ESP32 - I2S / I²S - Can I really use any pin?
bastian.h.jaeger
Postby bastian.h.jaeger » Fri Dec 18, 2020 8:07 pm
I am trying to create a custom ESP32-wroom based PCB with an I²S microphone.
As the PCB has more tasks to fulfill, the GPIOs are becoming rare. So I can not use any pin anymore.
I read a lot in the [Technical Reference Manual][https://www.espressif.com/sites/default ... ual_en.pdf] but I do not understand everything 100%.
As far as I understand, ws_io_num and data_out_num can be any pin, but bck_io_num can only be some specific pins, but I do not understand which!
Can someone tell me, which pins I can use for I2S?
bastian.h.jaeger
Re: ESP32 - I2S / I²S - Can I really use any pin?
Postby bastian.h.jaeger » Wed Jan 20, 2021 10:57 am
Anyone can refer to anythine or anyone?
Postby Sprite » Thu Jan 21, 2021 3:42 am
Where specifically do you read that BCK_IO_NUM is limited wrt pins to choose from?
