visual code idf setup issues
kc0skm
Postby kc0skm » Thu Dec 17, 2020 7:23 pm
i cannot get the idf installed any help suggestions - i have tried a number of versions of python... I cannot get my setup to validate the python tools in the last step - it finds the python path for select python version (initial steps)to use and finds Git also no issues. i cannot get the idf to pass if all the tools exist - (at 3.19 in this video see what attached video image capture) any help suggestions - i have tried a number of versions of python... it fails in verification of tools.
ERROR: Command errored out with exit status 1: 'C:\Users\Gregg\.espressif\python_env\idf4.1_py3.9_env\Scripts\python.exe' -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'C:\\Users\\Gregg\\AppData\\Local\\Temp\\pip-install-elpd2cer\\psutil\\setup.py'"'"'; __file__='"'"'C:\\Users\\Gregg\\AppData\\Local\\Temp\\pip-install-elpd2cer\\psutil\\setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record 'C:\Users\Gregg\AppData\Local\Temp\pip-record-fmanvioo\install-record.txt' --single-version-externally-managed --compile --install-headers 'C:\Users\Gregg\.espressif\python_env\idf4.1_py3.9_env\include\site\python3.9\psutil' Check the logs for full command output.
WARNING: You are using pip version 20.2.3; however, version 20.3.3 is available.
You should consider upgrading via the 'C:\Users\Gregg\.espressif\python_env\idf4.1_py3.9_env\Scripts\python.exe -m pip install --upgrade pip' command.
The following paths should be added to env PATH
.;C:\Python\Python39;C:\Users\Gregg\.espressif\tools\xtensa-esp32-elf\esp-2020r2-8.2.0\xtensa-esp32-elf\bin;C:\Users\Gregg\.espressif\tools\xtensa-esp32s2-elf\esp-2020r2-8.2.0\xtensa-esp32s2-elf\bin;C:\Users\Gregg\.espressif\tools\esp32ulp-elf\2.28.51-esp-20191205\esp32ulp-elf-binutils\bin;C:\Users\Gregg\.espressif\tools\esp32s2ulp-elf\2.28.51-esp-20191205\esp32s2ulp-elf-binutils\bin;C:\Users\Gregg\.espressif\tools\cmake\3.13.4\bin;C:\Users\Gregg\.espressif\tools\openocd-esp32\v0.10.0-esp32-20191114\openocd-esp32\bin;C:\Users\Gregg\.espressif\tools\ninja\1.9.0;C:\Users\Gregg\.espressif\tools\idf-exe\1.0.1;C:\Users\Gregg\.espressif\tools\ccache\3.7
esp pythom setup.jpg (13.03 KiB) Viewed 1730 times
