Poor performance X Benchmark
focosi
Postby focosi » Fri Jan 08, 2021 4:42 pm
In Wikipédia the information regarding processor speed is:
CPU: Xtensa dual-core (or single-core) 32-bit LX6 microprocessor, operating at 160 or 240 MHz and performing at up to 600 DMIPS
I prepared a small programm to test cpu speed and got strange results, because of this I have two questions:
1 – Why Iram program with DRAM variables had the worst performance
2 – Why the number of instructions per microsecond is so far from 240 or 600 as stated above
Below is the code:
#include <stdio.h>
#include "sdkconfig.h"
#include "freertos/task.h"
#include "esp_system.h"
#include "esp_spi_flash.h"
#include "esp_pm.h"
#include "esp_attr.h"
#include "esp32/clk.h"
#ifdef CONFIG_IDF_TARGET_ESP32
#define CHIP_NAME "ESP32"
#endif
#ifdef CONFIG_IDF_TARGET_ESP32S2BETA
#define CHIP_NAME "ESP32-S2 Beta"
#endif
 * I imagine in asm each while loop below will use around 3 instructions:
 * one instruction to add 1
 * one instruction to compare
 * the last instruction go to loop while <
#define	THREE_MILLION_INSTRUCTIONS	3000000
#define LOOP_ONE_MILLION			1000000
void IRAM_ATTR f_Iram_Internal_Calc_Cpu()
	int 		I_Ind;
	uint64_t 	I_Time_exec;
	int 		I_Int_Val, I_over;
	I_Ind 		= 0;
	I_Time_exec = esp_timer_get_time();
	I_over 		= esp_timer_get_time() - I_Time_exec;
	printf("Overhead f_Iram_Internal_Calc_Cpu=%d\n",I_over);
	while (I_Ind < LOOP_ONE_MILLION)
		I_Ind++;
	I_Int_Val = esp_timer_get_time() - I_Time_exec - I_over;
	printf("Time execution Iram + internal variable=%d, instructions per microsecond=%d\n",I_Int_Val, THREE_MILLION_INSTRUCTIONS/I_Int_Val);
DRAM_ATTR	int 		D_Ind;
DRAM_ATTR	uint64_t 	D_Time_exec;
DRAM_ATTR	int 		D_Int_Val, D_over;
void IRAM_ATTR f_Iram_Dram_Calc_Cpu()
	D_Ind 		= 0;
	D_Time_exec = esp_timer_get_time();
	D_over 		= esp_timer_get_time() - D_Time_exec;
	printf("Overhead f_Iram_Dram_Calc_Cpu=%d\n",D_over);
	while (D_Ind < LOOP_ONE_MILLION)
		D_Ind++;
	D_Int_Val = esp_timer_get_time() - D_Time_exec - D_over;
	printf("Time execution Iram + Dram variable=%d, instructions per microsecond=%d\n",D_Int_Val, THREE_MILLION_INSTRUCTIONS/D_Int_Val);
void f_Regular_DRAM_Calc_Cpu()
	D_Ind 		= 0;
	printf("Overhead f_Regular_DRAM_Calc_Cpu=%d\n",D_over);
		D_Ind++;
	printf("Time execution Regular + DRAM variable=%d, instructions per microsecond=%d\n",D_Int_Val, THREE_MILLION_INSTRUCTIONS/D_Int_Val);
void f_Regular_Internal_Calc_Cpu()
	int 		N_Ind;
	uint64_t 	N_Time_exec;
	int 		N_Int_Val, N_over;
	N_Ind 		= 0;
	N_Time_exec = esp_timer_get_time();
	N_over 		= esp_timer_get_time() - N_Time_exec;
	printf("Overhead f_Regular_Internal_Calc_Cpu=%d\n",N_over);
	while (N_Ind < LOOP_ONE_MILLION)
		N_Ind++;
	N_Int_Val = esp_timer_get_time() - N_Time_exec - N_over;
	printf("Time execution Regular + Internal variable=%d, instructions per microsecond=%d\n",N_Int_Val, THREE_MILLION_INSTRUCTIONS/N_Int_Val);
void app_main(void)
    int 	Int_Val;
    printf("Hello Processor!\n");
    /* Print chip information */
    esp_chip_info_t chip_info;
    esp_chip_info(&chip_info);
    printf("This is %s chip with %d CPU cores, WiFi%s%s, ",
            CHIP_NAME,
            chip_info.cores,
            (chip_info.features & CHIP_FEATURE_BT) ? "/BT" : "",
            (chip_info.features & CHIP_FEATURE_BLE) ? "/BLE" : "");
    printf("silicon revision %d, ", chip_info.revision);
    printf("%dMB %s flash\n", spi_flash_get_chip_size() / (1024 * 1024),
            (chip_info.features & CHIP_FEATURE_EMB_FLASH) ? "embedded" : "external");
	// Será exibida a velocidade do processamento
	Int_Val = rtc_clk_xtal_freq_get();
	printf("\nRtc speed rtc_clk_xtal_freq_get %d\n", Int_Val);
	Int_Val =  esp_clk_cpu_freq() / LOOP_ONE_MILLION;
	printf("Processor speed %d\n", Int_Val);
    printf("\n\n");
    f_Iram_Internal_Calc_Cpu();
    printf("\n\n");
    f_Iram_Dram_Calc_Cpu();
    printf("\n\n");
    f_Regular_DRAM_Calc_Cpu();
    printf("\n\n");
    f_Regular_Internal_Calc_Cpu();
    while (true)
		printf("Loop\n");
		vTaskDelay(60000 / portTICK_PERIOD_MS);
Results:
Hello Processor!
This is ESP32 chip with 2 CPU cores, WiFi/BT/BLE, silicon revision 1, 4MB external flash
Rtc speed rtc_clk_xtal_freq_get 40
Processor speed 240
Overhead f_Iram_Internal_Calc_Cpu=1
Time execution Iram + internal variable=41701, instructions per microsecond=71
Overhead f_Iram_Dram_Calc_Cpu=1
Time execution Iram + Dram variable=79231, instructions per microsecond=37
Overhead f_Regular_DRAM_Calc_Cpu=4
Time execution Regular + DRAM variable=79203, instructions per microsecond=37
Overhead f_Regular_Internal_Calc_Cpu=1
Time execution Regular + Internal variable=41688, instructions per microsecond=71
Re: Poor performance X Benchmark
Postby Sprite » Sat Jan 09, 2021 5:14 am
Likely, the compiler spots that your loop is doing absolutely nothing and has helpfully optimized it away. The rest of the results are probably noise.
cruz000
Postby cruz000 » Sat Mar 18, 2023 4:57 pm
You can try to obtain a detailed depict of the execution. Take a look at a the article: TLS Protocol Analysis Using IoTST—An IoT Benchmark Based on Scheduler Traces.
