OOP in ESP-WROOM-32
redplane
OOP in ESP-WROOM-32
Postby redplane » Sun Oct 11, 2020 6:00 pm
I'm using ESP32 for my personal project.
Currently, I'm making a WIFI manager using a class to scan & save the scanned WIFI network then display the network list on the TFT Screen with pagination (4 items per page).
I'm using a class WirelessNetworkManager to store the scanned network & use them later.
This is my code:
#include "../.pio/libdeps/esp32dev/LinkedList/LinkedList.h"
#include "WirelessNetwork.h"
class WirelessNetworkManager {
private:
    // Available networks that have been searched.
    LinkedList<WirelessNetwork> _availableNetworks;
    // Network which have been selected.
    WirelessNetwork *_selectedNetwork;
    // The last time when networks are scanned.
    float _lastScanTime;
    // Id of network which item will be retrieved previously.
    int _previousPageId;
    // Id of network from which item will be retrieved
    int _pageId;
public:
    WirelessNetworkManager();
    // Get list of available networks.
    LinkedList<WirelessNetwork> *getAvailableNetworks();
    // Get list of wireless networks by using page id & maximum records per page.
    LinkedList<WirelessNetwork> *getAvailableNetworks(int pageId, int maxRecords);
    // Get the id of page.
    int getPageId() const;
    // Get the selected network.
    WirelessNetwork *getSelectedNetwork();
    // Select wireless network by specifying its index.
    void selectWirelessNetwork(int index);
    // Disconnect to from the connect network (if any)
    static void disconnect() ;
    // Mark page to be loaded.
    void markPageLoaded();
    // Whether network records must be updated.
    bool shouldRecordsRefreshed() const;
    // Go to next network page
    void goForward();
    // Go to previous network page
    void goBackward();
#include <WirelessNetworkManager.h>
#include <WiFi.h>
//#region Constructor
WirelessNetworkManager::WirelessNetworkManager() {
    this->_lastScanTime = -1.0f;
    this->_selectedNetwork = nullptr;
    this->_availableNetworks = LinkedList<WirelessNetwork>();
    this->_pageId = 0;
    this->_previousPageId = -1;
//#endregion
//#region Methods
LinkedList<WirelessNetwork> *WirelessNetworkManager::getAvailableNetworks() {
    LinkedList<WirelessNetwork> *allNetworks = nullptr;
    // Clear the previous loaded network.
    this->_availableNetworks.clear();
    this->_pageId = 0;
    // Clear the selected network.
    // WiFi.scanNetworks will return the number of networks found
    int iDiscoveredNetworks = WiFi.scanNetworks();
    delay(20);
    // No network is discovered.
    if (iDiscoveredNetworks == 0) {
        return &this->_availableNetworks;
    LinkedList<WirelessNetwork> availableNetworks;
    for (int iNetworkIndex = 0; iNetworkIndex < iDiscoveredNetworks; iNetworkIndex++) {
        String ssid(WiFi.SSID(iNetworkIndex));
        char iSignalStrength = WiFi.RSSI(iNetworkIndex);
        bool bIsProtected = WiFi.encryptionType(iNetworkIndex) != WIFI_AUTH_OPEN;
        // Enlist the available networks.
        WirelessNetwork availableNetwork = WirelessNetwork(ssid.c_str(), iSignalStrength, bIsProtected);
        availableNetworks.add(availableNetwork);
    this->_availableNetworks = availableNetworks;
    allNetworks = &this->_availableNetworks;
    return allNetworks;
LinkedList<WirelessNetwork> *WirelessNetworkManager::getAvailableNetworks(int pageId, int maxRecords) {
    if (this->_availableNetworks.size() < 1) {
        return new LinkedList<WirelessNetwork>();
    // Update the page id.
    this->_pageId = pageId;
    // Get the records which must be skipped.
    int skippedRecords = this->_pageId * maxRecords;
    int endRecordId = skippedRecords + maxRecords;
    if (endRecordId > this->_availableNetworks.size()) {
        endRecordId = this->_availableNetworks.size();
    LinkedList<WirelessNetwork> *availableNetworks = new LinkedList<WirelessNetwork>();
    Serial.print("Items = ");
    Serial.println(this->_availableNetworks.size());
    Serial.print("Skipped records = ");
    Serial.println(skippedRecords);
    Serial.print("End records = ");
    Serial.println(endRecordId);
    for (int i = skippedRecords; i < endRecordId; i++) {
        Serial.print("Id ");
        Serial.println(i);
        char szItemTitle[128] = "";
        char szValue[10] = "";
        char szNetworkName[128] = "";
        const bool bIsProtected = this->_availableNetworks.get(i).getProtected();
        strcat(szItemTitle, " ");
        strcpy(szNetworkName, this->_availableNetworks.get(i).getName());
        strcat(szItemTitle, szNetworkName);
        strcat(szItemTitle, !bIsProtected ? " " : "*");
        Serial.print("Drawn network = ");
        Serial.println(szItemTitle);
        WirelessNetwork availableNetwork(this->_availableNetworks.get(i));
        availableNetworks->add(availableNetwork);
    return availableNetworks;
int WirelessNetworkManager::getPageId() const {
    return this->_pageId;
WirelessNetwork *WirelessNetworkManager::getSelectedNetwork() {
    return this->_selectedNetwork;
void WirelessNetworkManager::selectWirelessNetwork(int index) {
    if (index < 0 || index > this->_availableNetworks.size() - 1) {
        return;
    WirelessNetwork selectedNetwork = this->_availableNetworks.get(index);
    this->_selectedNetwork = &selectedNetwork;
void WirelessNetworkManager::disconnect() {
    WiFi.disconnect();
void WirelessNetworkManager::markPageLoaded() {
    this->_previousPageId = this->_pageId;
bool WirelessNetworkManager::shouldRecordsRefreshed() const {
    return this->_pageId != this->_previousPageId;
void WirelessNetworkManager::goForward() {
    // TODO: Check if page can be gone forward or not.
    this->_pageId++;
void WirelessNetworkManager::goBackward() {
    // TODO: Check if page can be gone backward or not.
    if (this->_pageId < 2) {
        return;
    this->_pageId--;
//#endregion
And here is my main file:
    // Open serial connection.
    Serial.begin(115000);
    nexInit();
    // Set WiFi to station mode and disconnect from an AP if it was previously connected
    WiFi.mode(WIFI_STA);
    WiFi.disconnect();
    // Screen activation callback.
    m_SplashScreen.attachPop(OnSplashScreenActivated);
    m_MainView.attachPop(OnMainViewActivated);
    m_NetworkView.attachPop(OnNetworkViewActivated);
    m_WifiPasswordView.attachPop(OnWifiPasswordViewActivated);
    String message;
    // Run loop
    nexLoop(m_WatchedControls);
    // In network page.
    if (m_iActivatedScreen == NETWORK_VIEW_ID) {
        int iMaxNetworkItems = sizeof(m_NetworkItems) / sizeof(m_NetworkItems[0]);
        int iMaxNetworkIcons = sizeof(m_NetworkIconItems) / sizeof(m_NetworkIconItems[0]);
        // Networks must be loaded.
        if (m_bMustLoadWifiNetworks) {
            // Display loading message.
            m_NetworkLoadingMessage.setText(MSG_SEARCHING_WIFI);
            m_NetworkLoadingMessage.setVisible(true);
            // Hide network item & icon.
            for (int iNetworkIndex = 0; iNetworkIndex < iMaxNetworkItems; iNetworkIndex++) {
                m_NetworkItems[iNetworkIndex]->setVisible(false);
                m_NetworkIconItems[iNetworkIndex]->setVisible(false);
            m_bMustLoadWifiNetworks = false;
            m_NetworkProcessStatus = NETWORK_STATUS_LOADING;
            // Scan for available networks.
            LinkedList<WirelessNetwork> *availableNetworks = m_WirelessNetworkManager->getAvailableNetworks();
            if (availableNetworks->size() < 1) {
                m_NetworkProcessStatus = NETWORK_STATUS_LOADED;
                m_NetworkLoadingMessage.setText(MSG_NO_WIFI);
                return;
            for (int i = 0; i < availableNetworks->size(); i++) {
                const bool bIsProtected = availableNetworks->get(i).getProtected();
                strcat(szNetworkName, availableNetworks->get(i).getName());
            if (availableNetworks->size() > 0)
                m_NetworkLoadingMessage.setVisible(false);
            else
        // Wifi already loaded.
        if (m_NetworkProcessStatus == NETWORK_STATUS_LOADED && m_WirelessNetworkManager->shouldRecordsRefreshed()) {
            int pageId = m_WirelessNetworkManager->getPageId();
            // Get the available networks which have been paginated.
            LinkedList<WirelessNetwork> *paginatedNetworks = m_WirelessNetworkManager->getAvailableNetworks(pageId, m_iMaxNetworkPageItems);
            for (int iNetworkIndex = 0; iNetworkIndex < paginatedNetworks->size(); iNetworkIndex++) {
                // Get the available network.
                WirelessNetwork availableNetwork = paginatedNetworks->get(iNetworkIndex);
                const bool bIsProtected = availableNetwork.getProtected();
                strcat(szNetworkName, availableNetwork.getName());
                m_NetworkItems[iNetworkIndex]->setText(szItemTitle);
                m_NetworkItems[iNetworkIndex]->setVisible(true);
                m_NetworkIconItems[iNetworkIndex]->setVisible(true);
            // Free allocated memory.
            delete paginatedNetworks;
            m_WirelessNetworkManager->markPageLoaded();
When I run the application and scan for network page. This is what I saw on Serial Monitor:
AH-6 Overwatch*
PHUONG THAO*
Tuta 518*
VIETTEL-E450*
Items = 8
Skipped records = 0
End records = 4
Id 0
Drawn network =  AH-6 Overwatch*
Id 1
Id 2
Id 3
Every time the first WIFI is returned, even I already stored the scanned list inside WirelessNetworkManager. Am I doing anything wrong ?
Thank you,
