Hello -
This is a follow-up on this topic that covers persistent storage of the keys required to maintain device bonds across ESP32 reboots:
viewtopic.php?t=13049
Simple question: Where is the code that reads and writes the persistent data? Looking at the ble_hs_cfg store callbacks and reading through the ESP-IDF NimBLE port, I wasn't able to find the code. Presumably there are functions that read/write NVS to store the keys and associated data. The sample apps only set the store_status_cb to ble_store_util_status_rr, which I believe is called when there is insufficient storage.
Thanks,
Brian
NimBLE - where is code that manages persistent bonding
Re: NimBLE - where is code that manages persistent bonding
Hi Brian, you can find this code section in: components/bt/host/nimble/nimble/nimble/host/store.
In this directory, there are different implementations of storing configuration, including the NVS way that the ESP32 implements, you can find specifically this implementation in: store/config/src/ble_store_nvs.c, the configuration of the read and write memory callbacks are implemented locally in this file.
Please let me know if this information was useful to you
Felipe
Felipe
Felipe -
Thank you for the helpful answer. That is what I was looking for.
Regards,
Brian
Regards,
Brian
Users browsing this forum: Amazon [Bot], Baidu [Spider], ChatGPT-User, PetalBot, Qwantbot and 2 guests
