Hi everyone.
What is difference between LoRa.write() and LoRa.print()?
I noticed this two commands send data package to LoRa network, but if I send message by LoRa.write(), the receiver side receive a strange characters.
Difference between Esp32 LoRa.write() and LoRa.print() commands
flavioavilela
Re: Difference between Esp32 LoRa.write() and LoRa.print() commands
Hello. Im having the same problem with not knowing which one to use. Have you found the answer to use for this?
LoRa.write(byte) sends a single byte as given in docs - https://github.com/sandeepmistry/arduin ... md#writing
LoRa.read() reads single byte from packet - https://github.com/sandeepmistry/arduin ... md#reading
On the receiver side -> byte data = LoRa.read();
then you can change the byte to a HEX string using String(data, HEX);
