I'm trying to add callback to the OTA function in the switch example:
Code: Untitled.txt Select all
/* Enable OTA */
esp_rmaker_ota_config_t ota_config = {
.ota_cb = &ota_cb_func,
.server_cert = ESP_RMAKER_OTA_DEFAULT_SERVER_CERT,
And my callback function:
esp_err_t ota_cb_func(esp_rmaker_ota_handle_t handle, esp_rmaker_ota_data_t *ota_data)
ota_status_t status = OTA_STATUS_IN_PROGRESS;
char info[1024]="test";
ESP_LOGW(TAG, "OTA URL: %s\r\n", ota_data->url);
ESP_LOGW(TAG, "OTA Filesize: %d\r\n", ota_data->filesize);
ESP_LOGW(TAG, "OTA Status: %d\r\n", status);
esp_err_t err = esp_rmaker_ota_report_status(handle, status, info); // reports to OTA server
return err;
Admittedly, there is very little information documented. I'm really just stabbing in the dark.
When I tried to update OTA, clearly it wouldn't work:
I (5314) app_wifi: Connected with IP Address:192.168.43.42
I (5314) esp_netif_handlers: sta ip: 192.168.43.42, mask: 255.255.255.0, gw: 192.168.43.70
I (5314) esp_rmaker_mqtt: Connecting to a1p72mufdu6064-ats.iot.us-east-1.amazonaws.com
I (5324) esp_rmaker_mqtt: Waiting for MQTT connection. This may take time.
I (10204) esp_rmaker_mqtt: MQTT Connected
I (10204) esp_rmaker_node_config: Reporting Node Configuration
I (10214) esp_rmaker_param: Reporting params: {"Switch":{"name":"Switch","power":true},"ota":{"status":"","info":"","url":""}}
I (75124) esp_rmaker_param: Received params: {"ota": {"url": "https://esp-rainmaker-ota-315787942180-prod.s3.amazonaws.com/users/c92eda40-6e1d-4762-8f70-a23bc0eb3d5c/firmwareimages/Oba-4qSGR/c%3A%5Cmsys32%5Chome%5Cy.tan%5Cesp%5Cesp-rainmaker%5Ccli%5C..%5Cexamples%5Cswitch%5Cswitch_ota.bin?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=ASIAUTBTNTESLTL6K3EK%2F20200816%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20200816T105153Z&X-Amz-Expires=86400&X-Amz-Security-Token=FwoGZXIvYXdzEAwaDHzxdypQ84o7NS1gfyK3Afi%2BWy8BFmPXnW%2BHwQyLffp2qHQITsMnT%2BVtWdzTXOr6UC8sh3k64Dcxc3dBBv3i%2Fq%2FNT7tr8QxjxLzh%2FFQzxnOh1AQij7XBH0Var7Qio9iPSnpofvBupA1TnNRoJ9LRrFUqhHHKIsc7G6Z8zvpSMPxFPNz0bOFiu6i8dbqi2Pxkx7ipqt1l7jrdWAGbxB0gUM%2BIa2%2F7Ac4xHt9wt4fvfFmlCCzFoDlSAVmOTs%2FOBCUH5B%2FQa92DWyjJn%2BT5BTIt7%2Fh%2BBsFyt4x%2FkHJJIwlmq21hSkjne7JS%2Fb5T09QiL7ZwI8x5HAGPkCKsUaMI&X-Amz-SignedHeaders=host&X-Amz-Signature=1d5e54dd6b9877cbf11dc75aa64a0c8b8705ba6bbbf8dab00f153522253a60d9"}}
I (75204) esp_rmaker_ota_using_params: Received value = https://esp-rainmaker-ota-315787942180-prod.s3.amazonaws.com/users/c92eda40-6e1d-4762-8f70-a23bc0eb3d5c/firmwareimages/Oba-4qSGR/c%3A%5Cmsys32%5Chome%5Cy.tan%5Cesp%5Cesp-rainmaker%5Ccli%5C..%5Cexamples%5Cswitch%5Cswitch_ota.bin?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=ASIAUTBTNTESLTL6K3EK%2F20200816%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20200816T105153Z&X-Amz-Expires=86400&X-Amz-Security-Token=FwoGZXIvYXdzEAwaDHzxdypQ84o7NS1gfyK3Afi%2BWy8BFmPXnW%2BHwQyLffp2qHQITsMnT%2BVtWdzTXOr6UC8sh3k64Dcxc3dBBv3i%2Fq%2FNT7tr8QxjxLzh%2FFQzxnOh1AQij7XBH0Var7Qio9iPSnpofvBupA1TnNRoJ9LRrFUqhHHKIsc7G6Z8zvpSMPxFPNz0bOFiu6i8dbqi2Pxkx7ipqt1l7jrdWAGbxB0gUM%2BIa2%2F7Ac4xHt9wt4fvfFmlCCzFoDlSAVmOTs%2FOBCUH5B%2FQa92DWyjJn%2BT5BTIt7%2Fh%2BBsFyt4x%2FkHJJIwlmq21hSkjne7JS%2Fb5T09QiL7ZwI8x5HAGPkCKsUaMI&X-Amz-SignedHeaders=host&X-Amz-Signature=1d5e54dd6b9877cbf11dc75aa64a0c8b8705ba6bbbf8dab00f153522253a60d9 for ota - url
W (76224) app_main: OTA URL: https://esp-rainmaker-ota-315787942180-prod.s3.amazonaws.com/users/c92eda40-6e1d-4762-8f70-a23bc0eb3d5c/firmwareimages/Oba-4qSGR/c%3A%5Cmsys32%5Chome%5Cy.tan%5Cesp%5Cesp-rainmaker%5Ccli%5C..%5Cexamples%5Cswitch%5Cswitch_ota.bin?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=ASIAUTBTNTESLTL6K3EK%2F20200816%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20200816T105153Z&X-Amz-Expires=86400&X-Amz-Security-Token=FwoGZXIvYXdzEAwaDHzxdypQ84o7NS1gfyK3Afi%2BWy8BFmPXnW%2BHwQyLffp2qHQITsMnT%2BVtWdzTXOr6UC8sh3k64Dcxc3dBBv3i%2Fq%2FNT7tr8QxjxLzh%2FFQzxnOh1AQij7XBH0Var7Qio9iPSnpofvBupA1TnNRoJ9LRrFUqhHHKIsc7G6Z8zvpSMPxFPNz0bOFiu6i8dbqi2Pxkx7ipqt1l7jrdWAGbxB0gUM%2BIa2%2F7Ac4xHt9wt4fvfFmlCCzFoDlSAVmOTs%2FOBCUH5B%2FQa92DWyjJn%2BT5BTIt7%2Fh%2BBsFyt4x%2FkHJJIwlmq21hSkjne7JS%2Fb5T09QiL7ZwI8x5HAGPkCKsUaMI&X-Amz-SignedHeaders=host&X-Amz-Signature=1d5e54dd6b9877cbf11dc75aa64a0c8b8705ba6bbbf8dab00f153522253a60d9
W (76294) app_main: OTA Filesize: 0
W (76294) app_main: OTA Status: 1
I (76304) esp_rmaker_param: Reporting params: {"ota":{"info":"test"}}
I (76314) esp_rmaker_param: Reporting params: {"ota":{"status":"in-progress"}}
