is my module failing?
mzimmers
Postby mzimmers » Tue Sep 01, 2020 3:28 pm
ESP32-WROVER
On startup, I often get messages like this:
E (1332) spiram: SPI SRAM memory test fail. 3/131072 writes failed, first @ 3FB12020
E (1332) cpu_start: External RAM failed memory test!
abort() was called at PC 0x4008169f on core 0
E (1332) spiram: SPI SRAM memory test fail. 4/131072 writes failed, first @ 3FAD3420
Eventually it starts up OK.
Re: is my module failing?
Postby Sprite » Wed Sep 02, 2020 8:16 am
Sounds like something weird is going on with SPIRAM indeed... Just to check: Are you sure you don't have anything connected to the flash pins of the module (including any possibly-conductive nastiness near the pads?) Do you still have the issue if you select '2T' mode for psram in menuconfig?
mzimmers
Postby mzimmers » Wed Sep 02, 2020 8:27 pm
Hi Sprite - I don't think there's anything touching the pins on the module. This unit has been working fine for months, and just recently started this behavior.
Changing the 2T setting did seem to make this problem go away; are there any side effects of this mode that I should be aware of?
Thanks...
Postby Sprite » Thu Sep 03, 2020 7:09 am
The side effect is that you loose half of the capacity of your chip. Assuming you have an 8M chip in there an do not use the himem API, it shouldn't matter.
Users browsing this forum: Google [Bot] and 2 guests
