Hello everyone,
I'm working with a custom PCB based on the u-blox NINA 101.
This module uses a 2MB flash, and my PCB also comes with an extra 16MB flash(W25Q128).
The problem is that in order to the NINA module to work I need to set CONFIG_SPI_FLASH_USE_LEGACY_IMPL, otherwhise the system fails to read the chip size and the esp crashes. If I set CONFIG_SPI_FLASH_USE_LEGACY_IMPL to true I lost some useful API that I would like to use for the extra 16MB flash.
How can I bypass this error? I saw similar issues on github but I was not able to correct the issue.
Thank's a lot,
Gabriel Gardin
Failed to get chip size NINA101
Re: Failed to get chip size NINA101
So, I still have the error but I was able to make make it works by altering the file esp_flash_spi_init.c
I just ignore the error:
Although it's working this is going to ignore any other errors that might happened, so it's not a truly solution.
esp_err_t esp_flash_init_default_chip(void)
memspi_host_config_t cfg = ESP_FLASH_HOST_CONFIG_DEFAULT();
//the host is already initialized, only do init for the data and load it to the host
spi_flash_hal_init(&default_driver_data, &cfg);
default_chip.host->driver_data = &default_driver_data;
// ROM TODO: account for non-standard default pins in efuse
// ROM TODO: to account for chips which are slow to power on, maybe keep probing in a loop here
esp_err_t err = esp_flash_init(&default_chip);
if (err != ESP_OK) {
//return err;
default_chip.size = g_rom_flashchip.chip_size; //Here is the "workaround"
if (default_chip.size < g_rom_flashchip.chip_size) {
ESP_EARLY_LOGE(TAG, "Detected size(%dk) smaller than the size in the binary image header(%dk). Probe failed.", default_chip.size/1024, g_rom_flashchip.chip_size/1024);
return ESP_ERR_FLASH_SIZE_NOT_MATCH;
} else if (default_chip.size > g_rom_flashchip.chip_size) {
ESP_EARLY_LOGW(TAG, "Detected size(%dk) larger than the size in the binary image header(%dk). Using the size in the binary image header.", default_chip.size/1024, g_rom_flashchip.chip_size/1024);
esp_flash_default_chip = &default_chip;
return ESP_OK;
}Who is online
Users browsing this forum: Bing [Bot], Google [Bot], PerplexityBot and 7 guests
