Skipping cmake@3.16.4 (already installed)
Requirement already satisfied: gdbgui>=0.13.2.0 in c:\users\xxxx\.espressif\python_env\idf4.3_py3.7_env\lib\site-packages (from -r xxxx\esp-idf\requirements.txt (line 14)) (0.14.0.0)
All done! You can now run:
export.bat2、而后执行export.bat
C:\Users\xxxx\.espressif\tools\cmake\3.16.4\bin
The following Python requirements are not satisfied:
gdbgui>=0.13.2.0gdbgui;gdbgui-0.14.0.0.dist-info。在gdbgui中VERSION.txt中显示版本为0.14.0.0。明显版本能够足要求。
4、总合来看,系统中己安装0.14版本的gdbgui,但在export.bat时却显示版本问题,请问这个问题该怎么解决?
