What is the difference between data partitions fctry and nvs ?
ytan86
Postby ytan86 » Sat Aug 22, 2020 8:32 am
Hi
This is the partition.csv from rainmaker examples/switch:
Code: partition.csv Select all
sec_cert,  0x3F, ,0xd000,    0x3000, ,  # Never mark this as an encrypted partition
nvs, data, nvs, 0x10000, 0x6000,
otadata, data, ota, , 0x2000
phy_init, data, phy, , 0x1000,
ota_0, app, ota_0, 0x20000, 1600K,
ota_1, app, ota_1, , 1600K,
fctry, data, nvs, 0x340000, 0x6000
What is fctry for? If is reserved for rainmaker only, or can I use fctry with esp_err_tnvs_flash_init_partition?
Piyush
Re: What is the difference between data partitions fctry and nvs ?
Postby Piyush » Sat Aug 22, 2020 9:49 am
The nvs partition has information like Wi-Fi credentials, custom device names, and any other information you store using nvs calls. The fctry is also an nvs partition, but it is used for information like node id, private key and certificate required for cloud communication. You may consider it as a read-only partition which isn't erased during a factory reset operation.
Regards,
Piyush
