How to switch between wifi AP mode and STA mode correctly?
rong.tsai
Postby rong.tsai » Tue Dec 01, 2020 6:55 am
Hi All
I am new, I have a project that it require to switch between WiFi AP mode and WiFi STA mode (Not AP_STA mode), However, in my implementation, I always get system panic problem when I try to restart wifi to STA mode from AP mode or AP mode from STA mode,
so I want to ask where I get wrong. Below is my code section,
Test code section in main function:
 while (1){
            wifi_ap_start("APPPPP", "1234567890");
            ESP_LOGI(MAIN_TAG, "ap started");
            vTaskDelay(pdMS_TO_TICKS(10000));
            wifi_ap_sta_stop();
            ESP_LOGI(MAIN_TAG, "ap stopped");
            vTaskDelay(pdMS_TO_TICKS(1000));
            wifi_sta_start();
            ESP_LOGI(MAIN_TAG, "sta started");
            wifi_ap_sta_stop();
            ESP_LOGI(MAIN_TAG, "sta stopped");
static WiFiStatus_t wifi_ap_sta_init(uint8_t mode)
    if(NULL == g_wifi_internal_event_group)
        g_wifi_internal_event_group = xEventGroupCreate();
    ESP_LOGI(WIFI_IFACE_TAG, "esp_netif_init");
    if(WIFI_STA_MODE == mode) {
       g_wifi_netif = esp_netif_create_default_wifi_sta();
    ESP_LOGI(WIFI_IFACE_TAG, "esp_netif_create_default_wifi_sta");
       g_wifi_netif = esp_netif_create_default_wifi_ap();
    ESP_LOGI(WIFI_IFACE_TAG, "esp_netif_create_default_wifi_ap");
    ESP_LOGI(WIFI_IFACE_TAG, "esp_wifi_init");
    ESP_ERROR_CHECK(esp_event_handler_register(WIFI_EVENT, ESP_EVENT_ANY_ID, &wifi_event_handler, NULL));
    ESP_LOGI(WIFI_IFACE_TAG, "wifi_ap_sta_init ok");
    return WIFI_STATUS_OK;
static WiFiStatus_t wifi_ap_sta_stop(void)
    if(NULL == g_wifi_netif)
    esp_event_handler_unregister(WIFI_EVENT, ESP_EVENT_ANY_ID, &wifi_event_handler);
    wifi_mode_t current_mode;
    esp_wifi_get_mode(&current_mode);
    if(WIFI_MODE_AP == current_mode) {
        esp_wifi_deauth_sta(0);
    } else if(WIFI_MODE_STA == current_mode) {
        esp_event_handler_unregister(IP_EVENT, IP_EVENT_STA_GOT_IP, &wifi_event_handler);
        wifi_sta_disconnect();
    vEventGroupDelete(g_wifi_internal_event_group);
    if(ESP_ERR_WIFI_NOT_INIT != esp_wifi_stop())
        esp_wifi_deinit();
    esp_netif_destroy(g_wifi_netif);
    esp_wifi_clear_default_wifi_driver_and_handlers(g_wifi_netif);
    g_wifi_netif = NULL;
    ESP_LOGI(WIFI_IFACE_TAG, "wifi stop");
static WiFiStatus_t wifi_ap_start(char* ssid, char* pwd)
    if(g_wifi_netif)
        return WIFI_STATUS_FAIL;
    wifi_ap_sta_init(WIFI_AP_MODE);
    wifi_config_t wifi_config = {
        .ap = {
            .max_connection = 1,
            .authmode = WIFI_AUTH_WPA2_PSK
    wifi_config.ap.ssid_len = strlen(ssid);
    memcpy(wifi_config.ap.ssid, ssid, strlen(ssid));
    memcpy(wifi_config.ap.password, pwd, strlen(pwd));
    esp_wifi_set_mode(WIFI_MODE_AP);
    esp_wifi_set_config(ESP_IF_WIFI_AP, &wifi_config);
    esp_wifi_start();
    EventBits_t bits = xEventGroupWaitBits(g_wifi_internal_event_group,
            WIFI_START_BIT,
            pdTRUE,
            pdFALSE,
    if (bits & WIFI_START_BIT) {
    wifi_ap_sta_stop();
static WiFiStatus_t wifi_sta_start(void)
    if(g_wifi_netif)
    wifi_ap_sta_init(WIFI_STA_MODE);
    esp_event_handler_register(IP_EVENT, IP_EVENT_STA_GOT_IP, &wifi_event_handler, NULL);
        .sta = {
            .threshold.authmode = WIFI_AUTH_WPA2_PSK,
            .pmf_cfg = {
                .capable = true,
                .required = false
    esp_wifi_set_mode(WIFI_MODE_STA);
    esp_wifi_set_config(ESP_IF_WIFI_STA, &wifi_config);
    esp_wifi_start();
            WIFI_START_BIT,
            pdTRUE,
            pdFALSE,
        ESP_LOGI(WIFI_IFACE_TAG, "sta start");
    wifi_ap_sta_stop();
In this code, do I get some problem in start and stop function? because I actually refer from esp-idf example code(wifi/station, wifi/ap). If somebody can help me, it will be thx so much!!
canada_eh
Re: How to switch between wifi AP mode and STA mode correctly?
Postby canada_eh » Tue Oct 12, 2021 2:59 pm
Looks like this answers:
viewtopic.php?t=22486
