mbedtls threading c & pthread
f.h-f.s.
Postby f.h-f.s. » Fri May 12, 2017 12:48 pm
I was trying to enable MBEDTLS_THREADING_C and MBEDTLS_THREADING_PTHREAD in:
mbedtls/port/include/mbedtls/esp_config.h
mbedtls/include/mbedtls/config.h
Resulting in a compiler error:
esp-idf/components/mbedtls/include/mbedtls/threading.h:46:2: error: 'pthread_mutex_t' does not name a type
  pthread_mutex_t mutex;
I saw a pthread_mutex_t defined in bt_defs.h and sys/types.h
I made a fix based on how bt_defs.h uses pthread_mutex_t that seems to fix that issue but is there another way?
I also have no clue if this fix is correct.
Threading.h:44
// typedef struct
// pthread_mutex_t mutex;
// char is_valid;
// } mbedtls_threading_mutex_t;
Threading.h:85
#include "freertos/semphr.h"
typedef unsigned int mbedtls_pthread_mutex_t; /* identify a mutex */
typedef struct
	mbedtls_pthread_mutex_t mutex;
	char is_valid;
typedef struct
	int type;
} pthread_mutexattr_t;
#define PTHREAD_MUTEX_INITIALIZER ((mbedtls_pthread_mutex_t)0xFFFFFFFF)
Threading.c:33
int pthread_mutex_unlock(mbedtls_pthread_mutex_t *pxMutex)
	xSemaphoreGive(*pxMutex);
	return 0;
void pthread_mutex_destroy(mbedtls_pthread_mutex_t *pxMutex)
	vQueueDelete((QueueHandle_t)*pxMutex);
int pthread_mutex_lock(mbedtls_pthread_mutex_t *pxMutex)
	while (xSemaphoreTake(*pxMutex, portMAX_DELAY) != pdPASS)
	return 0;
int pthread_mutex_init(mbedtls_pthread_mutex_t *pxMutex, void *a)
	int xReturn = -1;
	*pxMutex = (mbedtls_pthread_mutex_t)xSemaphoreCreateMutex();
	if (pxMutex != NULL)
		xReturn = 0;
	return xReturn;
Users browsing this forum: Bing [Bot], ChatGPT-User, PerplexityBot and 1 guest
