recvfrom returns -1 with error-code 11
Wamor45
Postby Wamor45 » Wed Apr 19, 2017 8:58 pm
I have the below program.
Function recvfrom(...) in receive_UDP(...) returns -1 with error-code 11.
I believe this is caused by a time-out but I should receive the "Hello world!"-text instead ?
Is there someone who could help me finding what is wrong ?
Best regards,
Wamor
/* HTTP GET Example using plain POSIX sockets
#include <string.h>
#include "freertos/task.h"
#include "esp_system.h"
#include "esp_wifi.h"
#include "esp_event_loop.h"
#include "esp_log.h"
#include "lwip/ip4_addr.h"
#include "nvs_flash.h"
#include "lwip/err.h"
#include "lwip/sockets.h"
#include "lwip/sys.h"
#include "lwip/netdb.h"
#include "lwip/dns.h"
/* The examples use simple WiFi configuration that you can set via
   'make menuconfig'.
   If you'd rather not, just change the below entries to strings with
   the config you want - ie #define EXAMPLE_WIFI_SSID "mywifissid"
#define EXAMPLE_WIFI_SSID CONFIG_WIFI_SSID
#define EXAMPLE_WIFI_PASS CONFIG_WIFI_PASSWORD
/* FreeRTOS event group to signal when we are connected & ready to make a request */
static EventGroupHandle_t wifi_event_group;
/* The event group allows multiple bits for each event,
   but we only care about one event - are we connected
   to the AP with an IP? */
const int CONNECTED_BIT = BIT0;
#define PORT_NUMBER 34952
static const char *TAG = "ESP32";
static const char *TAG_RECEIVE = "ESP32 Receive";
static const char *TAG_SEND = "ESP32 Send";
int sock = 0;
struct sockaddr_in source, destination;
static void connect_UDP(void)
    tcpip_adapter_ip_info_t ip_info;
    struct timeval tv;
    tv.tv_sec = 3;  /* 3 Seconds Time-out */
    tv.tv_usec = 0;
	if ((sock = socket(AF_INET, SOCK_DGRAM, IPPROTO_UDP)) < 0)
        ESP_LOGE(TAG, "... Failed to allocate socket.");
    /*set the socket options*/
    setsockopt(sock, SOL_SOCKET, SO_RCVTIMEO, (char *) &tv, sizeof(struct timeval));
    /*Initialize source to zero*/
    memset(&source, 0, sizeof(source));       //source is an instance of sockaddr_in. Initialization to zero
    /*Initialize destination to zero*/
    memset(&destination, 0, sizeof(destination));
    ESP_ERROR_CHECK( tcpip_adapter_get_ip_info(TCPIP_ADAPTER_IF_STA, &ip_info) );
    ESP_LOGE(TAG, "Local IP-address=%s", inet_ntoa(ip_info.ip));
    //source.sin_len = sizeof(source);
	source.sin_family = AF_INET;
	source.sin_port = htons(7005);
	source.sin_addr.s_addr = INADDR_ANY; //ip_info.ip.addr;
	memset(source.sin_zero, '\0', sizeof source.sin_zero);
	if (bind(sock, (struct sockaddr *) &source, sizeof(source)) < 0)
        ESP_LOGE(TAG, "... Failed to bind socket.");
    ESP_LOGE(TAG, "Gateway IP-address=%s", inet_ntoa(ip_info.gw));
    //destination.sin_len = sizeof(destination);
	destination.sin_family = AF_INET;
	destination.sin_port = htons(7005);
	destination.sin_addr.s_addr = inet_addr("127.0.0.1"); //ip_info.gw.addr;
	memset(destination.sin_zero, '\0', sizeof destination.sin_zero);
static void disconnect_UDP(void)
    close(sock);
static esp_err_t event_handler(void *ctx, system_event_t *event)
    switch(event->event_id) {
    case SYSTEM_EVENT_WIFI_READY:		        /**< ESP32 WiFi ready */
		ESP_LOGI(TAG, "SYSTEM_EVENT_WIFI_READY");
    case SYSTEM_EVENT_SCAN_DONE:                /**< ESP32 finish scanning AP */
		ESP_LOGI(TAG, "SYSTEM_EVENT_SCAN_DONE");
    case SYSTEM_EVENT_STA_START:                /**< ESP32 station start */
		ESP_LOGI(TAG, "SYSTEM_EVENT_STA_START");
		ESP_ERROR_CHECK( esp_wifi_connect() );
    case SYSTEM_EVENT_STA_STOP:                 /**< ESP32 station stop */
		ESP_LOGI(TAG, "SYSTEM_EVENT_STA_STOP");
    case SYSTEM_EVENT_STA_CONNECTED:            /**< ESP32 station connected to AP */
		ESP_LOGI(TAG, "SYSTEM_EVENT_STA_CONNECTED");
    case SYSTEM_EVENT_STA_DISCONNECTED:         /**< ESP32 station disconnected from AP */
		ESP_LOGI(TAG, "SYSTEM_EVENT_STA_DISCONNECTED");
		/* This is a workaround as ESP32 WiFi libs don't currently
		   auto-reassociate. */
		xEventGroupClearBits(wifi_event_group, CONNECTED_BIT);
		disconnect_UDP();
    case SYSTEM_EVENT_STA_AUTHMODE_CHANGE:      /**< the auth mode of AP connected by ESP32 station changed */
		ESP_LOGI(TAG, "SYSTEM_EVENT_STA_AUTHMODE_CHANGE");
    case SYSTEM_EVENT_STA_GOT_IP:               /**< ESP32 station got IP from connected AP */
		ESP_LOGI(TAG, "SYSTEM_EVENT_STA_GOT_IP");
		connect_UDP();
		xEventGroupSetBits(wifi_event_group, CONNECTED_BIT);
    case SYSTEM_EVENT_STA_WPS_ER_SUCCESS:       /**< ESP32 station wps succeeds in enrollee mode */
		ESP_LOGI(TAG, "SYSTEM_EVENT_STA_WPS_ER_SUCCESS");
    case SYSTEM_EVENT_STA_WPS_ER_FAILED:        /**< ESP32 station wps fails in enrollee mode */
		ESP_LOGI(TAG, "SYSTEM_EVENT_STA_WPS_ER_FAILED");
    case SYSTEM_EVENT_STA_WPS_ER_TIMEOUT:       /**< ESP32 station wps timeout in enrollee mode */
		ESP_LOGI(TAG, "SYSTEM_EVENT_STA_WPS_ER_TIMEOUT");
    case SYSTEM_EVENT_STA_WPS_ER_PIN:           /**< ESP32 station wps pin code in enrollee mode */
		ESP_LOGI(TAG, "SYSTEM_EVENT_STA_WPS_ER_PIN");
    case SYSTEM_EVENT_AP_START:                 /**< ESP32 soft-AP start */
		ESP_LOGI(TAG, "SYSTEM_EVENT_AP_START");
    case SYSTEM_EVENT_AP_STOP:                  /**< ESP32 soft-AP stop */
		ESP_LOGI(TAG, "SYSTEM_EVENT_AP_STOP");
    case SYSTEM_EVENT_AP_STACONNECTED:          /**< a station connected to ESP32 soft-AP */
		ESP_LOGI(TAG, "SYSTEM_EVENT_AP_STACONNECTED");
    case SYSTEM_EVENT_AP_STADISCONNECTED:       /**< a station disconnected from ESP32 soft-AP */
		ESP_LOGI(TAG, "SYSTEM_EVENT_AP_STADISCONNECTED");
    case SYSTEM_EVENT_AP_PROBEREQRECVED:        /**< Receive probe request packet in soft-AP interface */
		ESP_LOGI(TAG, "SYSTEM_EVENT_AP_PROBEREQRECVED");
    case SYSTEM_EVENT_AP_STA_GOT_IP6:           /**< ESP32 station or ap interface v6IP addr is preferred */
		ESP_LOGI(TAG, "SYSTEM_EVENT_AP_STA_GOT_IP6");
    case SYSTEM_EVENT_ETH_START:                /**< ESP32 ethernet start */
		ESP_LOGI(TAG, "SYSTEM_EVENT_ETH_START");
    case SYSTEM_EVENT_ETH_STOP:                 /**< ESP32 ethernet stop */
		ESP_LOGI(TAG, "SYSTEM_EVENT_ETH_STOP");
    case SYSTEM_EVENT_ETH_CONNECTED:            /**< ESP32 ethernet phy link up */
		ESP_LOGI(TAG, "SYSTEM_EVENT_ETH_CONNECTED");
    case SYSTEM_EVENT_ETH_DISCONNECTED:         /**< ESP32 ethernet phy link down */
		ESP_LOGI(TAG, "SYSTEM_EVENT_ETH_DISCONNECTED");
    case SYSTEM_EVENT_ETH_GOT_IP:               /**< ESP32 ethernet got IP from connected AP */
		ESP_LOGI(TAG, "SYSTEM_EVENT_ETH_GOT_IP");
    default:
    return ESP_OK;
static void initialise_wifi(void)
    tcpip_adapter_init();
    wifi_event_group = xEventGroupCreate();
    ESP_ERROR_CHECK( esp_event_loop_init(event_handler, NULL) );
    ESP_ERROR_CHECK( esp_wifi_set_storage(WIFI_STORAGE_RAM) );
    wifi_config_t wifi_config = {
        .sta = {
        		.ssid = "Console",
				.password = "password",
				.bssid_set = false
    ESP_LOGI(TAG, "Setting WiFi configuration SSID %s...", wifi_config.sta.ssid);
    ESP_ERROR_CHECK( esp_wifi_set_mode(WIFI_MODE_STA) );
    ESP_ERROR_CHECK( esp_wifi_set_config(ESP_IF_WIFI_STA, &wifi_config) );
static void send_UDP(void *pvParameters)
	int r;
	while (1) {
        xEventGroupWaitBits(wifi_event_group, CONNECTED_BIT,
                            false, true, portMAX_DELAY);
        ESP_LOGI(TAG_SEND, "Connected to AP");
        ESP_LOGE(TAG_SEND, "socketnumber=%d", sock);
        ESP_LOGE(TAG_SEND, "Local IP-address=%s", inet_ntoa(source.sin_addr.s_addr));
        ESP_LOGE(TAG_SEND, "Len=%d", destination.sin_len);
        ESP_LOGE(TAG_SEND, "Family=%d", destination.sin_family);
        ESP_LOGE(TAG_SEND, "Port number=%d", destination.sin_port);
        ESP_LOGE(TAG_SEND, "Decimal Destination IP-address=%x", destination.sin_addr.s_addr);
        ESP_LOGE(TAG_SEND, "Destination IP-address=%s", inet_ntoa(destination.sin_addr.s_addr));
        /* Send UDP data*/
    	char *data = "Hello world!";
        r = sendto(sock, data, strlen(data), 0, (struct sockaddr *) &destination, sizeof(destination));
        ESP_LOGI(TAG_SEND, "... done sending to socket. Last read return=%d errno=%d", r, errno);
        ESP_LOGI(TAG_SEND, "Starting again!");
static void receive_UDP(void *pvParameters)
	int r;
	struct sockaddr_storage fromAddr;   // same as the previous entity struct sockaddr_storage serverStorage;
    unsigned int addrlen;
    uint8_t *recv_buffer;
    addrlen = sizeof(fromAddr);
    recv_buffer = (uint8_t *) malloc(250);
    while (1) {
        ESP_LOGI(TAG_RECEIVE, "Connected to AP");
        ESP_LOGE(TAG_RECEIVE, "socketnumber=%d", sock);
        /* Read UDP data */
        do {
        	memset((void *) recv_buffer, 0, 250);
            r = recvfrom(sock, recv_buffer, 98, 0, (struct sockaddr *) &destination, &addrlen);
            for (int i = 0; i < r; i++) {
                putchar(recv_buffer[i]);
        } while (r > 0);
        ESP_LOGI(TAG_RECEIVE, "... done reading from socket. Last read return=%d errno=%d", r, errno);
        ESP_LOGI(TAG_RECEIVE, "Starting again!");
void app_main()
    nvs_flash_init();
    initialise_wifi();
    xTaskCreate(&receive_UDP, "receive_UDP", 2048, NULL, 5, NULL);
    xTaskCreate(&send_UDP, "send_UDP", 2048, NULL, 5, NULL);
WiFive
Re: recvfrom returns -1 with error-code 11
Postby WiFive » Wed Apr 19, 2017 10:48 pm
Wamor45
Postby Wamor45 » Fri Apr 21, 2017 8:32 pm
Thank you WiFive for your response.
I looked at the link you mentioned and decided not to use loop-back but send information to my gateway.
My gateway is returning the data back again then.
Please find below my program. I don't receive anything at my gateway and nothing is returned.
Any clues what could be wrong here ?
Regards,
Wamor
#include <string.h>
   'make menuconfig'.
int sock_server = 0;
struct sockaddr_in sa_server;
int sock_client = 0;
struct sockaddr_in sa_client;
	memset(&sa_server, 0, sizeof sa_server);
	sa_server.sin_family = AF_INET;
	sa_server.sin_addr.s_addr = ip_info.ip.addr;
	sa_server.sin_port = htons(PORT_NUMBER);
	sock_server = socket(PF_INET, SOCK_DGRAM, IPPROTO_UDP);
	if (bind(sock_server, (struct sockaddr *) &sa_server, sizeof sa_server) < 0) {
		ESP_LOGE(TAG, "error bind failed");
		close(sock_server);
		exit(EXIT_FAILURE);
	/* create an Internet, datagram, socket using UDP */
	sock_client = socket(PF_INET, SOCK_DGRAM, IPPROTO_UDP);
	if (sock_client < 0) {
		/* if socket failed to initialize, exit */
		ESP_LOGE(TAG, "Error Creating Socket");
		exit(EXIT_FAILURE);
	memset(&sa_client, 0, sizeof sa_client);
	sa_client.sin_family = AF_INET;
	sa_client.sin_addr.s_addr = ip_info.gw.addr;
	sa_client.sin_port = htons(PORT_NUMBER);
    close(sock_server);
    close(sock_client);
		disconnect_UDP();
		connect_UDP();
    default:
    return ESP_OK;
        .sta = {
        		.ssid = "Console",
				.bssid_set = false
	int r;
	while (1) {
        ESP_LOGE(TAG_SEND, "socket_client number=%d", sock_client);
        ESP_LOGE(TAG_SEND, "Local IP-address=%s", inet_ntoa(sa_server.sin_addr.s_addr));
        ESP_LOGE(TAG_SEND, "Len=%d", sa_client.sin_len);
        ESP_LOGE(TAG_SEND, "Family=%d", sa_client.sin_family);
        ESP_LOGE(TAG_SEND, "Port number=%d", sa_client.sin_port);
        ESP_LOGE(TAG_SEND, "Destination IP-address=%s", inet_ntoa(sa_client.sin_addr.s_addr));
        /* Send UDP data*/
        r = sendto(sock_client, data, strlen(data), 0, (struct sockaddr *) &sa_client, sizeof(sa_client));
	int r;
    addrlen = sizeof(sa_server);
    while (1) {
        ESP_LOGE(TAG_RECEIVE, "socket_server number=%d", sock_server);
        /* Read UDP data */
        do {
            r = recvfrom(sock_server, recv_buffer, sizeof(recv_buffer) - 1, 0, (struct sockaddr *) &sa_server, &addrlen);
        } while (r > 0);
void app_main()
    nvs_flash_init();
    initialise_wifi();
Users browsing this forum: Qwantbot, Semrush [Bot] and 2 guests
