calling it with stack depth of 1 - 2048 causes:
***ERROR*** A stack overflow in task atask has been detected.
calling it with stack depth of 2048 - some_high_value causes:
abort() was called at PC 0x400874b7 on core 0
what can i do to make you help me with this?
i am trying to do a patch over a patch (over a patch) since i cannot seem to read the data returning from an http request...
thanks in advance.
how to use xTaskCreatePinnedToCore?
Re: how to use xTaskCreatePinnedToCore?
The stack overflow is exactly what it sounds like. It's more likely that the abort() is something else, but without seeing your code or a backtrace, it's impossible to know what it was.
Its probably not the case, but do you have task in infinite loop or does it end with vTaskDelete? Task cant exit.
Users browsing this forum: Amazon [Bot] and 10 guests
