spi driver, spi_get_trans_result stuck
veelox
Postby veelox » Fri Dec 04, 2020 7:08 pm
I am trying to write an SPI driver for my project, but cant seems to work. I've tried to use spi_device_transmit, spi_device_polling_transmit, queue_trans, get_trans but i never seem to be able to get it working. I've tried multiple different bus and device config. But it is always stuck, waiting for the slave device to answer.
Code: Untitled.cpp Select all
void initializeSPI(void)
esp_err_t err;
spi_bus_config_t buscfg;
buscfg.miso_io_num=19;
buscfg.mosi_io_num=23;
buscfg.sclk_io_num=18;
buscfg.quadwp_io_num=-1;
buscfg.quadhd_io_num=-1;
buscfg.max_transfer_sz=4094;
err=spi_bus_initialize(SPI3_HOST, &buscfg, 1); //return ESP_OK
printf("spi initialize err : %s\r\n", esp_err_to_name(err));
// SPI
#define SPI_MAX_CS 34 // GPIO 33 is the last port that can be used as output
#define BUFFER_SIZE 200
spi_device_handle_t spi[SPI_MAX_CS] = { 0 };
uint8_t _csPin_ = 21;
ICM_20948_SPI::ICM_20948_SPI()
ICM_20948_Status_e ICM_20948_SPI::begin(uint8_t csPin, uint32_t SPIFreq)
esp_err_t err;
spi_device_interface_config_t devcfg;
devcfg.clock_speed_hz=SPIFreq;
devcfg.mode=ICM_20948_SPI_DEFAULT_MODE;
devcfg.spics_io_num=_csPin_;
devcfg.queue_size=1;
devcfg.flags = 0;
devcfg.command_bits = 0; // no command bits used
devcfg.address_bits = 0; // register address is first byte in MOSI
devcfg.dummy_bits = 0; // no dummy bits used
devcfg.pre_cb =NULL;
devcfg.post_cb=NULL;
spi[_csPin_] = (spi_device_handle_t)malloc(sizeof(spi_device_handle_t));
err=spi_bus_add_device(SPI3_HOST, &devcfg, &spi[_csPin_]); // return ESP_OK
printf("icm 20948 add device err : %s\r\n", esp_err_to_name(err));
if (err != ESP_OK) free (spi[_csPin_]);
// Set up the serif
_serif.write = ICM_20948_write_SPI;
_serif.read = ICM_20948_read_SPI;
_serif.user = (void *)this; // refer to yourself in the user field
// Link the serif
_device._serif = &_serif;
// Perform default startup
status = startupDefault();
if (status != ICM_20948_Stat_Ok)
return status;
return ICM_20948_Stat_Ok;
ICM_20948_Status_e ICM_20948_write_SPI(uint8_t reg, uint8_t *data, uint32_t len, void *user)
static uint8_t mosi[BUFFER_SIZE];
mosi[0] = reg;
for (int i = 0; i < len; i++)
mosi[i+1] = data[i];
if (!spi_transfer_pf (mosi, NULL, len+1))
return ICM_20948_Stat_Err;
ICM_20948_Status_e ICM_20948_read_SPI(uint8_t reg, uint8_t *buff, uint32_t len, void *user)
if (user == NULL)
return ICM_20948_Stat_ParamErr;
static uint8_t miso[BUFFER_SIZE];
memset (mosi, 0xff, BUFFER_SIZE);
memset (miso, 0xff, BUFFER_SIZE);
mosi[0] = reg;
if (!spi_transfer_pf (mosi, miso, len+1))
for (int i=0; i < len; i++)
buff[i] = miso[i+1];
uint32_t spi_transfer_pf (const uint8_t *mosi, uint8_t *miso, uint32_t len)
spi_transaction_t spi_trans;
memset(&spi_trans, 0, sizeof(spi_trans)); // zero out spi_trans;
spi_trans.tx_buffer = mosi;
spi_trans.rx_buffer = miso;
spi_trans.length=len*8;
spi_trans.user=(void*)0;
// Stuck in here
if (spi_device_transmit(spi[_csPin_], &spi_trans) != ESP_OK) //spi_device_polling_transmit trigger watchdog
printf("spi device transmit != ESP_OK\r\n");
return 0;
printf("spi device transmit = ESP_OK\r\n");
return len;
The spi_device_transmit seems alive since it does not trigger my thread watchdog. Inside the function, spi_device_queue_trans return ESP_OK, it is stuck inside spi_get_trans_result.
Re: spi driver, spi_get_trans_result stuck
Postby Sprite » Sat Dec 05, 2020 2:57 am
One thing that might affect your setup: make sure to zero-initialize your config structs. Even if your current setup might not have any issues, uninitialized members can break your code later on. E.g.
spi_device_interface_config_t devcfg={};
will work.
veelox
Postby veelox » Sat Dec 05, 2020 3:11 pm
Well yes its working, thank you!!
Users browsing this forum: meta-externalagent and 1 guest
