sending jpg through websocket from esp32 websocket client
jensdk32
Postby jensdk32 » Sun Jul 26, 2020 6:19 am
I playing with a ESP32-CAM.
I'm using the standard Windows installer for esp tools and esp-idf. So I'm using v4.0.1 from May 2020.
I have a image encoded as jpg in a struct as this
typedef struct {
    uint8_t * buf;              /*!< Pointer to the pixel data */
    size_t len;                 /*!< Length of the buffer in bytes */
    size_t width;               /*!< Width of the buffer in pixels */
    size_t height;              /*!< Height of the buffer in pixels */
    pixformat_t format;         /*!< Format of the pixel data */
    struct timeval timestamp;   /*!< Timestamp since boot of the first DMA buffer of the frame */
} camera_fb_t;
I want to send this image data across a websocket connection. Image size can be up to 300kB. The send function for binary data has the following syntax
esp_websocket_client_send(client,(char *)fb->buf, fb->len, portMAX_DELAY);
On the server side I get no errors and can see some sort of data being received. But the ESP log tells me the websocket client is not behaving as expected::
E (26194) TRANSPORT_WS: Error transport_poll_write
E (26194) WEBSOCKET_CLIENT: Network error: esp_transport_write() returned 0, errno=0
I tried to replace portMAX_DELAY with 10000 as suggested here: https://github.com/espressif/esp-idf/issues/4316
But that did not remove the error message.
If I replace actual data length with 1000 I get no errors:
esp_websocket_client_send(client,(char *)fb->buf, 1000, portMAX_DELAY);
Any ideas what is going on? Am I supposed to split up the data in smaller chunks? I am currently assuming that any such fragmentation, if needed, is taken care of implicitly by the websocket API.
Erik Lee
Re: sending jpg through websocket from esp32 websocket client
Postby Erik Lee » Wed Jun 11, 2025 7:33 am
In the case of version 5.3, I changed the delay from 1s to 10s, this situation has been solved a lot, may it be a timeout problem?
Users browsing this forum: Bing [Bot], meta-externalagent and 3 guests
