Micro usb power supply esp32 cam
Daveyman123
Postby Daveyman123 » Mon Oct 26, 2020 10:24 pm
Why would powering the 5v pin with a wall plug in 5v micro usb not work? In other words I have plugged in 5v from the wall and it doesn’t work correctly.
Spile2
Re: Micro usb power supply esp32 cam
Postby Spile2 » Tue Oct 27, 2020 11:41 am
I assume that when using the external power supply
1) You do not have a USB connection?
2) Your eternal supply can supply enough current to the ESP-32? I would allow for 0.8A
Ref:
viewtopic.php?f=2&t=2662
Daveyman123
Postby Daveyman123 » Tue Oct 27, 2020 12:10 pm
Thank you for the reply Spile,
Two things might be the issue. My power supply is rated 2.5 amps
Also
The power supply is just sitting on the breadboard. No soldering
Whenever I plug another power supply into the usb breakout I get different output. One is almost nothing and the other streaming gibberish.
I think I will buy a soldering iron today ;)
Daveyman123
Postby Daveyman123 » Tue Oct 27, 2020 12:11 pm
Here are a couple pictures of my setup
Daveyman123
Postby Daveyman123 » Tue Oct 27, 2020 12:13 pm
Daveyman123
Postby Daveyman123 » Tue Oct 27, 2020 5:57 pm
I guess I need to get a soldering iron and solder the breakout board. I'm 99% sure thats the problem
was wanting to go for a cheap option but I am fine with this :)
Users browsing this forum: PerplexityBot and 3 guests
