compile failed with dangerous relocation: cannot decode instruction opcode
MSD-Systems
Postby MSD-Systems » Fri Jan 08, 2021 6:25 pm
i have a problem that the linking fails with the following error messages. I have updated to latest github files. Now can not compile anymore my application.
Linking CXX executable huhu_books.elf
FAILED: huhu_books.elf
: && /home/schwm/.espressif/tools/xtensa-esp32s2-elf/esp-2020r3-8.4.0/xtensa-esp32s2-elf/bin/xtensa-esp32s2-elf-g++  -mlongcalls   CMakeFiles/huhu_books.elf.dir/project_elf_src_esp32s2.c.obj  -o huhu_books.elf  esp-idf/esp_pm/libesp_pm.a  esp-idf/mbedtls/libmbedtls.a  esp-idf/efuse/libefuse.a  esp-idf/bootloader_support/libbootloader_support.a  esp-idf/app_update/libapp_update.a  esp-idf/esp_ipc/libesp_ipc.a  esp-idf/spi_flash/libspi_flash.a  esp-idf/nvs_flash/libnvs_flash.a  esp-idf/pthread/libpthread.a  esp-idf/esp_gdbstub/libesp_gdbstub.a  esp-idf/esp_system/libesp_system.a  esp-idf/esp_rom/libesp_rom.a  esp-idf/hal/libhal.a  esp-idf/vfs/libvfs.a  esp-idf/esp_eth/libesp_eth.a  esp-idf/tcpip_adapter/libtcpip_adapter.a  esp-idf/esp_netif/libesp_netif.a  esp-idf/esp_event/libesp_event.a  esp-idf/wpa_supplicant/libwpa_supplicant.a  esp-idf/esp_wifi/libesp_wifi.a  esp-idf/lwip/liblwip.a  esp-idf/log/liblog.a  esp-idf/heap/libheap.a  esp-idf/soc/libsoc.a  esp-idf/esp_hw_support/libesp_hw_support.a  esp-idf/esp_ringbuf/libesp_ringbuf.a  esp-idf/driver/libdriver.a  esp-idf/xtensa/libxtensa.a  esp-idf/espcoredump/libespcoredump.a  esp-idf/esp32s2/libesp32s2.a  esp-idf/esp_common/libesp_common.a  esp-idf/esp_timer/libesp_timer.a  esp-idf/freertos/libfreertos.a  esp-idf/newlib/libnewlib.a  esp-idf/cxx/libcxx.a  esp-idf/app_trace/libapp_trace.a  esp-idf/asio/libasio.a  esp-idf/cbor/libcbor.a  esp-idf/unity/libunity.a  esp-idf/cmock/libcmock.a  esp-idf/coap/libcoap.a  esp-idf/console/libconsole.a  esp-idf/nghttp/libnghttp.a  esp-idf/esp-tls/libesp-tls.a  esp-idf/esp_adc_cal/libesp_adc_cal.a  esp-idf/esp_hid/libesp_hid.a  esp-idf/tcp_transport/libtcp_transport.a  esp-idf/esp_http_client/libesp_http_client.a  esp-idf/esp_http_server/libesp_http_server.a  esp-idf/esp_https_ota/libesp_https_ota.a  esp-idf/protobuf-c/libprotobuf-c.a  esp-idf/protocomm/libprotocomm.a  esp-idf/mdns/libmdns.a  esp-idf/esp_local_ctrl/libesp_local_ctrl.a  esp-idf/sdmmc/libsdmmc.a  esp-idf/esp_serial_slave_link/libesp_serial_slave_link.a  esp-idf/esp_websocket_client/libesp_websocket_client.a  esp-idf/expat/libexpat.a  esp-idf/wear_levelling/libwear_levelling.a  esp-idf/fatfs/libfatfs.a  esp-idf/freemodbus/libfreemodbus.a  esp-idf/jsmn/libjsmn.a  esp-idf/json/libjson.a  esp-idf/libsodium/liblibsodium.a  esp-idf/mqtt/libmqtt.a  esp-idf/openssl/libopenssl.a  esp-idf/perfmon/libperfmon.a  esp-idf/spiffs/libspiffs.a  esp-idf/ulp/libulp.a  esp-idf/wifi_provisioning/libwifi_provisioning.a  esp-idf/audio_sal/libaudio_sal.a  esp-idf/adf_utils/libadf_utils.a  esp-idf/display_service/libdisplay_service.a  esp-idf/esp_dispatcher/libesp_dispatcher.a  esp-idf/audio_hal/libaudio_hal.a  esp-idf/esp-sr/libesp-sr.a  esp-idf/esp-adf-libs/libesp-adf-libs.a  esp-idf/audio_pipeline/libaudio_pipeline.a  esp-idf/esp_peripherals/libesp_peripherals.a  esp-idf/wifi_service/libwifi_service.a  esp-idf/dueros_service/libdueros_service.a  esp-idf/esp_actions/libesp_actions.a  esp-idf/tone_partition/libtone_partition.a  esp-idf/audio_stream/libaudio_stream.a  esp-idf/battery_service/libbattery_service.a  esp-idf/bluetooth_service/libbluetooth_service.a  esp-idf/coredump_upload_service/libcoredump_upload_service.a  esp-idf/esp_event_cast/libesp_event_cast.a  esp-idf/input_key_service/libinput_key_service.a  esp-idf/ota_service/libota_service.a  esp-idf/playlist/libplaylist.a  esp-idf/my_board/libmy_board.a  esp-idf/my_gpio/libmy_gpio.a  esp-idf/pn532/libpn532.a  esp-idf/rgb-led/librgb-led.a  esp-idf/wifi-prov/libwifi-prov.a  esp-idf/main/libmain.a  -Wl,--cref -Wl,--Map=/home/schwm/huhu/huhu_books/build/huhu_books.map  -fno-rtti  -fno-lto  esp-idf/asio/libasio.a  esp-idf/cbor/libcbor.a  esp-idf/cmock/libcmock.a  esp-idf/unity/libunity.a  esp-idf/coap/libcoap.a  esp-idf/esp_hid/libesp_hid.a  esp-idf/esp_local_ctrl/libesp_local_ctrl.a  esp-idf/esp_websocket_client/libesp_websocket_client.a  esp-idf/expat/libexpat.a  esp-idf/freemodbus/libfreemodbus.a  esp-idf/libsodium/liblibsodium.a  esp-idf/mqtt/libmqtt.a  esp-idf/openssl/libopenssl.a  esp-idf/perfmon/libperfmon.a  esp-idf/adf_utils/libadf_utils.a  esp-idf/jsmn/libjsmn.a  esp-idf/battery_service/libbattery_service.a  esp-idf/bluetooth_service/libbluetooth_service.a  esp-idf/coredump_upload_service/libcoredump_upload_service.a  esp-idf/esp_event_cast/libesp_event_cast.a  esp-idf/input_key_service/libinput_key_service.a  esp-idf/ota_service/libota_service.a  esp-idf/audio_stream/libaudio_stream.a  esp-idf/tone_partition/libtone_partition.a  esp-idf/wifi_service/libwifi_service.a  esp-idf/esp_actions/libesp_actions.a  esp-idf/wifi_service/libwifi_service.a  esp-idf/esp_actions/libesp_actions.a  -L/home/schwm/Tools/esptools/esp-adf/components/wifi_service/airkiss_config  -lairkiss_aes  esp-idf/dueros_service/libdueros_service.a  -L/home/schwm/Tools/esptools/esp-adf/components/clouds/dueros/lightduer  -lduer-device-v4x  esp-idf/playlist/libplaylist.a  esp-idf/my_gpio/libmy_gpio.a  esp-idf/pn532/libpn532.a  esp-idf/rgb-led/librgb-led.a  esp-idf/display_service/libdisplay_service.a  esp-idf/audio_hal/libaudio_hal.a  esp-idf/esp_peripherals/libesp_peripherals.a  esp-idf/my_board/libmy_board.a  esp-idf/display_service/libdisplay_service.a  esp-idf/audio_hal/libaudio_hal.a  esp-idf/esp_peripherals/libesp_peripherals.a  esp-idf/my_board/libmy_board.a  -L/home/schwm/Tools/esptools/esp-adf/components/audio_hal/driver/zl38063/firmware  -lfirmware  esp-idf/esp_adc_cal/libesp_adc_cal.a  esp-idf/fatfs/libfatfs.a  esp-idf/wear_levelling/libwear_levelling.a  esp-idf/spiffs/libspiffs.a  esp-idf/esp-adf-libs/libesp-adf-libs.a  esp-idf/audio_pipeline/libaudio_pipeline.a  /home/schwm/Tools/esptools/esp-adf/components/esp-adf-libs/esp_codec/lib/esp32s2/libesp_processing.a  /home/schwm/Tools/esptools/esp-adf/components/esp-adf-libs/esp_audio/lib/esp32s2/libesp_audio.a  /home/schwm/Tools/esptools/esp-adf/components/esp-adf-libs/esp_codec/lib/esp32s2/libesp-opus.a  /home/schwm/Tools/esptools/esp-adf/components/esp-adf-libs/esp_codec/lib/esp32s2/libesp-tremor.a  /home/schwm/Tools/esptools/esp-adf/components/esp-adf-libs/recorder_engine/lib/esp32s2/librecorder_engine.a  esp-idf/esp-adf-libs/libesp-adf-libs.a  esp-idf/audio_pipeline/libaudio_pipeline.a  /home/schwm/Tools/esptools/esp-adf/components/esp-adf-libs/esp_codec/lib/esp32s2/libesp_processing.a  /home/schwm/Tools/esptools/esp-adf/components/esp-adf-libs/esp_audio/lib/esp32s2/libesp_audio.a  /home/schwm/Tools/esptools/esp-adf/components/esp-adf-libs/esp_codec/lib/esp32s2/libesp-opus.a  /home/schwm/Tools/esptools/esp-adf/components/esp-adf-libs/esp_codec/lib/esp32s2/libesp-tremor.a  /home/schwm/Tools/esptools/esp-adf/components/esp-adf-libs/recorder_engine/lib/esp32s2/librecorder_engine.a  esp-idf/esp-sr/libesp-sr.a  -L /home/schwm/Tools/esptools/esp-adf/components/esp-sr/lib  -L /home/schwm/Tools/esptools/esp-adf/components/esp-sr/wake_word_engine  -L /home/schwm/Tools/esptools/esp-adf/components/esp-sr/speech_command_recognition  -L /home/schwm/Tools/esptools/esp-adf/components/esp-sr/acoustic_algorithm  -L /home/schwm/Tools/esptools/esp-adf/components/esp-sr/esp-tts/esp_tts_chinese  -lesp_tts_chinese_esp32s2  -lvoice_set_xiaole_esp32s2  -lvoice_set_template_esp32s2  -Wl,--start-group  -Wl,--end-group  -L /home/schwm/Tools/esptools/esp-adf/components/esp-adf-libs/esp_audio/lib/esp32s2  -L /home/schwm/Tools/esptools/esp-adf/components/esp-adf-libs/esp_codec/lib/esp32s2  -L /home/schwm/Tools/esptools/esp-adf/components/esp-adf-libs/esp_ssdp/lib/esp32s2  -L /home/schwm/Tools/esptools/esp-adf/components/esp-adf-libs/esp_upnp/lib/esp32s2  -L /home/schwm/Tools/esptools/esp-adf/components/esp-adf-libs/esp_sip/lib/esp32s2  -L /home/schwm/Tools/esptools/esp-adf/components/esp-adf-libs/recorder_engine/lib/esp32s2  -lesp-aac  -lesp-amr  -lesp-amrwbenc  -lesp-flac  -lesp_ssdp  -lesp-ogg-container  /home/schwm/Tools/esptools/esp-adf/components/esp-adf-libs/esp_sip/lib/esp32s2/libesp_sip.a  -lesp_upnp  -lesp-mp3  -lcodec-utils  -lesp-g711  esp-idf/esp_dispatcher/libesp_dispatcher.a  esp-idf/audio_sal/libaudio_sal.a  esp-idf/wifi-prov/libwifi-prov.a  esp-idf/wifi_provisioning/libwifi_provisioning.a  esp-idf/protocomm/libprotocomm.a  esp-idf/protobuf-c/libprotobuf-c.a  esp-idf/mdns/libmdns.a  esp-idf/console/libconsole.a  esp-idf/json/libjson.a  esp-idf/esp_pm/libesp_pm.a  esp-idf/mbedtls/libmbedtls.a  esp-idf/efuse/libefuse.a  esp-idf/bootloader_support/libbootloader_support.a  esp-idf/app_update/libapp_update.a  esp-idf/esp_ipc/libesp_ipc.a  esp-idf/spi_flash/libspi_flash.a  esp-idf/nvs_flash/libnvs_flash.a  esp-idf/pthread/libpthread.a  esp-idf/esp_gdbstub/libesp_gdbstub.a  esp-idf/esp_system/libesp_system.a  esp-idf/esp_rom/libesp_rom.a  esp-idf/hal/libhal.a  esp-idf/vfs/libvfs.a  esp-idf/esp_eth/libesp_eth.a  esp-idf/tcpip_adapter/libtcpip_adapter.a  esp-idf/esp_netif/libesp_netif.a  esp-idf/esp_event/libesp_event.a  esp-idf/wpa_supplicant/libwpa_supplicant.a  esp-idf/esp_wifi/libesp_wifi.a  esp-idf/lwip/liblwip.a  esp-idf/log/liblog.a  esp-idf/heap/libheap.a  esp-idf/soc/libsoc.a  esp-idf/esp_hw_support/libesp_hw_support.a  esp-idf/esp_ringbuf/libesp_ringbuf.a  esp-idf/driver/libdriver.a  esp-idf/xtensa/libxtensa.a  esp-idf/espcoredump/libespcoredump.a  esp-idf/esp32s2/libesp32s2.a  esp-idf/esp_common/libesp_common.a  esp-idf/esp_timer/libesp_timer.a  esp-idf/freertos/libfreertos.a  esp-idf/newlib/libnewlib.a  esp-idf/cxx/libcxx.a  esp-idf/app_trace/libapp_trace.a  esp-idf/nghttp/libnghttp.a  esp-idf/esp-tls/libesp-tls.a  esp-idf/tcp_transport/libtcp_transport.a  esp-idf/esp_http_client/libesp_http_client.a  esp-idf/esp_http_server/libesp_http_server.a  esp-idf/esp_https_ota/libesp_https_ota.a  esp-idf/sdmmc/libsdmmc.a  esp-idf/esp_serial_slave_link/libesp_serial_slave_link.a  esp-idf/ulp/libulp.a  esp-idf/mbedtls/mbedtls/library/libmbedtls.a  esp-idf/mbedtls/mbedtls/library/libmbedcrypto.a  esp-idf/mbedtls/mbedtls/library/libmbedx509.a  /home/schwm/Tools/esptools/esp-idf/components/esp_wifi/lib/esp32s2/libcoexist.a  /home/schwm/Tools/esptools/esp-idf/components/esp_wifi/lib/esp32s2/libcore.a  /home/schwm/Tools/esptools/esp-idf/components/esp_wifi/lib/esp32s2/libespnow.a  /home/schwm/Tools/esptools/esp-idf/components/esp_wifi/lib/esp32s2/libmesh.a  /home/schwm/Tools/esptools/esp-idf/components/esp_wifi/lib/esp32s2/libnet80211.a  /home/schwm/Tools/esptools/esp-idf/components/esp_wifi/lib/esp32s2/libpp.a  /home/schwm/Tools/esptools/esp-idf/components/esp_wifi/lib/esp32s2/librtc.a  /home/schwm/Tools/esptools/esp-idf/components/esp_wifi/lib/esp32s2/libsmartconfig.a  /home/schwm/Tools/esptools/esp-idf/components/esp_wifi/lib/esp32s2/libphy.a  esp-idf/esp_pm/libesp_pm.a  esp-idf/mbedtls/libmbedtls.a  esp-idf/efuse/libefuse.a  esp-idf/bootloader_support/libbootloader_support.a  esp-idf/app_update/libapp_update.a  esp-idf/esp_ipc/libesp_ipc.a  esp-idf/spi_flash/libspi_flash.a  esp-idf/nvs_flash/libnvs_flash.a  esp-idf/pthread/libpthread.a  esp-idf/esp_gdbstub/libesp_gdbstub.a  esp-idf/esp_system/libesp_system.a  esp-idf/esp_rom/libesp_rom.a  esp-idf/hal/libhal.a  esp-idf/vfs/libvfs.a  esp-idf/esp_eth/libesp_eth.a  esp-idf/tcpip_adapter/libtcpip_adapter.a  esp-idf/esp_netif/libesp_netif.a  esp-idf/esp_event/libesp_event.a  esp-idf/wpa_supplicant/libwpa_supplicant.a  esp-idf/esp_wifi/libesp_wifi.a  esp-idf/lwip/liblwip.a  esp-idf/log/liblog.a  esp-idf/heap/libheap.a  esp-idf/soc/libsoc.a  esp-idf/esp_hw_support/libesp_hw_support.a  esp-idf/esp_ringbuf/libesp_ringbuf.a  esp-idf/driver/libdriver.a  esp-idf/xtensa/libxtensa.a  esp-idf/espcoredump/libespcoredump.a  esp-idf/esp32s2/libesp32s2.a  esp-idf/esp_common/libesp_common.a  esp-idf/esp_timer/libesp_timer.a  esp-idf/freertos/libfreertos.a  esp-idf/newlib/libnewlib.a  esp-idf/cxx/libcxx.a  esp-idf/app_trace/libapp_trace.a  esp-idf/nghttp/libnghttp.a  esp-idf/esp-tls/libesp-tls.a  esp-idf/tcp_transport/libtcp_transport.a  esp-idf/esp_http_client/libesp_http_client.a  esp-idf/esp_http_server/libesp_http_server.a  esp-idf/esp_https_ota/libesp_https_ota.a  esp-idf/sdmmc/libsdmmc.a  esp-idf/esp_serial_slave_link/libesp_serial_slave_link.a  esp-idf/ulp/libulp.a  esp-idf/mbedtls/mbedtls/library/libmbedtls.a  esp-idf/mbedtls/mbedtls/library/libmbedcrypto.a  esp-idf/mbedtls/mbedtls/library/libmbedx509.a  /home/schwm/Tools/esptools/esp-idf/components/esp_wifi/lib/esp32s2/libcoexist.a  /home/schwm/Tools/esptools/esp-idf/components/esp_wifi/lib/esp32s2/libcore.a  /home/schwm/Tools/esptools/esp-idf/components/esp_wifi/lib/esp32s2/libespnow.a  /home/schwm/Tools/esptools/esp-idf/components/esp_wifi/lib/esp32s2/libmesh.a  /home/schwm/Tools/esptools/esp-idf/components/esp_wifi/lib/esp32s2/libnet80211.a  /home/schwm/Tools/esptools/esp-idf/components/esp_wifi/lib/esp32s2/libpp.a  /home/schwm/Tools/esptools/esp-idf/components/esp_wifi/lib/esp32s2/librtc.a  /home/schwm/Tools/esptools/esp-idf/components/esp_wifi/lib/esp32s2/libsmartconfig.a  /home/schwm/Tools/esptools/esp-idf/components/esp_wifi/lib/esp32s2/libphy.a  esp-idf/esp_pm/libesp_pm.a  esp-idf/mbedtls/libmbedtls.a  esp-idf/efuse/libefuse.a  esp-idf/bootloader_support/libbootloader_support.a  esp-idf/app_update/libapp_update.a  esp-idf/esp_ipc/libesp_ipc.a  esp-idf/spi_flash/libspi_flash.a  esp-idf/nvs_flash/libnvs_flash.a  esp-idf/pthread/libpthread.a  esp-idf/esp_gdbstub/libesp_gdbstub.a  esp-idf/esp_system/libesp_system.a  esp-idf/esp_rom/libesp_rom.a  esp-idf/hal/libhal.a  esp-idf/vfs/libvfs.a  esp-idf/esp_eth/libesp_eth.a  esp-idf/tcpip_adapter/libtcpip_adapter.a  esp-idf/esp_netif/libesp_netif.a  esp-idf/esp_event/libesp_event.a  esp-idf/wpa_supplicant/libwpa_supplicant.a  esp-idf/esp_wifi/libesp_wifi.a  esp-idf/lwip/liblwip.a  esp-idf/log/liblog.a  esp-idf/heap/libheap.a  esp-idf/soc/libsoc.a  esp-idf/esp_hw_support/libesp_hw_support.a  esp-idf/esp_ringbuf/libesp_ringbuf.a  esp-idf/driver/libdriver.a  esp-idf/xtensa/libxtensa.a  esp-idf/espcoredump/libespcoredump.a  esp-idf/esp32s2/libesp32s2.a  esp-idf/esp_common/libesp_common.a  esp-idf/esp_timer/libesp_timer.a  esp-idf/freertos/libfreertos.a  esp-idf/newlib/libnewlib.a  esp-idf/cxx/libcxx.a  esp-idf/app_trace/libapp_trace.a  esp-idf/nghttp/libnghttp.a  esp-idf/esp-tls/libesp-tls.a  esp-idf/tcp_transport/libtcp_transport.a  esp-idf/esp_http_client/libesp_http_client.a  esp-idf/esp_http_server/libesp_http_server.a  esp-idf/esp_https_ota/libesp_https_ota.a  esp-idf/sdmmc/libsdmmc.a  esp-idf/esp_serial_slave_link/libesp_serial_slave_link.a  esp-idf/ulp/libulp.a  esp-idf/mbedtls/mbedtls/library/libmbedtls.a  esp-idf/mbedtls/mbedtls/library/libmbedcrypto.a  esp-idf/mbedtls/mbedtls/library/libmbedx509.a  /home/schwm/Tools/esptools/esp-idf/components/esp_wifi/lib/esp32s2/libcoexist.a  /home/schwm/Tools/esptools/esp-idf/components/esp_wifi/lib/esp32s2/libcore.a  /home/schwm/Tools/esptools/esp-idf/components/esp_wifi/lib/esp32s2/libespnow.a  /home/schwm/Tools/esptools/esp-idf/components/esp_wifi/lib/esp32s2/libmesh.a  /home/schwm/Tools/esptools/esp-idf/components/esp_wifi/lib/esp32s2/libnet80211.a  /home/schwm/Tools/esptools/esp-idf/components/esp_wifi/lib/esp32s2/libpp.a  /home/schwm/Tools/esptools/esp-idf/components/esp_wifi/lib/esp32s2/librtc.a  /home/schwm/Tools/esptools/esp-idf/components/esp_wifi/lib/esp32s2/libsmartconfig.a  /home/schwm/Tools/esptools/esp-idf/components/esp_wifi/lib/esp32s2/libphy.a  esp-idf/esp_pm/libesp_pm.a  esp-idf/mbedtls/libmbedtls.a  esp-idf/efuse/libefuse.a  esp-idf/bootloader_support/libbootloader_support.a  esp-idf/app_update/libapp_update.a  esp-idf/esp_ipc/libesp_ipc.a  esp-idf/spi_flash/libspi_flash.a  esp-idf/nvs_flash/libnvs_flash.a  esp-idf/pthread/libpthread.a  esp-idf/esp_gdbstub/libesp_gdbstub.a  esp-idf/esp_system/libesp_system.a  esp-idf/esp_rom/libesp_rom.a  esp-idf/hal/libhal.a  esp-idf/vfs/libvfs.a  esp-idf/esp_eth/libesp_eth.a  esp-idf/tcpip_adapter/libtcpip_adapter.a  esp-idf/esp_netif/libesp_netif.a  esp-idf/esp_event/libesp_event.a  esp-idf/wpa_supplicant/libwpa_supplicant.a  esp-idf/esp_wifi/libesp_wifi.a  esp-idf/lwip/liblwip.a  esp-idf/log/liblog.a  esp-idf/heap/libheap.a  esp-idf/soc/libsoc.a  esp-idf/esp_hw_support/libesp_hw_support.a  esp-idf/esp_ringbuf/libesp_ringbuf.a  esp-idf/driver/libdriver.a  esp-idf/xtensa/libxtensa.a  esp-idf/espcoredump/libespcoredump.a  esp-idf/esp32s2/libesp32s2.a  esp-idf/esp_common/libesp_common.a  esp-idf/esp_timer/libesp_timer.a  esp-idf/freertos/libfreertos.a  esp-idf/newlib/libnewlib.a  esp-idf/cxx/libcxx.a  esp-idf/app_trace/libapp_trace.a  esp-idf/nghttp/libnghttp.a  esp-idf/esp-tls/libesp-tls.a  esp-idf/tcp_transport/libtcp_transport.a  esp-idf/esp_http_client/libesp_http_client.a  esp-idf/esp_http_server/libesp_http_server.a  esp-idf/esp_https_ota/libesp_https_ota.a  esp-idf/sdmmc/libsdmmc.a  esp-idf/esp_serial_slave_link/libesp_serial_slave_link.a  esp-idf/ulp/libulp.a  esp-idf/mbedtls/mbedtls/library/libmbedtls.a  esp-idf/mbedtls/mbedtls/library/libmbedcrypto.a  esp-idf/mbedtls/mbedtls/library/libmbedx509.a  /home/schwm/Tools/esptools/esp-idf/components/esp_wifi/lib/esp32s2/libcoexist.a  /home/schwm/Tools/esptools/esp-idf/components/esp_wifi/lib/esp32s2/libcore.a  /home/schwm/Tools/esptools/esp-idf/components/esp_wifi/lib/esp32s2/libespnow.a  /home/schwm/Tools/esptools/esp-idf/components/esp_wifi/lib/esp32s2/libmesh.a  /home/schwm/Tools/esptools/esp-idf/components/esp_wifi/lib/esp32s2/libnet80211.a  /home/schwm/Tools/esptools/esp-idf/components/esp_wifi/lib/esp32s2/libpp.a  /home/schwm/Tools/esptools/esp-idf/components/esp_wifi/lib/esp32s2/librtc.a  /home/schwm/Tools/esptools/esp-idf/components/esp_wifi/lib/esp32s2/libsmartconfig.a  /home/schwm/Tools/esptools/esp-idf/components/esp_wifi/lib/esp32s2/libphy.a  -lesp32s2  -u esp_app_desc  -u pthread_include_pthread_impl  -u pthread_include_pthread_cond_impl  -u pthread_include_pthread_local_storage_impl  -u ld_include_panic_highint_hdl  -u start_app  -L /home/schwm/Tools/esptools/esp-idf/components/esp_rom/esp32s2/ld  -T esp32s2.rom.ld  -T esp32s2.rom.api.ld  -T esp32s2.rom.libgcc.ld  -T esp32s2.rom.newlib-funcs.ld  -T esp32s2.rom.newlib-data.ld  -T esp32s2.rom.spiflash.ld  -u vfs_include_syscalls_impl  -L /home/schwm/Tools/esptools/esp-idf/components/esp_wifi/lib/esp32s2  /home/schwm/Tools/esptools/esp-idf/components/xtensa/esp32s2/libxt_hal.a  -L /home/schwm/huhu/huhu_books/build/esp-idf/esp32s2  -T esp32s2_out.ld  -L /home/schwm/huhu/huhu_books/build/esp-idf/esp32s2/ld  -T esp32s2.project.ld  -L /home/schwm/Tools/esptools/esp-idf/components/esp32s2/ld  -T esp32s2.peripherals.ld  -u call_user_start_cpu0  -Wl,--gc-sections  -Wl,--undefined=uxTopUsedPriority  -u app_main  -lm  esp-idf/newlib/libnewlib.a  -u newlib_include_heap_impl  -u newlib_include_syscalls_impl  -u newlib_include_pthread_impl  -lgcc  -u __cxa_guard_dummy  -lstdc++  esp-idf/pthread/libpthread.a  -u __cxx_fatal_exception  esp-idf/app_trace/libapp_trace.a  -lgcov  esp-idf/app_trace/libapp_trace.a  -lgcov  -lc && :
/home/schwm/.espressif/tools/xtensa-esp32s2-elf/esp-2020r3-8.4.0/xtensa-esp32s2-elf/bin/../lib/gcc/xtensa-esp32s2-elf/8.4.0/../../../../xtensa-esp32s2-elf/bin/ld: /home/schwm/Tools/esptools/esp-adf/components/esp-adf-libs/esp_codec/lib/esp32s2/libesp_processing.a(esp_alc.c.obj)(.text.alc_volume_setup_open+0x33): could not decode instruction; possible configuration mismatch
/home/schwm/.espressif/tools/xtensa-esp32s2-elf/esp-2020r3-8.4.0/xtensa-esp32s2-elf/bin/../lib/gcc/xtensa-esp32s2-elf/8.4.0/../../../../xtensa-esp32s2-elf/bin/ld: /home/schwm/Tools/esptools/esp-adf/components/esp-adf-libs/esp_codec/lib/esp32s2/libesp_processing.a(aac_decoder.c.obj)(.text.aac_decoder_open+0x73e): could not decode instruction; possible configuration mismatch
/home/schwm/.espressif/tools/xtensa-esp32s2-elf/esp-2020r3-8.4.0/xtensa-esp32s2-elf/bin/../lib/gcc/xtensa-esp32s2-elf/8.4.0/../../../../xtensa-esp32s2-elf/bin/ld: /home/schwm/Tools/esptools/esp-adf/components/esp-adf-libs/esp_codec/lib/esp32s2/libesp_processing.a(esp_alc.c.obj): in function `volume_amplify_dual':
/home/gitlab-runner/builds/w2jWgEzx/0/adf/esp-adf-libs-source/esp_processing/esp-alc/src/esp_alc.c:183:(.text.alc_volume_setup_process+0xbe): dangerous relocation: cannot decode instruction opcode: (.text.alc_volume_setup_process+0xc4)
/home/schwm/.espressif/tools/xtensa-esp32s2-elf/esp-2020r3-8.4.0/xtensa-esp32s2-elf/bin/../lib/gcc/xtensa-esp32s2-elf/8.4.0/../../../../xtensa-esp32s2-elf/bin/ld: /home/gitlab-runner/builds/w2jWgEzx/0/adf/esp-adf-libs-source/esp_processing/esp-alc/src/esp_alc.c:202:(.text.alc_volume_setup_process+0xf6): dangerous relocation: cannot decode instruction opcode: (.text.alc_volume_setup_process+0xfc)
/home/schwm/.espressif/tools/xtensa-esp32s2-elf/esp-2020r3-8.4.0/xtensa-esp32s2-elf/bin/../lib/gcc/xtensa-esp32s2-elf/8.4.0/../../../../xtensa-esp32s2-elf/bin/ld: /home/gitlab-runner/builds/w2jWgEzx/0/adf/esp-adf-libs-source/esp_processing/esp-alc/src/esp_alc.c:212:(.text.alc_volume_setup_process+0x11b): dangerous relocation: cannot decode instruction opcode: (.text.alc_volume_setup_process+0x121)
/home/schwm/.espressif/tools/xtensa-esp32s2-elf/esp-2020r3-8.4.0/xtensa-esp32s2-elf/bin/../lib/gcc/xtensa-esp32s2-elf/8.4.0/../../../../xtensa-esp32s2-elf/bin/ld: /home/gitlab-runner/builds/w2jWgEzx/0/adf/esp-adf-libs-source/esp_processing/esp-alc/src/esp_alc.c:213:(.text.alc_volume_setup_process+0x130): dangerous relocation: cannot decode instruction opcode: (.text.alc_volume_setup_process+0x136)
/home/schwm/.espressif/tools/xtensa-esp32s2-elf/esp-2020r3-8.4.0/xtensa-esp32s2-elf/bin/../lib/gcc/xtensa-esp32s2-elf/8.4.0/../../../../xtensa-esp32s2-elf/bin/ld: /home/gitlab-runner/builds/w2jWgEzx/0/adf/esp-adf-libs-source/esp_processing/esp-alc/src/esp_alc.c:254:(.text.alc_volume_setup_process+0x148): dangerous relocation: cannot decode instruction opcode: (.text.alc_volume_setup_process+0x14e)
/home/schwm/.espressif/tools/xtensa-esp32s2-elf/esp-2020r3-8.4.0/xtensa-esp32s2-elf/bin/../lib/gcc/xtensa-esp32s2-elf/8.4.0/../../../../xtensa-esp32s2-elf/bin/ld: /home/gitlab-runner/builds/w2jWgEzx/0/adf/esp-adf-libs-source/esp_processing/esp-alc/src/esp_alc.c:273:(.text.alc_volume_setup_process+0x17c): dangerous relocation: cannot decode instruction opcode: (.text.alc_volume_setup_process+0x182)
/home/schwm/.espressif/tools/xtensa-esp32s2-elf/esp-2020r3-8.4.0/xtensa-esp32s2-elf/bin/../lib/gcc/xtensa-esp32s2-elf/8.4.0/../../../../xtensa-esp32s2-elf/bin/ld: /home/gitlab-runner/builds/w2jWgEzx/0/adf/esp-adf-libs-source/esp_processing/esp-alc/src/esp_alc.c:274:(.text.alc_volume_setup_process+0x191): dangerous relocation: cannot decode instruction opcode: (.text.alc_volume_setup_process+0x197)
/home/schwm/.espressif/tools/xtensa-esp32s2-elf/esp-2020r3-8.4.0/xtensa-esp32s2-elf/bin/../lib/gcc/xtensa-esp32s2-elf/8.4.0/../../../../xtensa-esp32s2-elf/bin/ld: /home/schwm/Tools/esptools/esp-adf/components/esp-adf-libs/esp_codec/lib/esp32s2/libesp_processing.a(esp_alc.c.obj): in function `volume_amplify_mono':
/home/gitlab-runner/builds/w2jWgEzx/0/adf/esp-adf-libs-source/esp_processing/esp-alc/src/esp_alc.c:362:(.text.alc_volume_setup_process+0x1f6): dangerous relocation: cannot decode instruction opcode: (.text.alc_volume_setup_process+0x1fc)
/home/schwm/.espressif/tools/xtensa-esp32s2-elf/esp-2020r3-8.4.0/xtensa-esp32s2-elf/bin/../lib/gcc/xtensa-esp32s2-elf/8.4.0/../../../../xtensa-esp32s2-elf/bin/ld: /home/gitlab-runner/builds/w2jWgEzx/0/adf/esp-adf-libs-source/esp_processing/esp-alc/src/esp_alc.c:373:(.text.alc_volume_setup_process+0x224): dangerous relocation: cannot decode instruction opcode: (.text.alc_volume_setup_process+0x22a)
/home/schwm/.espressif/tools/xtensa-esp32s2-elf/esp-2020r3-8.4.0/xtensa-esp32s2-elf/bin/../lib/gcc/xtensa-esp32s2-elf/8.4.0/../../../../xtensa-esp32s2-elf/bin/ld: /home/gitlab-runner/builds/w2jWgEzx/0/adf/esp-adf-libs-source/esp_processing/esp-alc/src/esp_alc.c:374:(.text.alc_volume_setup_process+0x233): dangerous relocation: cannot decode instruction opcode: (.text.alc_volume_setup_process+0x244)
/home/schwm/.espressif/tools/xtensa-esp32s2-elf/esp-2020r3-8.4.0/xtensa-esp32s2-elf/bin/../lib/gcc/xtensa-esp32s2-elf/8.4.0/../../../../xtensa-esp32s2-elf/bin/ld: /home/gitlab-runner/builds/w2jWgEzx/0/adf/esp-adf-libs-source/esp_processing/esp-alc/src/esp_alc.c:378:(.text.alc_volume_setup_process+0x247): dangerous relocation: cannot decode instruction opcode: (.text.alc_volume_setup_process+0x294)
/home/schwm/.espressif/tools/xtensa-esp32s2-elf/esp-2020r3-8.4.0/xtensa-esp32s2-elf/bin/../lib/gcc/xtensa-esp32s2-elf/8.4.0/../../../../xtensa-esp32s2-elf/bin/ld: /home/gitlab-runner/builds/w2jWgEzx/0/adf/esp-adf-libs-source/esp_processing/esp-alc/src/esp_alc.c:415:(.text.alc_volume_setup_process+0x256): dangerous relocation: cannot decode instruction opcode: (.text.alc_volume_setup_process+0x25c)
/home/schwm/.espressif/tools/xtensa-esp32s2-elf/esp-2020r3-8.4.0/xtensa-esp32s2-elf/bin/../lib/gcc/xtensa-esp32s2-elf/8.4.0/../../../../xtensa-esp32s2-elf/bin/ld: /home/gitlab-runner/builds/w2jWgEzx/0/adf/esp-adf-libs-source/esp_processing/esp-alc/src/esp_alc.c:380:(.text.alc_volume_setup_process+0x29a): dangerous relocation: cannot decode instruction opcode: (.text.alc_volume_setup_process+0x2c0)
/home/schwm/.espressif/tools/xtensa-esp32s2-elf/esp-2020r3-8.4.0/xtensa-esp32s2-elf/bin/../lib/gcc/xtensa-esp32s2-elf/8.4.0/../../../../xtensa-esp32s2-elf/bin/ld: /home/gitlab-runner/builds/w2jWgEzx/0/adf/esp-adf-libs-source/esp_processing/esp-alc/src/esp_alc.c:394:(.text.alc_volume_setup_process+0x2c3): dangerous relocation: cannot decode instruction opcode: (.text.alc_volume_setup_process+0x24d)
/home/schwm/.espressif/tools/xtensa-esp32s2-elf/esp-2020r3-8.4.0/xtensa-esp32s2-elf/bin/../lib/gcc/xtensa-esp32s2-elf/8.4.0/../../../../xtensa-esp32s2-elf/bin/ld: /home/gitlab-runner/builds/w2jWgEzx/0/adf/esp-adf-libs-source/esp_processing/esp-alc/src/esp_alc.c:403:(.text.alc_volume_setup_process+0x2eb): dangerous relocation: cannot decode instruction opcode: (.text.alc_volume_setup_process+0x2f1)
/home/gitlab-runner/builds/w2jWgEzx/0/adf/esp-adf-libs-source/esp_processing/esp-alc/src/esp_alc.c:217:(.text.alc_volume_setup_process+0x30d): dangerous relocation: cannot decode instruction opcode: (.text.alc_volume_setup_process+0x313)
/home/schwm/.espressif/tools/xtensa-esp32s2-elf/esp-2020r3-8.4.0/xtensa-esp32s2-elf/bin/../lib/gcc/xtensa-esp32s2-elf/8.4.0/../../../../xtensa-esp32s2-elf/bin/ld: /home/gitlab-runner/builds/w2jWgEzx/0/adf/esp-adf-libs-source/esp_processing/esp-alc/src/esp_alc.c:219:(.text.alc_volume_setup_process+0x319): dangerous relocation: cannot decode instruction opcode: (.text.alc_volume_setup_process+0x341)
/home/schwm/.espressif/tools/xtensa-esp32s2-elf/esp-2020r3-8.4.0/xtensa-esp32s2-elf/bin/../lib/gcc/xtensa-esp32s2-elf/8.4.0/../../../../xtensa-esp32s2-elf/bin/ld: /home/gitlab-runner/builds/w2jWgEzx/0/adf/esp-adf-libs-source/esp_processing/esp-alc/src/esp_alc.c:233:(.text.alc_volume_setup_process+0x344): dangerous relocation: cannot decode instruction opcode: (.text.alc_volume_setup_process+0x34a)
/home/schwm/.espressif/tools/xtensa-esp32s2-elf/esp-2020r3-8.4.0/xtensa-esp32s2-elf/bin/../lib/gcc/xtensa-esp32s2-elf/8.4.0/../../../../xtensa-esp32s2-elf/bin/ld: /home/gitlab-runner/builds/w2jWgEzx/0/adf/esp-adf-libs-source/esp_processing/esp-alc/src/esp_alc.c:242:(.text.alc_volume_setup_process+0x370): dangerous relocation: cannot decode instruction opcode: (.text.alc_volume_setup_process+0x376)
/home/schwm/.espressif/tools/xtensa-esp32s2-elf/esp-2020r3-8.4.0/xtensa-esp32s2-elf/bin/../lib/gcc/xtensa-esp32s2-elf/8.4.0/../../../../xtensa-esp32s2-elf/bin/ld: /home/gitlab-runner/builds/w2jWgEzx/0/adf/esp-adf-libs-source/esp_processing/esp-alc/src/esp_alc.c:278:(.text.alc_volume_setup_process+0x399): dangerous relocation: cannot decode instruction opcode: (.text.alc_volume_setup_process+0x3a4)
/home/schwm/.espressif/tools/xtensa-esp32s2-elf/esp-2020r3-8.4.0/xtensa-esp32s2-elf/bin/../lib/gcc/xtensa-esp32s2-elf/8.4.0/../../../../xtensa-esp32s2-elf/bin/ld: /home/gitlab-runner/builds/w2jWgEzx/0/adf/esp-adf-libs-source/esp_processing/esp-alc/src/esp_alc.c:280:(.text.alc_volume_setup_process+0x3aa): dangerous relocation: cannot decode instruction opcode: (.text.alc_volume_setup_process+0x3d2)
/home/schwm/.espressif/tools/xtensa-esp32s2-elf/esp-2020r3-8.4.0/xtensa-esp32s2-elf/bin/../lib/gcc/xtensa-esp32s2-elf/8.4.0/../../../../xtensa-esp32s2-elf/bin/ld: /home/gitlab-runner/builds/w2jWgEzx/0/adf/esp-adf-libs-source/esp_processing/esp-alc/src/esp_alc.c:294:(.text.alc_volume_setup_process+0x3d5): dangerous relocation: cannot decode instruction opcode: (.text.alc_volume_setup_process+0x3db)
/home/schwm/.espressif/tools/xtensa-esp32s2-elf/esp-2020r3-8.4.0/xtensa-esp32s2-elf/bin/../lib/gcc/xtensa-esp32s2-elf/8.4.0/../../../../xtensa-esp32s2-elf/bin/ld: /home/gitlab-runner/builds/w2jWgEzx/0/adf/esp-adf-libs-source/esp_processing/esp-alc/src/esp_alc.c:303:(.text.alc_volume_setup_process+0x400): dangerous relocation: cannot decode instruction opcode: (.text.alc_volume_setup_process+0x406)
collect2: error: ld returned 1 exit status
ninja failed with exit code 1
What i am doing wrong ?
best regards
Code: Untitled.c Select all
