platformIO编译ESP32-CAM-AI-THINKER例程时提示错误:
[0;31mE (1255) memory_layout: SOC_RESERVE_MEMORY_REGION region range 0x3f800000 - 0x40000000 overlaps with 0x3ffae000 - 0x3ffae6e0[0m
abort() was called at PC 0x400e67b3 on core 0
8月份编译时还可以正常使用,怀疑是升级官方库造成的,但是没找到准确原因。
完整启动信息如下:
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0030,len:4
load:0x3fff0034,len:7308
load:0x40078000,len:13856
load:0x40080400,len:4052
entry 0x40080688
[0;32mI (29) boot: ESP-IDF 3.40100.200827 2nd stage bootloader[0m
[0;32mI (29) boot: compile time 23:25:21[0m
[0;32mI (29) boot: chip revision: 1[0m
[0;32mI (33) boot_comm: chip revision: 1, min. bootloader chip revision: 0[0m
[0;32mI (40) boot.esp32: SPI Speed : 40MHz[0m
[0;32mI (44) boot.esp32: SPI Mode : DIO[0m
[0;32mI (49) boot.esp32: SPI Flash Size : 4MB[0m
[0;32mI (53) boot: Enabling RNG early entropy source...[0m
[0;32mI (59) boot: Partition Table:[0m
[0;32mI (62) boot: ## Label Usage Type ST Offset Length[0m
[0;32mI (70) boot: 0 nvs WiFi data 01 02 00009000 00006000[0m
[0;32mI (77) boot: 1 phy_init RF data 01 01 0000f000 00001000[0m
[0;32mI (85) boot: 2 factory factory app 00 00 00010000 00100000[0m
[0;32mI (92) boot: End of partition table[0m
[0;32mI (96) boot_comm: chip revision: 1, min. application chip revision: 0[0m
[0;32mI (103) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x12128 ( 74024) map[0m
[0;32mI (144) esp_image: segment 1: paddr=0x00022150 vaddr=0x3ffb0000 size=0x026c8 ( 9928) load[0m
[0;32mI (149) esp_image: segment 2: paddr=0x00024820 vaddr=0x40080000 size=0x00404 ( 1028) load[0m
[0;32mI (152) esp_image: segment 3: paddr=0x00024c2c vaddr=0x40080404 size=0x0b3ec ( 46060) load[0m
[0;32mI (182) esp_image: segment 4: paddr=0x00030020 vaddr=0x400d0020 size=0x310bc (200892) map[0m
[0;32mI (270) esp_image: segment 5: paddr=0x000610e4 vaddr=0x4008b7f0 size=0x09318 ( 37656) load[0m
[0;32mI (300) boot: Loaded app from partition at offset 0x10000[0m
[0;32mI (300) boot: Disabling RNG early entropy source...[0m
[0;32mI (300) psram: This chip is ESP32-D0WD[0m
[0;32mI (306) spiram: Found 64MBit SPI RAM device[0m
[0;32mI (310) spiram: SPI RAM mode: flash 40m sram 40m[0m
[0;32mI (315) spiram: PSRAM initialized, cache is in low/high (2-core) mode.[0m
[0;32mI (322) cpu_start: Pro cpu up.[0m
[0;32mI (326) cpu_start: Application information:[0m
[0;32mI (331) cpu_start: Project name: esp32_cam_sd_jpg[0m
[0;32mI (336) cpu_start: App version: 1[0m
[0;32mI (341) cpu_start: Compile time: Nov 18 2020 23:23:24[0m
[0;32mI (347) cpu_start: ELF file SHA256: a70f3ca105ebfd05...[0m
[0;32mI (353) cpu_start: ESP-IDF: 3.40100.200827[0m
[0;32mI (358) cpu_start: Starting app cpu, entry point is 0x40082a74[0m
[0;32mI (0) cpu_start: App cpu up.[0m
[0;32mI (1250) spiram: SPI SRAM memory test OK[0m
D (1250) memory_layout: Checking 8 reserved memory ranges:[0m
D (1250) memory_layout: Reserved memory range 0x3f800000 - 0x40000000[0m
Backtrace: 0x4008b384:0x3ffe34a0 0x4008b838:0x3ffe34d0 0x400e67b3:0x3ffe3500 0x400e6858:0x3ffe3540 0x400e582d:0x3ffe3890 0x40082cd1:0x3ffe3c40 0x4007931a:0x3ffe3c80 |<-CORRUPTED
Rebooting...
platformIO编译ESP32-CAM-AI-THINKER提示memory_layout overlay错误
firemountain
