Use FTDI bridge device to program esp32
Duhjoker
Postby Duhjoker » Fri Apr 28, 2017 10:48 pm
Hi guys
I accidentally knocked the Micro USB port off from the board. I see that the board has UART pins. Can an FTDI or other bridge device be used to program an esp32 board? Is there an example of this?
Fear is the mind killer.......
GameR the DIY iot gaming device that does more......
https://github.com/Duhjoker/GameR-Iot_ESP
WiFive
Re: Use FTDI bridge device to program esp32
Postby WiFive » Fri Apr 28, 2017 11:05 pm
Duhjoker
Postby Duhjoker » Sat Apr 29, 2017 12:44 am
Awesome thank you!!!!
Duhjoker
Postby Duhjoker » Tue May 02, 2017 9:29 am
Ok so i have an uart cp2102 programmer. I see that the board has uart pins buy can it be programmed by a uart bridge device as well?
WiFive
Postby WiFive » Tue May 02, 2017 10:44 am
What's the difference between a cp2102 on the same board and on a different board? Nothing if you hook it up the same way. The only consideration is whether you have to use the buttons to get into download mode and if the inactive cp2102 on the board will hold any signal lines (probably not). Check the devkitc schematic.
