UART is not workinf
joicetm
UART is not workinf
Postby joicetm » Wed Apr 12, 2017 11:45 am
uart is not working
i am trying to set up uart on my project. but, even the example code is not working.
any help is much appreciated.
my code:
/* Uart Events Example
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
#include "freertos/task.h"
#include "esp_system.h"
#include "nvs_flash.h"
#include "driver/uart.h"
#include "freertos/queue.h"
#include "esp_log.h"
#include "soc/uart_struct.h"
* This is a example exaple which echos any data it receives on UART1 back to the sender, with hardware flow control
* turned on. It does not use UART driver event queue.
* - port: UART1
* - rx buffer: on
* - tx buffer: off
* - flow control: on
* - event queue: off
* - pin assignment: txd(io4), rxd(io5), rts(18), cts(19)
#define ECHO_TEST_TXD (1)
#define ECHO_TEST_RXD (3)
#define ECHO_TEST_RTS (6)
#define ECHO_TEST_CTS (11)
#define BUF_SIZE (1024)
//an example of echo test with hardware flow control on UART1
//static void echo_task()
void app_main()
//A uart read/write example without event queue;
//xTaskCreate(echo_task, "uart_echo_task", 1024, NULL, 10, NULL);
const int uart_num = UART_NUM_0;
uart_config_t uart_config = {
.baud_rate = 115200,
.flow_ctrl = UART_HW_FLOWCTRL_CTS_RTS,
.rx_flow_ctrl_thresh = 120,
//Configure UART1 parameters
uart_param_config(uart_num, &uart_config);
// Set UART1 pins(TX: IO4, RX: I05, RTS: UART_PIN_NO_CHANGE, CTS: UART_PIN_NO_CHANGE)
uart_set_pin(uart_num, ECHO_TEST_TXD, ECHO_TEST_RXD, UART_PIN_NO_CHANGE, UART_PIN_NO_CHANGE);
//Install UART driver (we don't need an event queue here)
//In this example we don't even use a buffer for sending data.
//uart_driver_install(uart_num, 2048, 0, 0, NULL, 0);
uart_driver_install(uart_num, BUF_SIZE * 2, 0, 0, NULL, 0);
uint8_t* data = (uint8_t*) malloc(BUF_SIZE);
uint8_t dat[]={4,5,6,7};
int len=4;
data=dat;
while(1) {
//Read data from UART
//int len = uart_read_bytes(uart_num, data, BUF_SIZE, 20 / portTICK_RATE_MS);
//Write data back to UART
// uart_write_bytes(uart_num,&dat, len);
kolban
Re: UART is not workinf
Postby kolban » Sat Apr 15, 2017 8:48 pm
What is the symptom of it "not working"?
joicetm
Re: UART is not working
Postby joicetm » Mon May 08, 2017 2:25 pm
Thank you so much MR.Kolban,
My esp-idf was not updated,the problem solved when i have updated it.
I found your book very helpful. i appreciate the effort you took to develop such a book on esp32.
madscientist_42
Postby madscientist_42 » Mon May 08, 2017 7:15 pm
He is quite helpful. I can only hope, as one of the embedded pros in the forums, I can eventually be as helpful as he's been up to this point on all fronts. :D
Users browsing this forum: Applebot, Baidu [Spider], Bing [Bot], Google [Bot] and 2 guests
