OpenSource HydraBus / ESP-WROOM-32 Breakout board OSHPark
hydrabus
Contact:
Postby hydrabus » Wed Aug 10, 2016 4:24 pm
HydraBus v1.0 Shield / Breakout board for ESP-WROOM-32 (updated Rev1.1 Aug 15 2016).
This shield can be used with or without HydraBus board, you can even cut HydraBus specific right side (on the line) to have a tiny ESP-WROOM-32 breakout board.
  • This shield can be used on top or bottom of HydraBus board (you just need to solder ESP-WROOM-32 on top or bottom of the shield)
  • The HydraBus board is a small (60mm x 37mm) and low cost, multi-tool extensible board with STM32F405 Cortex M4F 32bits MCU @168MHz with a fully open source firmware hydrafwand full online documentation hydrafw wiki
  • The ESP-WROOM-32 is a low-power 32-bit 240 MHz dual core MCU Wi- Fi+BLE combo module that highly integrates TCP/IP network stacks, 12- bit ADC and HSPI/SDIO/UART/PWM/I2C/I2S interfaces. See ESP-WROOM-32 link/info, Espressif Products Overview including ESP-WROOM-32 PDF
Design based on official esp_wroom_32_datasheet_en.pdf (August 8, 2016)
For more details see https://oshpark.com/shared_projects/6t5hURXL
Users browsing this forum: Google [Bot] and 5 guests
