3.x library has been providing Modbus TCP/IP for a long time, when will it be in 4.x library ??
Does anyone know anything about this?
Greetings
Adam
When will Modbus TCP/IP be in ESP_IDF 4.x ?
fahad_ali_sarwar
ESP_alisitsyn
- Contact:
Re: When will Modbus TCP/IP be in ESP_IDF 4.x ?
Hi @adam_esp,
The previous answer from @fahad_ali_sarwar is correct. The Modbus TCP master/slave functionality implemented from ESP-IDF v4.2.
https://docs.espressif.com/projects/esp ... ght=modbus
Welcome,
thanks for the answer, i used version 4.1.
In version 4.2 there are no examples yet, but they are already on the master branch.
I am going to migrate from 4.1 to 4.2. I hope it will be painless
Greetings
Adam
Greetings
Adam
ESP_alisitsyn
- Contact:
@adam_esp ,
I recommend you to use latest release with examples:
https://docs.espressif.com/projects/esp ... odbus.html
https://github.com/espressif/esp-idf/tr ... _tcp_slave
https://github.com/espressif/esp-idf/tr ... tcp_master
Users browsing this forum: Qwantbot, Semrush [Bot] and 5 guests
