd, &readBuffer, SHT31_ACK_VAL);
i2c_master_read_byte(cmd, &readBuffer + 1, SHT31_ACK_VAL);
i2c_master_read_byte(cmd, &readBuffer + 2, SHT31_NACK_VAL);
ESP_LOGI(tag, "Status Register Read");
void status_register() {
i2c_master_write_byte(cmd, 0xF3, SHT31_ACK_CHECK_EN);
i2c_master_write_byte(cmd, 0x2D, SHT31_ACK_CHECK_EN);
ESP_LOGI(tag, "Status Register Write");
status_register_read();
void heater_on() {
i2c_master_write_byte(cmd, 0x6D, SHT31_ACK_CHECK_EN);
ESP_LOGI(tag, "Heater On");
void single_shot() {
i2c_master_write_byte(cmd, 0x24, SHT31_ACK_CHECK_EN);
i2c_master_write_byte(cmd, 0x00, SHT31_ACK_CHECK_EN);
ESP_LOGI(tag, "Single Shot");
void read_temperature_humidity() {
uint8_t readBuffer;
i2c_master_read_byte(cmd, &readBuffer + 2, SHT31_ACK_VAL);
i2c_master_read_byte(cmd, &readBuffer + 3, SHT31_ACK_VAL);
i2c_master_read_byte(cmd, &readBuffer + 4, SHT31_ACK_VAL);
i2c_master_read_byte(cmd, &readBuffer + 5, SHT31_NACK_VAL);
ESP_LOGI(tag, "Read Measurement");
Code: Untitled.c Select all
All the Setup Stuff
https://preview.redd.it/yl5o974uhy251.p ... 3122f70dfa
When trying to Read
Also here is a link to the datasheet (Goto Section 4): https://www.sensirion.com/fileadmin/use ... igital.pdf
Users browsing this forum: ChatGPT-User, Google [Bot] and 1 guest
