Compile C++14 and newer.
Viktor
Postby Viktor » Thu Dec 10, 2020 7:04 am
Hi.
I assume that it's possible to build with different compiler options. I see that my code is compiled with -std=gnu++11 by default.
I found some comments about changing c++ version: https://github.com/espressif/esp-idf/is ... -423867023
But both
CFLAGS += -std=c++14
and
component_compile_options(-std=c++14)
don't work in my case, I think. I still see -std=gnu++11 in ESP-IDF command prompt during compilation before component filenames and errors in that files.
What's wrong with my configuration?
ESP-IDF v4.1. ESP32 project.
Jan
Re: Compile C++14 and newer.
Postby Jan » Sun Dec 13, 2020 2:07 pm
Hi Viktor,
take a look at https://docs.espressif.com/projects/esp ... ompilation
This describes how to apply compilation flags to specific source files.
Please note that compiling ESP-IDF using different compile flags may not be supported. However you can compile only your code using those flags.
Feel free to post any follow-up questions.
Users browsing this forum: Baidu [Spider], DuckDuckGo [Bot], Google [Bot], trendictionbot and 7 guests
