Hi! I'm looking for this:
https://github.com/espressif/arduino-es ... OTA_Update
But I have a question:
Is it a good solution? I read the previously solution and it was stable.
The previously solution:
https://github.com/suculent/esp32-http-update
Thanks!
HTTPS UPDATES
Re: HTTPS UPDATES
Hi! Thank's u for the answer. I have the next context:
I will create an interface in which I can program a ESP32 around the world using my own web server (business) like a P2P.
The steps will be the next:
1- The client connect the esp32 in a local server (for example) in Spain.
2- I charge an update into my server.
3-The client clicks "update" button.
4-The esp32 generate a petition to the "version" page.
5-If the version is different from the current one then it goes to step 6 else, it shows an message like "Your device is alredy update".
6-The esp32 generate a petition at .bin file direction.
7-The esp32 restarts and when the client connect again with your device, the esp32 shows "the controller is now update to the XX version".
Hi! I'm a PCB designer and a Uc programmer from Argentinia.
