Sample code crashes upon BLE and WIFI enabled
ukrsms
Postby ukrsms » Thu Oct 01, 2020 2:24 pm
First I faced the problem in my custom firmware and later I reproduced it in a simple example code.
In the code below I just merge two examples: examples\bluetooth\bluedroid\ble\ble_spp_server\ and examples\wifi\getting_started\station\ into one file. The resulted code is as following:
#include "esp_wifi.h"
#include "esp_event.h"
#include "lwip/err.h"
#include "lwip/sys.h"
#include "freertos/task.h"
#include "esp_system.h"
#include "esp_log.h"
#include "nvs_flash.h"
#include "esp_bt.h"
#include "driver/uart.h"
#include "string.h"
#include "esp_gap_ble_api.h"
#include "esp_gatts_api.h"
#include "esp_bt_defs.h"
#include "esp_bt_main.h"
#include "ble_spp_server_demo.h"
/* The examples use WiFi configuration that you can set via project configuration menu
   If you'd rather not, just change the below entries to strings with
   the config you want - ie #define EXAMPLE_WIFI_SSID "mywifissid"
#define EXAMPLE_ESP_WIFI_SSID      "xxx"
#define EXAMPLE_ESP_WIFI_PASS      "xxxxxxxxx"
#define EXAMPLE_ESP_MAXIMUM_RETRY  5
/* FreeRTOS event group to signal when we are connected*/
static EventGroupHandle_t s_wifi_event_group;
/* The event group allows multiple bits for each event, but we only care about two events:
 * - we are connected to the AP with an IP
 * - we failed to connect after the maximum amount of retries */
#define WIFI_CONNECTED_BIT BIT0
#define WIFI_FAIL_BIT      BIT1
static const char *TAG = "wifi station";
static int s_retry_num = 0;
#if 1		//wifi part
static void event_handler(void* arg, esp_event_base_t event_base,
                                int32_t event_id, void* event_data)
    if (event_base == WIFI_EVENT && event_id == WIFI_EVENT_STA_START) {
        esp_wifi_connect();
    } else if (event_base == WIFI_EVENT && event_id == WIFI_EVENT_STA_DISCONNECTED) {
        if (s_retry_num < EXAMPLE_ESP_MAXIMUM_RETRY) {
            esp_wifi_connect();
            s_retry_num++;
            ESP_LOGI(TAG, "retry to connect to the AP");
            xEventGroupSetBits(s_wifi_event_group, WIFI_FAIL_BIT);
        ESP_LOGI(TAG,"connect to the AP fail");
    } else if (event_base == IP_EVENT && event_id == IP_EVENT_STA_GOT_IP) {
        ip_event_got_ip_t* event = (ip_event_got_ip_t*) event_data;
        ESP_LOGI(TAG, "got ip:" IPSTR, IP2STR(&event->ip_info.ip));
        s_retry_num = 0;
        xEventGroupSetBits(s_wifi_event_group, WIFI_CONNECTED_BIT);
void wifi_init_sta(void)
    s_wifi_event_group = xEventGroupCreate();
    esp_netif_create_default_wifi_sta();
    ESP_ERROR_CHECK(esp_event_handler_register(WIFI_EVENT, ESP_EVENT_ANY_ID, &event_handler, NULL));
    ESP_ERROR_CHECK(esp_event_handler_register(IP_EVENT, IP_EVENT_STA_GOT_IP, &event_handler, NULL));
    wifi_config_t wifi_config = {
        .sta = {
            .ssid = "ukrsms",
            .password = "dubrovycja"
    ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_STA) );
    ESP_ERROR_CHECK(esp_wifi_set_config(ESP_IF_WIFI_STA, &wifi_config) );
    ESP_ERROR_CHECK(esp_wifi_start() );
    ESP_LOGI(TAG, "wifi_init_sta finished.");
    /* Waiting until either the connection is established (WIFI_CONNECTED_BIT) or connection failed for the maximum
     * number of re-tries (WIFI_FAIL_BIT). The bits are set by event_handler() (see above) */
    EventBits_t bits = xEventGroupWaitBits(s_wifi_event_group,
            WIFI_CONNECTED_BIT | WIFI_FAIL_BIT,
            pdFALSE,
            pdFALSE,
            portMAX_DELAY);
    /* xEventGroupWaitBits() returns the bits before the call returned, hence we can test which event actually
     * happened. */
    if (bits & WIFI_CONNECTED_BIT) {
        ESP_LOGI(TAG, "connected to ap SSID:%s password:%s",
                 EXAMPLE_ESP_WIFI_SSID, EXAMPLE_ESP_WIFI_PASS);
    } else if (bits & WIFI_FAIL_BIT) {
        ESP_LOGI(TAG, "Failed to connect to SSID:%s, password:%s",
        ESP_LOGE(TAG, "UNEXPECTED EVENT");
    ESP_ERROR_CHECK(esp_event_handler_unregister(IP_EVENT, IP_EVENT_STA_GOT_IP, &event_handler));
    ESP_ERROR_CHECK(esp_event_handler_unregister(WIFI_EVENT, ESP_EVENT_ANY_ID, &event_handler));
    vEventGroupDelete(s_wifi_event_group);
#endif
#define GATTS_TABLE_TAG  "GATTS_SPP_DEMO"
#define SPP_PROFILE_NUM             1
#define SPP_PROFILE_APP_IDX         0
#define ESP_SPP_APP_ID              0x56
#define SAMPLE_DEVICE_NAME          "ESP_SPP_SERVER"
#define SPP_SVC_INST_ID	            0
/// SPP Service
static const uint16_t spp_service_uuid = 0xABF0;
/// Characteristic UUID
#define ESP_GATT_UUID_SPP_DATA_RECEIVE      0xABF1
#define ESP_GATT_UUID_SPP_DATA_NOTIFY       0xABF2
#define ESP_GATT_UUID_SPP_COMMAND_RECEIVE   0xABF3
#define ESP_GATT_UUID_SPP_COMMAND_NOTIFY    0xABF4
#ifdef SUPPORT_HEARTBEAT
#define ESP_GATT_UUID_SPP_HEARTBEAT         0xABF5
#endif
static const uint8_t spp_adv_data[23] = {
    0x02,0x01,0x06,
    0x03,0x03,0xF0,0xAB,
    0x0F,0x09,0x45,0x53,0x50,0x5f,0x53,0x50,0x50,0x5f,0x53,0x45,0x52,0x56,0x45,0x52
static uint16_t spp_mtu_size = 23;
static uint16_t spp_conn_id = 0xffff;
static esp_gatt_if_t spp_gatts_if = 0xff;
QueueHandle_t spp_uart_queue = NULL;
static xQueueHandle cmd_cmd_queue = NULL;
static xQueueHandle cmd_heartbeat_queue = NULL;
static uint8_t  heartbeat_s[9] = {'E','s','p','r','e','s','s','i','f'};
static bool enable_heart_ntf = false;
static uint8_t heartbeat_count_num = 0;
#endif
static bool enable_data_ntf = false;
static bool is_connected = false;
static esp_bd_addr_t spp_remote_bda = {0x0,};
static uint16_t spp_handle_table[SPP_IDX_NB];
static esp_ble_adv_params_t spp_adv_params = {
    .adv_int_min        = 0x20,
    .adv_int_max        = 0x40,
    .adv_type           = ADV_TYPE_IND,
    .own_addr_type      = BLE_ADDR_TYPE_PUBLIC,
    .channel_map        = ADV_CHNL_ALL,
    .adv_filter_policy  = ADV_FILTER_ALLOW_SCAN_ANY_CON_ANY,
struct gatts_profile_inst {
    esp_gatts_cb_t gatts_cb;
    uint16_t gatts_if;
    uint16_t app_id;
    uint16_t conn_id;
    uint16_t service_handle;
    esp_gatt_srvc_id_t service_id;
    uint16_t char_handle;
    esp_bt_uuid_t char_uuid;
    esp_gatt_perm_t perm;
    esp_gatt_char_prop_t property;
    uint16_t descr_handle;
    esp_bt_uuid_t descr_uuid;
typedef struct spp_receive_data_node{
    int32_t len;
    uint8_t * node_buff;
    struct spp_receive_data_node * next_node;
}spp_receive_data_node_t;
static spp_receive_data_node_t * temp_spp_recv_data_node_p1 = NULL;
static spp_receive_data_node_t * temp_spp_recv_data_node_p2 = NULL;
typedef struct spp_receive_data_buff{
    int32_t node_num;
    int32_t buff_size;
    spp_receive_data_node_t * first_node;
}spp_receive_data_buff_t;
static spp_receive_data_buff_t SppRecvDataBuff = {
    .node_num   = 0,
    .buff_size  = 0,
    .first_node = NULL
static void gatts_profile_event_handler(esp_gatts_cb_event_t event, esp_gatt_if_t gatts_if, esp_ble_gatts_cb_param_t *param);
/* One gatt-based profile one app_id and one gatts_if, this array will store the gatts_if returned by ESP_GATTS_REG_EVT */
static struct gatts_profile_inst spp_profile_tab[SPP_PROFILE_NUM] = {
    [SPP_PROFILE_APP_IDX] = {
        .gatts_cb = gatts_profile_event_handler,
        .gatts_if = ESP_GATT_IF_NONE,       /* Not get the gatt_if, so initial is ESP_GATT_IF_NONE */
 *  SPP PROFILE ATTRIBUTES
#define CHAR_DECLARATION_SIZE   (sizeof(uint8_t))
static const uint16_t primary_service_uuid = ESP_GATT_UUID_PRI_SERVICE;
static const uint16_t character_declaration_uuid = ESP_GATT_UUID_CHAR_DECLARE;
static const uint16_t character_client_config_uuid = ESP_GATT_UUID_CHAR_CLIENT_CONFIG;
static const uint8_t char_prop_read_notify = ESP_GATT_CHAR_PROP_BIT_READ|ESP_GATT_CHAR_PROP_BIT_NOTIFY;
static const uint8_t char_prop_read_write = ESP_GATT_CHAR_PROP_BIT_WRITE_NR|ESP_GATT_CHAR_PROP_BIT_READ;
static const uint8_t char_prop_read_write_notify = ESP_GATT_CHAR_PROP_BIT_READ|ESP_GATT_CHAR_PROP_BIT_WRITE_NR|ESP_GATT_CHAR_PROP_BIT_NOTIFY;
#endif
///SPP Service - data receive characteristic, read&write without response
static const uint16_t spp_data_receive_uuid = ESP_GATT_UUID_SPP_DATA_RECEIVE;
static const uint8_t  spp_data_receive_val[20] = {0x00};
///SPP Service - data notify characteristic, notify&read
static const uint16_t spp_data_notify_uuid = ESP_GATT_UUID_SPP_DATA_NOTIFY;
static const uint8_t  spp_data_notify_val[20] = {0x00};
static const uint8_t  spp_data_notify_ccc[2] = {0x00, 0x00};
///SPP Service - command characteristic, read&write without response
static const uint16_t spp_command_uuid = ESP_GATT_UUID_SPP_COMMAND_RECEIVE;
static const uint8_t  spp_command_val[10] = {0x00};
///SPP Service - status characteristic, notify&read
static const uint16_t spp_status_uuid = ESP_GATT_UUID_SPP_COMMAND_NOTIFY;
static const uint8_t  spp_status_val[10] = {0x00};
static const uint8_t  spp_status_ccc[2] = {0x00, 0x00};
///SPP Server - Heart beat characteristic, notify&write&read
static const uint16_t spp_heart_beat_uuid = ESP_GATT_UUID_SPP_HEARTBEAT;
static const uint8_t  spp_heart_beat_val[2] = {0x00, 0x00};
static const uint8_t  spp_heart_beat_ccc[2] = {0x00, 0x00};
#endif
///Full HRS Database Description - Used to add attributes into the database
static const esp_gatts_attr_db_t spp_gatt_db[SPP_IDX_NB] =
    //SPP -  Service Declaration
    [SPP_IDX_SVC]                      	=
    {{ESP_GATT_AUTO_RSP}, {ESP_UUID_LEN_16, (uint8_t *)&primary_service_uuid, ESP_GATT_PERM_READ,
    sizeof(spp_service_uuid), sizeof(spp_service_uuid), (uint8_t *)&spp_service_uuid}},
    //SPP -  data receive characteristic Declaration
    [SPP_IDX_SPP_DATA_RECV_CHAR]            =
    {{ESP_GATT_AUTO_RSP}, {ESP_UUID_LEN_16, (uint8_t *)&character_declaration_uuid, ESP_GATT_PERM_READ,
    CHAR_DECLARATION_SIZE,CHAR_DECLARATION_SIZE, (uint8_t *)&char_prop_read_write}},
    //SPP -  data receive characteristic Value
    [SPP_IDX_SPP_DATA_RECV_VAL]             	=
    {{ESP_GATT_AUTO_RSP}, {ESP_UUID_LEN_16, (uint8_t *)&spp_data_receive_uuid, ESP_GATT_PERM_READ|ESP_GATT_PERM_WRITE,
    SPP_DATA_MAX_LEN,sizeof(spp_data_receive_val), (uint8_t *)spp_data_receive_val}},
    //SPP -  data notify characteristic Declaration
    [SPP_IDX_SPP_DATA_NOTIFY_CHAR]  =
    CHAR_DECLARATION_SIZE,CHAR_DECLARATION_SIZE, (uint8_t *)&char_prop_read_notify}},
    //SPP -  data notify characteristic Value
    [SPP_IDX_SPP_DATA_NTY_VAL]   =
    {{ESP_GATT_AUTO_RSP}, {ESP_UUID_LEN_16, (uint8_t *)&spp_data_notify_uuid, ESP_GATT_PERM_READ,
    SPP_DATA_MAX_LEN, sizeof(spp_data_notify_val), (uint8_t *)spp_data_notify_val}},
    //SPP -  data notify characteristic - Client Characteristic Configuration Descriptor
    [SPP_IDX_SPP_DATA_NTF_CFG]         =
    {{ESP_GATT_AUTO_RSP}, {ESP_UUID_LEN_16, (uint8_t *)&character_client_config_uuid, ESP_GATT_PERM_READ|ESP_GATT_PERM_WRITE,
    sizeof(uint16_t),sizeof(spp_data_notify_ccc), (uint8_t *)spp_data_notify_ccc}},
    //SPP -  command characteristic Declaration
    [SPP_IDX_SPP_COMMAND_CHAR]            =
    //SPP -  command characteristic Value
    [SPP_IDX_SPP_COMMAND_VAL]                 =
    {{ESP_GATT_AUTO_RSP}, {ESP_UUID_LEN_16, (uint8_t *)&spp_command_uuid, ESP_GATT_PERM_READ|ESP_GATT_PERM_WRITE,
    SPP_CMD_MAX_LEN,sizeof(spp_command_val), (uint8_t *)spp_command_val}},
    //SPP -  status characteristic Declaration
    [SPP_IDX_SPP_STATUS_CHAR]            =
    //SPP -  status characteristic Value
    [SPP_IDX_SPP_STATUS_VAL]                 =
    {{ESP_GATT_AUTO_RSP}, {ESP_UUID_LEN_16, (uint8_t *)&spp_status_uuid, ESP_GATT_PERM_READ,
    SPP_STATUS_MAX_LEN,sizeof(spp_status_val), (uint8_t *)spp_status_val}},
    //SPP -  status characteristic - Client Characteristic Configuration Descriptor
    [SPP_IDX_SPP_STATUS_CFG]         =
    sizeof(uint16_t),sizeof(spp_status_ccc), (uint8_t *)spp_status_ccc}},
    //SPP -  Heart beat characteristic Declaration
    [SPP_IDX_SPP_HEARTBEAT_CHAR]  =
    CHAR_DECLARATION_SIZE,CHAR_DECLARATION_SIZE, (uint8_t *)&char_prop_read_write_notify}},
    //SPP -  Heart beat characteristic Value
    [SPP_IDX_SPP_HEARTBEAT_VAL]   =
    {{ESP_GATT_AUTO_RSP}, {ESP_UUID_LEN_16, (uint8_t *)&spp_heart_beat_uuid, ESP_GATT_PERM_READ|ESP_GATT_PERM_WRITE,
    sizeof(spp_heart_beat_val), sizeof(spp_heart_beat_val), (uint8_t *)spp_heart_beat_val}},
    //SPP -  Heart beat characteristic - Client Characteristic Configuration Descriptor
    [SPP_IDX_SPP_HEARTBEAT_CFG]         =
    sizeof(uint16_t),sizeof(spp_data_notify_ccc), (uint8_t *)spp_heart_beat_ccc}},
#endif
static uint8_t find_char_and_desr_index(uint16_t handle)
    uint8_t error = 0xff;
    for(int i = 0; i < SPP_IDX_NB ; i++){
        if(handle == spp_handle_table[i]){
            return i;
    return error;
static bool store_wr_buffer(esp_ble_gatts_cb_param_t *p_data)
    temp_spp_recv_data_node_p1 = (spp_receive_data_node_t *)malloc(sizeof(spp_receive_data_node_t));
    if(temp_spp_recv_data_node_p1 == NULL){
        ESP_LOGI(GATTS_TABLE_TAG, "malloc error %s %d\n", __func__, __LINE__);
        return false;
    if(temp_spp_recv_data_node_p2 != NULL){
        temp_spp_recv_data_node_p2->next_node = temp_spp_recv_data_node_p1;
    temp_spp_recv_data_node_p1->len = p_data->write.len;
    SppRecvDataBuff.buff_size += p_data->write.len;
    temp_spp_recv_data_node_p1->next_node = NULL;
    temp_spp_recv_data_node_p1->node_buff = (uint8_t *)malloc(p_data->write.len);
    temp_spp_recv_data_node_p2 = temp_spp_recv_data_node_p1;
    memcpy(temp_spp_recv_data_node_p1->node_buff,p_data->write.value,p_data->write.len);
    if(SppRecvDataBuff.node_num == 0){
        SppRecvDataBuff.first_node = temp_spp_recv_data_node_p1;
        SppRecvDataBuff.node_num++;
    }else{
    return true;
static void free_write_buffer(void)
    temp_spp_recv_data_node_p1 = SppRecvDataBuff.first_node;
    while(temp_spp_recv_data_node_p1 != NULL){
        temp_spp_recv_data_node_p2 = temp_spp_recv_data_node_p1->next_node;
        free(temp_spp_recv_data_node_p1->node_buff);
        free(temp_spp_recv_data_node_p1);
        temp_spp_recv_data_node_p1 = temp_spp_recv_data_node_p2;
    SppRecvDataBuff.node_num = 0;
    SppRecvDataBuff.buff_size = 0;
    SppRecvDataBuff.first_node = NULL;
static void print_write_buffer(void)
        uart_write_bytes(UART_NUM_0, (char *)(temp_spp_recv_data_node_p1->node_buff), temp_spp_recv_data_node_p1->len);
        temp_spp_recv_data_node_p1 = temp_spp_recv_data_node_p1->next_node;
void uart_task(void *pvParameters)
    uart_event_t event;
    uint8_t total_num = 0;
    uint8_t current_num = 0;
    for (;;) {
        //Waiting for UART event.
        if (xQueueReceive(spp_uart_queue, (void * )&event, (portTickType)portMAX_DELAY)) {
            switch (event.type) {
            //Event of UART receving data
            case UART_DATA:
                if ((event.size)&&(is_connected)) {
                    uint8_t * temp = NULL;
                    uint8_t * ntf_value_p = NULL;
                    if(!enable_heart_ntf){
                        ESP_LOGE(GATTS_TABLE_TAG, "%s do not enable heartbeat Notify\n", __func__);
#endif
                    if(!enable_data_ntf){
                        ESP_LOGE(GATTS_TABLE_TAG, "%s do not enable data Notify\n", __func__);
                    temp = (uint8_t *)malloc(sizeof(uint8_t)*event.size);
                    if(temp == NULL){
                        ESP_LOGE(GATTS_TABLE_TAG, "%s malloc.1 failed\n", __func__);
                    memset(temp,0x0,event.size);
                    uart_read_bytes(UART_NUM_0,temp,event.size,portMAX_DELAY);
                    if(event.size <= (spp_mtu_size - 3)){
                        esp_ble_gatts_send_indicate(spp_gatts_if, spp_conn_id, spp_handle_table[SPP_IDX_SPP_DATA_NTY_VAL],event.size, temp, false);
                    }else if(event.size > (spp_mtu_size - 3)){
                        if((event.size%(spp_mtu_size - 7)) == 0){
                            total_num = event.size/(spp_mtu_size - 7);
                        }else{
                            total_num = event.size/(spp_mtu_size - 7) + 1;
                        current_num = 1;
                        ntf_value_p = (uint8_t *)malloc((spp_mtu_size-3)*sizeof(uint8_t));
                        if(ntf_value_p == NULL){
                            ESP_LOGE(GATTS_TABLE_TAG, "%s malloc.2 failed\n", __func__);
                            free(temp);
                        while(current_num <= total_num){
                            if(current_num < total_num){
                                ntf_value_p[0] = '#';
                                ntf_value_p[1] = '#';
                                ntf_value_p[2] = total_num;
                                ntf_value_p[3] = current_num;
                                memcpy(ntf_value_p + 4,temp + (current_num - 1)*(spp_mtu_size-7),(spp_mtu_size-7));
                                esp_ble_gatts_send_indicate(spp_gatts_if, spp_conn_id, spp_handle_table[SPP_IDX_SPP_DATA_NTY_VAL],(spp_mtu_size-3), ntf_value_p, false);
                            }else if(current_num == total_num){
                                memcpy(ntf_value_p + 4,temp + (current_num - 1)*(spp_mtu_size-7),(event.size - (current_num - 1)*(spp_mtu_size - 7)));
                                esp_ble_gatts_send_indicate(spp_gatts_if, spp_conn_id, spp_handle_table[SPP_IDX_SPP_DATA_NTY_VAL],(event.size - (current_num - 1)*(spp_mtu_size - 7) + 4), ntf_value_p, false);
                            vTaskDelay(20 / portTICK_PERIOD_MS);
                            current_num++;
                        free(ntf_value_p);
                    free(temp);
            default:
    vTaskDelete(NULL);
static void spp_uart_init(void)
    uart_config_t uart_config = {
        .baud_rate = 115200,
        .flow_ctrl = UART_HW_FLOWCTRL_RTS,
        .rx_flow_ctrl_thresh = 122,
        .source_clk = UART_SCLK_APB,
    //Install UART driver, and get the queue.
    uart_driver_install(UART_NUM_0, 4096, 8192, 10,&spp_uart_queue,0);
    //Set UART parameters
    uart_param_config(UART_NUM_0, &uart_config);
    //Set UART pins
    uart_set_pin(UART_NUM_0, UART_PIN_NO_CHANGE, UART_PIN_NO_CHANGE, UART_PIN_NO_CHANGE, UART_PIN_NO_CHANGE);
    xTaskCreate(uart_task, "uTask", 2048, (void*)UART_NUM_0, 8, NULL);
void spp_heartbeat_task(void * arg)
    uint16_t cmd_id;
    for(;;) {
        vTaskDelay(50 / portTICK_PERIOD_MS);
        if(xQueueReceive(cmd_heartbeat_queue, &cmd_id, portMAX_DELAY)) {
            while(1){
                heartbeat_count_num++;
                vTaskDelay(5000/ portTICK_PERIOD_MS);
                if((heartbeat_count_num >3)&&(is_connected)){
                    esp_ble_gap_disconnect(spp_remote_bda);
                if(is_connected && enable_heart_ntf){
                    esp_ble_gatts_send_indicate(spp_gatts_if, spp_conn_id, spp_handle_table[SPP_IDX_SPP_HEARTBEAT_VAL],sizeof(heartbeat_s), heartbeat_s, false);
                }else if(!is_connected){
    vTaskDelete(NULL);
#endif
void spp_cmd_task(void * arg)
    uint8_t * cmd_id;
    for(;;){
        if(xQueueReceive(cmd_cmd_queue, &cmd_id, portMAX_DELAY)) {
            esp_log_buffer_char(GATTS_TABLE_TAG,(char *)(cmd_id),strlen((char *)cmd_id));
            free(cmd_id);
    vTaskDelete(NULL);
static void spp_task_init(void)
    spp_uart_init();
    cmd_heartbeat_queue = xQueueCreate(10, sizeof(uint32_t));
    xTaskCreate(spp_heartbeat_task, "spp_heartbeat_task", 2048, NULL, 10, NULL);
#endif
    cmd_cmd_queue = xQueueCreate(10, sizeof(uint32_t));
    xTaskCreate(spp_cmd_task, "spp_cmd_task", 2048, NULL, 10, NULL);
static void gap_event_handler(esp_gap_ble_cb_event_t event, esp_ble_gap_cb_param_t *param)
    esp_err_t err;
    ESP_LOGE(GATTS_TABLE_TAG, "GAP_EVT, event %d\n", event);
    switch (event) {
    case ESP_GAP_BLE_ADV_DATA_RAW_SET_COMPLETE_EVT:
        esp_ble_gap_start_advertising(&spp_adv_params);
    case ESP_GAP_BLE_ADV_START_COMPLETE_EVT:
        //advertising start complete event to indicate advertising start successfully or failed
        if((err = param->adv_start_cmpl.status) != ESP_BT_STATUS_SUCCESS) {
            ESP_LOGE(GATTS_TABLE_TAG, "Advertising start failed: %s\n", esp_err_to_name(err));
    default:
    esp_ble_gatts_cb_param_t *p_data = (esp_ble_gatts_cb_param_t *) param;
    uint8_t res = 0xff;
    ESP_LOGI(GATTS_TABLE_TAG, "event = %x\n",event);
    switch (event) {
    	case ESP_GATTS_REG_EVT:
    	    ESP_LOGI(GATTS_TABLE_TAG, "%s %d\n", __func__, __LINE__);
        	esp_ble_gap_set_device_name(SAMPLE_DEVICE_NAME);
        	esp_ble_gap_config_adv_data_raw((uint8_t *)spp_adv_data, sizeof(spp_adv_data));
        	esp_ble_gatts_create_attr_tab(spp_gatt_db, gatts_if, SPP_IDX_NB, SPP_SVC_INST_ID);
    	case ESP_GATTS_READ_EVT:
            res = find_char_and_desr_index(p_data->read.handle);
            if(res == SPP_IDX_SPP_STATUS_VAL){
                //TODO:client read the status characteristic
    	case ESP_GATTS_WRITE_EVT: {
    	    res = find_char_and_desr_index(p_data->write.handle);
            if(p_data->write.is_prep == false){
                ESP_LOGI(GATTS_TABLE_TAG, "ESP_GATTS_WRITE_EVT : handle = %d\n", res);
                if(res == SPP_IDX_SPP_COMMAND_VAL){
                    uint8_t * spp_cmd_buff = NULL;
                    spp_cmd_buff = (uint8_t *)malloc((spp_mtu_size - 3) * sizeof(uint8_t));
                    if(spp_cmd_buff == NULL){
                        ESP_LOGE(GATTS_TABLE_TAG, "%s malloc failed\n", __func__);
                    memset(spp_cmd_buff,0x0,(spp_mtu_size - 3));
                    memcpy(spp_cmd_buff,p_data->write.value,p_data->write.len);
                    xQueueSend(cmd_cmd_queue,&spp_cmd_buff,10/portTICK_PERIOD_MS);
                }else if(res == SPP_IDX_SPP_DATA_NTF_CFG){
                    if((p_data->write.len == 2)&&(p_data->write.value[0] == 0x01)&&(p_data->write.value[1] == 0x00)){
                        enable_data_ntf = true;
                    }else if((p_data->write.len == 2)&&(p_data->write.value[0] == 0x00)&&(p_data->write.value[1] == 0x00)){
                else if(res == SPP_IDX_SPP_HEARTBEAT_CFG){
                        enable_heart_ntf = true;
                }else if(res == SPP_IDX_SPP_HEARTBEAT_VAL){
                    if((p_data->write.len == sizeof(heartbeat_s))&&(memcmp(heartbeat_s,p_data->write.value,sizeof(heartbeat_s)) == 0)){
#endif
                else if(res == SPP_IDX_SPP_DATA_RECV_VAL){
#ifdef SPP_DEBUG_MODE
                    esp_log_buffer_char(GATTS_TABLE_TAG,(char *)(p_data->write.value),p_data->write.len);
#else
                    uart_write_bytes(UART_NUM_0, (char *)(p_data->write.value), p_data->write.len);
#endif
                }else{
                    //TODO:
            }else if((p_data->write.is_prep == true)&&(res == SPP_IDX_SPP_DATA_RECV_VAL)){
                ESP_LOGI(GATTS_TABLE_TAG, "ESP_GATTS_PREP_WRITE_EVT : handle = %d\n", res);
                store_wr_buffer(p_data);
    	case ESP_GATTS_EXEC_WRITE_EVT:{
    	    ESP_LOGI(GATTS_TABLE_TAG, "ESP_GATTS_EXEC_WRITE_EVT\n");
    	    if(p_data->exec_write.exec_write_flag){
    	        print_write_buffer();
    	        free_write_buffer();
    	case ESP_GATTS_MTU_EVT:
    	    spp_mtu_size = p_data->mtu.mtu;
    	case ESP_GATTS_CONF_EVT:
    	case ESP_GATTS_UNREG_EVT:
    	case ESP_GATTS_DELETE_EVT:
    	case ESP_GATTS_START_EVT:
    	case ESP_GATTS_STOP_EVT:
    	case ESP_GATTS_CONNECT_EVT:
    	    spp_conn_id = p_data->connect.conn_id;
    	    spp_gatts_if = gatts_if;
    	    is_connected = true;
    	    memcpy(&spp_remote_bda,&p_data->connect.remote_bda,sizeof(esp_bd_addr_t));
    	    uint16_t cmd = 0;
            xQueueSend(cmd_heartbeat_queue,&cmd,10/portTICK_PERIOD_MS);
#endif
    	case ESP_GATTS_DISCONNECT_EVT:
#endif
    	case ESP_GATTS_OPEN_EVT:
    	case ESP_GATTS_CANCEL_OPEN_EVT:
    	case ESP_GATTS_CLOSE_EVT:
    	case ESP_GATTS_LISTEN_EVT:
    	case ESP_GATTS_CONGEST_EVT:
    	case ESP_GATTS_CREAT_ATTR_TAB_EVT:{
    	    ESP_LOGI(GATTS_TABLE_TAG, "The number handle =%x\n",param->add_attr_tab.num_handle);
    	    if (param->add_attr_tab.status != ESP_GATT_OK){
    	        ESP_LOGE(GATTS_TABLE_TAG, "Create attribute table failed, error code=0x%x", param->add_attr_tab.status);
    	    else if (param->add_attr_tab.num_handle != SPP_IDX_NB){
    	        ESP_LOGE(GATTS_TABLE_TAG, "Create attribute table abnormally, num_handle (%d) doesn't equal to HRS_IDX_NB(%d)", param->add_attr_tab.num_handle, SPP_IDX_NB);
    	    else {
    	        memcpy(spp_handle_table, param->add_attr_tab.handles, sizeof(spp_handle_table));
    	        esp_ble_gatts_start_service(spp_handle_table[SPP_IDX_SVC]);
    	default:
static void gatts_event_handler(esp_gatts_cb_event_t event, esp_gatt_if_t gatts_if, esp_ble_gatts_cb_param_t *param)
    ESP_LOGI(GATTS_TABLE_TAG, "EVT %d, gatts if %d\n", event, gatts_if);
    /* If event is register event, store the gatts_if for each profile */
    if (event == ESP_GATTS_REG_EVT) {
        if (param->reg.status == ESP_GATT_OK) {
            spp_profile_tab[SPP_PROFILE_APP_IDX].gatts_if = gatts_if;
            ESP_LOGI(GATTS_TABLE_TAG, "Reg app failed, app_id %04x, status %d\n",param->reg.app_id, param->reg.status);
            return;
    do {
        int idx;
        for (idx = 0; idx < SPP_PROFILE_NUM; idx++) {
            if (gatts_if == ESP_GATT_IF_NONE || /* ESP_GATT_IF_NONE, not specify a certain gatt_if, need to call every profile cb function */
                    gatts_if == spp_profile_tab[idx].gatts_if) {
                if (spp_profile_tab[idx].gatts_cb) {
                    spp_profile_tab[idx].gatts_cb(event, gatts_if, param);
    } while (0);
void app_main(void)
    esp_err_t ret;
    esp_bt_controller_config_t bt_cfg = BT_CONTROLLER_INIT_CONFIG_DEFAULT();
    // Initialize NVS
    ret = nvs_flash_init();
    ESP_ERROR_CHECK( ret );
    ESP_ERROR_CHECK(esp_bt_controller_mem_release(ESP_BT_MODE_CLASSIC_BT));
    ret = esp_bt_controller_init(&bt_cfg);
    if (ret) {
        ESP_LOGE(GATTS_TABLE_TAG, "%s enable controller failed: %s\n", __func__, esp_err_to_name(ret));
        return;
    ret = esp_bt_controller_enable(ESP_BT_MODE_BLE);
    if (ret) {
        return;
    ESP_LOGI(GATTS_TABLE_TAG, "%s init bluetooth\n", __func__);
    ret = esp_bluedroid_init();
    if (ret) {
        ESP_LOGE(GATTS_TABLE_TAG, "%s init bluetooth failed: %s\n", __func__, esp_err_to_name(ret));
        return;
    ret = esp_bluedroid_enable();
    if (ret) {
        ESP_LOGE(GATTS_TABLE_TAG, "%s enable bluetooth failed: %s\n", __func__, esp_err_to_name(ret));
        return;
    esp_ble_gatts_register_callback(gatts_event_handler);
    esp_ble_gap_register_callback(gap_event_handler);
    esp_ble_gatts_app_register(ESP_SPP_APP_ID);
    spp_task_init();
    ESP_LOGI(TAG, "ESP_WIFI_MODE_STA");
    wifi_init_sta();
    while(1)
        vTaskDelay(200);
        printf("Time:%lld\n", esp_timer_get_time()/1000);
At first I could not flash the resulted binary into the chip as it exceeded the default partition size (1M), so I specify a custom partition table for it:
# ESP-IDF Partition Table
# Name,   Type, SubType, Offset,  Size, Flags
nvs,      data, nvs,     0x9000,  0x6000,
phy_init, data, phy,     0xf000,  0x1000,
factory,  app,  factory, 0x10000, 2M,
While using default sdkconfig configuration it works well. But when I enabled the following two options (and a few others)
CONFIG_COMPILER_STACK_CHECK=y and
CONFIG_HEAP_TRACING=y
the program began crashing. In my case, it crashes randomly in the range 50..500sec.
T:171623
T:173623
T:175623
T:177623
Guru Meditation Error: Core  0 panic'ed (IllegalInstruction). Exception was unhandled.
Memory dump at 0x40082fdc: fff9e502 0000f01d d2004136
0x40082fdc: __wrap_free at c:\esp-idf\components\heap\include/heap_trace.inc:162
Core 0 register dump:
PC      : 0x40082fe0  PS      : 0x00060d30  A0      : 0x00040020  A1      : 0x3ffdea30
0x40082fe0: __wrap_free at c:\esp-idf\components\heap\include/heap_trace.inc:163
A2      : 0x3ffe4fe0  A3      : 0x3ffceb70  A4      : 0x00000001  A5      : 0x00000001
A6      : 0x0000cdcd  A7      : 0x00000100  A8      : 0x80082fe0  A9      : 0x3ffdea00
A10     : 0x639eb662  A11     : 0x3ffc9b5c  A12     : 0xffffffff  A13     : 0x00000000
A14     : 0x00000010  A15     : 0x00000000  SAR     : 0x0000001d  EXCCAUSE: 0x00000000
EXCVADDR: 0x00000000  LBEG    : 0x4000c2e0  LEND    : 0x4000c2f6  LCOUNT  : 0xffffffff
ELF file SHA256: 90b62c5ff08a0cc0c7bb21b16a1ae3dd5525fad884c596a55a9e39d79b6ead63
Backtrace: 0x40082fdd:0x3ffdea30 0x0004001d:0x3ffdea50 |<-CORRUPTED
0x40082fdd: __wrap_free at c:\esp-idf\components\heap\include/heap_trace.inc:162
It is interesting that with the configurations enabled both examples (WIFI and BLE) work fine and after being merged it leads to the issue.
Could someone comment on the issue?
(1.26 KiB) Downloaded 462 times
ble_spp_server_demo.c
(31.95 KiB) Downloaded 450 times
partitions.csv
(197 Bytes) Downloaded 441 times
PeterR
Re: Sample code crashes upon BLE and WIFI enabled
Postby PeterR » Thu Oct 01, 2020 4:06 pm
Usually this sort of thing is about stack sizes.
Try using uxTaskGetSystemState() and printf names & .usStackHighWaterMark
That will tell you how close to the wind you are flying.
BLE & Wifi will use a lot of memory. You only have one antena as well.
Maybe this is heap failure? Try dumping the results of heap_caps_get_info() after each initialiser.
ukrsms
Postby ukrsms » Fri Oct 02, 2020 10:46 am
@PeterR, do you mean it may be necessary to increase tasks stack size if stack overflows?
By dumping tasks heaps I get
Task name       Time spent      StackHighWaterMark
main            3239354         6364
IDLE0           631724392       1012
Net             49639           2740
tiT             1172789         3304
Tmr Svc         98              1584
BTC_TASK        23726           2872
sys_evt         7911            2816
wifi            50635043        1188
esp_timer       9426029         3232
btController    37879369        2084
hciT            46656           1716
btuT            40391           4868
And results of heap_caps_get_info dumping:
type: data, total_free_bytes: 112260
type: exe, total_free_bytes: 162840
type: spi, total_free_bytes: 0
As for me, there is some reserve in each task, however, the problem exists somewhere...
As I see BT and WIFI use separated stacks so one should not influence another, but the problem does occur only when both are activated.
Users browsing this forum: Amazon [Bot], Bytespider, Google [Bot] and 3 guests
