LOLIN D32 Pro V2.0.0 power/battery red LED keeps flashing quickly
marcmerlin
Postby marcmerlin » Sat Jan 16, 2021 2:47 am
I have some older versions of this board:
https://www.amazon.com/gp/product/B07QDFP3W
they work fine.
I bought some new ones, from 2 sources, and the red power LED keeps flashing at high speed when powered through USB. I think it's probably complaining about the lipo plugged into the port, except there is none, which is maybe what it's complaining about.
I haven't found a good way to contact lolin, so I'm asking here in case anyone knows.
becorey
Re: LOLIN D32 Pro V2.0.0 power/battery red LED keeps flashing quickly
Postby becorey » Sat Jan 16, 2021 7:30 am
The led is connected to TP4054 CHRG pin. With no battery connected, maybe it is doing the "charge complete / AC present" indicator of 20uA pull down.
Are you seeing a bright flash or very dim?
Maybe your usb port is doing something like switching on and off due to light load. Do different lolin boards show different led patterns?
Also there is another led on IO5, could that be the one you're seeing?
marcmerlin
Postby marcmerlin » Sat Jan 16, 2021 9:34 pm
Thanks for the reply. I'm seeing a bright flash. I get this on all 8 of my newer D32 Pros. It may be an issue/change with V2.0 and I probably had some V1.x before. It flashes between 6 and 8 times per second at fixed interval.
It is not the LED connected to IO5, the red LED flashes before any code has even had time to start, as soon as power is plugged in.
marcmerlin
Postby marcmerlin » Wed Feb 17, 2021 2:40 am
to close the loop, it's a change from the manufacturer, I think i'ts an unfortunate change, but it is what it is.
Users browsing this forum: Bytespider and 2 guests
