VSCode idf插件升级到0.6.0的问题
zlflove99
Postby zlflove99 » Mon Jan 11, 2021 2:01 pm
VSCode IDF插件升级到0.6.0后Monitor无法串口打印,退回到0.5.1后可正常打印,第一次点击出现如下的提示:
Code: Untitled.txt Select all
Windows PowerShell
版权所有 (C) Microsoft Corporation。保留所有权利。
尝试新的跨平台 PowerShell https://aka.ms/pscore6
PS D:\SelfSoftware\ESP32\UserProject\wear_levelling> $Env:Path = "
>> $Env:IDF_PATH = "
PS D:\SelfSoftware\ESP32\UserProject\wear_levelling> $Env:IDF_TARGET = "
>> $Env:PYTHON = "
PS D:\SelfSoftware\ESP32\UserProject\wear_levelling> $Env:IDF_PYTHON_ENV_PATH = "
>> cls
>> d:\SelfSoftware\ESP32\ESP_IDFTools\python_env\idf4.3_py3.9_env\Scripts\python.exe d:\SelfSoftware\ESP32\IDF_Master\esp-idf\tools\idf.py -p COM3 monitor
第二次点击出现如下的提示:
PS D:\SelfSoftware\ESP32\UserProject\wear_levelling> d:\SelfSoftware\ESP32\ESP_IDFTools\python_env\idf4.3_py3.9_env\Scripts\python.exe d:\SelfSoftware\ESP32\IDF_Master\esp-idf\tools\idf.py -p COM3 monitor
File "d:\SelfSoftware\ESP32\IDF_Master\esp-idf\tools\idf.py", line 805, in <module>
main()
File "d:\SelfSoftware\ESP32\IDF_Master\esp-idf\tools\idf.py", line 720, in main
checks_output = check_environment()
File "d:\SelfSoftware\ESP32\IDF_Master\esp-idf\tools\idf.py", line 77, in check_environment
debug_print_idf_version()
File "d:\SelfSoftware\ESP32\IDF_Master\esp-idf\tools\idf.py", line 126, in debug_print_idf_version
version = idf_version()
File "d:\SelfSoftware\ESP32\IDF_Master\esp-idf\tools\idf_py_actions\tools.py", line 54, in idf_version
version = subprocess.check_output([
File "C:\Users\ZLF\AppData\Local\Programs\Python\Python39\lib\subprocess.py", line 420, in check_output
return run(*popenargs, stdout=PIPE, timeout=timeout, check=True,
File "C:\Users\ZLF\AppData\Local\Programs\Python\Python39\lib\subprocess.py", line 501, in run
with Popen(*popenargs, **kwargs) as process:
File "C:\Users\ZLF\AppData\Local\Programs\Python\Python39\lib\subprocess.py", line 947, in __init__
self._execute_child(args, executable, preexec_fn, close_fds,
File "C:\Users\ZLF\AppData\Local\Programs\Python\Python39\lib\subprocess.py", line 1416, in _execute_child
hp, ht, pid, tid = _winapi.CreateProcess(executable, args,
FileNotFoundError: [WinError 2] 系统找不到指定的文件。
XLstone
Re: VSCode idf插件升级到0.6.0的问题
Postby XLstone » Sun Jan 17, 2021 5:06 am
我也是一样的问题,老哥你解决了吗?
day_day
Postby day_day » Sun Jan 24, 2021 12:45 pm
我在linux下开发。
先是装了从官网下的 esp-idf-v4.2.zip 包,装命令行方式开发的方法:https://blog.csdn.net/qq_34917736/artic ... /112546772
后来用 vscode Espressif IDF ,也是用 从官网下的 esp-idf-v4.2.zip 包,选择最下面的那个选项,直接导进去可以用。IDF tool 就是原本命令行安装在home/用户 目录下的.espressif 直接导进去。
第一次安装失败,python有些 依赖没下下来(很奇怪,命令行方式开发安装的时候已经通过pip换源把所有依赖都安装完了,怎么还会有依赖问题,而且还下不了?)又试了一次,莫名其妙成功了
