ESP32-S2 build problems
MarkusR
Postby MarkusR » Fri Dec 11, 2020 2:51 am
I tried to follow the steps for setting up the esp32-s2 toolchain for the esp32-s2-wroom module however it doesn't really work.
I'm following those steps:
https://docs.espressif.com/projects/esp ... -configure
$ cd /Users/markus/devel/esp32/esp-idf/examples/get-started/blink
$ idf.py set-target esp32s2
$ idf.py menuconfig
sdkconfig shows up:
CONFIG_IDF_CMAKE=y
CONFIG_IDF_TARGET_ARCH_XTENSA=y
CONFIG_IDF_TARGET="esp32s2"
CONFIG_IDF_TARGET_ESP32S2=y
CONFIG_IDF_FIRMWARE_CHIP_ID=0x0002
$ make
make
Python requirements from /Users/markus/devel/esp32/esp-idf/requirements.txt are satisfied.
GENCONFIG
Loading defaults file /Users/markus/devel/esp32/esp-idf/examples/get-started/blink/sdkconfig.defaults...
App "blink" version: v4.3-dev-1901-g178b122c1
Building partitions from /Users/markus/devel/esp32/esp-idf/components/partition_table/partitions_singleapp.csv...
CC build/bootloader/esp_hw_support/compare_set.o
/Users/markus/devel/esp32/esp-idf/components/esp_hw_support/include/soc/compare_set.h: Assembler messages:
/Users/markus/devel/esp32/esp-idf/components/esp_hw_support/include/soc/compare_set.h:33: Error: invalid register 'SCOMPARE1' for 'wsr' instruction
/Users/markus/devel/esp32/esp-idf/components/esp_hw_support/include/soc/compare_set.h:34: Error: unknown opcode or format name 's32c1i'
make[2]: *** [compare_set.o] Error 1
make[1]: *** [component-esp_hw_support-build] Error 2
make: *** [/Users/markus/devel/esp32/esp-idf/examples/get-started/blink/build/bootloader/bootloader.bin] Error 2
Any idea what I can do next?
Angus
Re: ESP32-S2 build problems
Postby Angus » Fri Dec 11, 2020 3:22 am
Hi Markus,
The ESP-IDF "GNU Make" build system doesn't support ESP32-S2, unfortunately. Try using "idf.py build" to build, instead of "make".
(It is possible to run CMake with arguments to then run "make" as the build step for ESP32-S2, but "idf.py build" takes care of this part automatically.)
Angus
MarkusR
Postby MarkusR » Fri Dec 11, 2020 3:42 am
I just figured that out 10 minutes ago .. yes it needs idf.py build it fixed the problem
thanks for your quick reply!
Users browsing this forum: ChatGPT-User, Google [Bot], PetalBot and 5 guests
