NVS issue, unable read stored data from NVS
masadf22
Postby masadf22 » Thu Dec 17, 2020 1:45 pm
Hi, I am able to write successfully but when I read from NVS it throws an error of "Error (ESP_ERR_NVS_INVALID_LENGTH) reading!"
[Codebox=c file=Untitled.c]void set_nvs_string(char* data, char* key)
	nvs_handle my_handle;
	esp_err_t err = nvs_open("storage", NVS_READWRITE, &my_handle);
	if (err != ESP_OK) {
		printf("Error (%s) opening NVS handle!\n", esp_err_to_name(err));
	err = nvs_set_str(my_handle, key, data);
	printf((err != ESP_OK) ? "Failed! Setting String from NVS\n" : "Done Setting String from NVS\n");
	printf("Committing updates in NVS ... ");
	err = nvs_commit(my_handle);
	printf((err != ESP_OK) ? "Failed! Commiting\n" : "Done Commiting\n");
esp_err_t get_nvs_string(char* key, char* data)
	size_t size = strlen(data);
	err = nvs_get_str(my_handle, key, data, &size);
	switch (err)
	case ESP_OK:
		printf("Done Getting String from NVS\n");
	case ESP_ERR_NVS_NOT_FOUND:
		printf("The value is not initialized yet!\n");
	default :
		printf("Error (%s) reading!\n", esp_err_to_name(err));
	return err;
ESP_LOGI(TAG_ap, "SSID Local: %s  PASSWORD Local: %s Inverter ID %s", ssidLocal, passwordLocal, InverterId);
	set_nvs_string(InverterId, "InverterId");
	if (strlen(ssidLocal) != 0 && strlen(passwordLocal) != 0)
		set_nvs_string(ssidLocal, "ssid");
		set_nvs_string(passwordLocal, "password");
		wifi_config_t wifi_config;
		char* tempSsid = malloc(sizeof(char) * 32);
		char* tempPassword = malloc(sizeof(char) * 64);
		get_nvs_string("ssid", tempSsid);
		get_nvs_string("password", tempPassword);
		strcpy((char*)wifi_config.sta.ssid, tempSsid);
		strcpy((char*)wifi_config.sta.password, tempPassword);
		ESP_LOGI("WIFI CHECK4", "Set SSID: %s", (char*)wifi_config.sta.ssid);
		ESP_LOGI("WIFI CHECK4", "Set Password: %s", (char*)wifi_config.sta.password);
		free(tempSsid);
		free(tempPassword);
		ESP_LOGI(TAG_ap, "=========== PARSED DATA ==========");
		ESP_LOGI(TAG_ap, "SSID: %s  PASSWORD: %s", wifi_config.sta.ssid, wifi_config.sta.password);
		ESP_LOGI(TAG_ap, "====================================");
		ESP_ERROR_CHECK(esp_wifi_stop());
		wifi_init_sta();
		s_retry_num = 0;
	}[/Codebox]
Output:
Code: Untitled.txt Select all
I (146517) Hojaa Pls: SSID Local: ZongAltium1  PASSWORD Local: Xavor123 Inverter ID Schneider
Committing updates in NVS ... Done Commiting
I (146557) wifi: station: 9e:62:e3:2e:66:f5 leave, AID = 1, bss_flags is 134243
I (146567) WIFI CHECK4: Set SSID: ZongAltium1
I (146567) wifi: n:1 0, o:1 0, ap:1 1, sta:0 0, prof:1
I (146567) WIFI CHECK4: Set Password: ???
I (146577) Hojaa Pls: =========== PARSED DATA ==========
I (146587) Hojaa Pls: SSID: ZongAltium1 PASSWORD: ???
I (146587) Hojaa Pls: ====================================
I (146637) wifi: flush txq
I (146637) wifi: stop sw txq
I (146637) wifi: lmac stop hw txq
[/color][/color]
dkaufmann
Re: NVS issue, unable read stored data from NVS
Postby dkaufmann » Wed Jun 29, 2022 6:37 am
Hello. I had a very similar problem. In my case the initialization of the size was wrong
You could try:
size_t size = strlen(data)+1;
best regards
Dominik
igrr
Postby igrr » Wed Jun 29, 2022 1:48 pm
Indeed, this part of the code leads to the issue:
The last argument of nvs_get_str has the following meaning (see docs):
  • as an input, it should contain the amount of space (number of bytes) available in "out_value" pointer.
  • as an output, if "out_value" is not NULL, it will be filled with the actual number of bytes written into "out_value", including the NULL terminator
So the code should look like this:
// 1. add "out_data_size" argument to tell this function how much space is available in "out_data".
// 2. Also make "key" const, since it is not modified by this function.
esp_err_t get_nvs_string(const char* key, char* data, size_t data_size)
	// 3. as input, "size" should contain the amount of space available
	size_t size = out_data_size;
	// 4. after this call, if err == ESP_OK, "size" will contain the number of bytes written into "data"
Then the caller of this function should pass the "data_size" value based on the size of the storage allocated for "data" variable.
For example:
char value[32];
err = get_nvs_string("some_key", value, sizeof(value));
Users browsing this forum: Bing [Bot], YaCy [Bot] and 3 guests
