Hello everybody,
how can I add support for the idf spi-driver into bootloader?
I have a spi-sd-card driver (which already works in firmware) which I want to use in the bootloader.
I have added a custom bootloader into a project called "bldr".
Copied from /esp-idf/components/bootloader into my project: bldr/components/bootloader/
This works so far.
I have tried adding component "driver" (which includes spi-driver) in several CMakeLists.txt:
(1) into bldr/components/bootloader/CMakeLists.txt
add_dependencies(bootloader partition_table_bin driver)
This gave the error: The dependency target "driver" of target "bootloader" does not exist.
(2) into bldr/components/bootloader/subproject/CMakeLists.txt
set(COMPONENTS bootloader esptool_py partition_table soc bootloader_support log spi_flash micro-ecc main efuse driver)
esp-idf/esp-idf_Release_V4_2/components/esp_ringbuf/ringbuf.c:17:10: fatal error: freertos/FreeRTOS.h: No such file or directory
Greetings, Timm
Use of spi driver (+ freertos) in bootloader
Users browsing this forum: Amazon [Bot], ChatGPT-User, Semrush [Bot] and 1 guest
