Problems with sockets and HTTP server
eliott
Postby eliott » Mon Jan 25, 2021 8:19 pm
I'm using ESP http server for my application with multiple web pages (html, png, js, css...).
I'm also using UDP client and server. I noticed that after 4 http calls I'm unable to open udp client socket.
This is my script:
-> HTTP server host a page called "/devicescan", the javascript call wait until 5 seconds for timeout
-> On the HTTP "get handler": an UDP server is openned on port 2000
-> Then and UDP client is openned and send a string to all other devices on the network via IP 192.168.1.255
-> UDP client is immediately closed
-> If the devices are present they answer back to the ESP on port 2000.
-> The UDP server wait for answers during two seconds and generate a json array.
-> After 2 seconds the answer is transfered back to the HTTP server.
For the example I receive this:
{"scanlist":[{"name":"Dev1","ip":"192.168.1.193"},{"name":"Dev2","ip":"192.168.1.208"},{"name":"Dev3","ip":"192.168.1.221"}]}
The page "/devicescan" works 4 times, but after this I receive this error: "UDP CLIENT: unable to create socket: errno 23"
I also tryed to use different port for client/server (eg 1800 and 1900).
If I wait a while, this is working again. I don't think I forgot to close the UDP socket, but maybe I'm reaching a limit somewhere or maybe the HTTP socket are not closed properely. How I can monitor this ?
I also noticed that I have a similar issue when I'm using the HTTP client.
Please find my code below:
get_handler function for the page /devicescann:
static void page_devicescan(httpd_req_t *req)
	char data[768]; //!\ 66 chars par device * 10 = 660 + marges
	sprintf(data,"{\"scanlist\":[");
	udp_server_start(data, sizeof(data));
	strcat(data,"]}");
	display_page(req, data, strlen(data));
UDP client/server combined
#define PORT_CLIENT 1900
#define PORT_SERVER 1800
static const char *TAGCLIENT = "[UDP CLIENT]";
static const char *TAGSERVER = "[UDP SERVER]";
static const char *payload = "UDP /NOTIFY-V5\r\n";
static esp_err_t udp_client_receive()
    char addr_str[128];
    int addr_family;
    int ip_protocol;
	char *HOST_IP_ADRESS;
	HOST_IP_ADRESS=get_sta_ip();
	uint8_t i;
	for(i=strlen(HOST_IP_ADRESS); i>5; i--)
		if(*(HOST_IP_ADRESS+i)=='.') break;
	if(i==5)
		ESP_LOGI(TAGCLIENT, "Can't match network with IP %s",HOST_IP_ADRESS);
		return ESP_FAIL;
	else
		memcpy((HOST_IP_ADRESS+i+1),"255\0",4);
		ESP_LOGI(TAGCLIENT, "Network is %s",HOST_IP_ADRESS);
		struct sockaddr_in dest_addr;
		dest_addr.sin_addr.s_addr = inet_addr(HOST_IP_ADRESS);
		dest_addr.sin_family = AF_INET;
		dest_addr.sin_port = htons(PORT_CLIENT);
		addr_family = AF_INET;
		ip_protocol = IPPROTO_IP;
		inet_ntoa_r(dest_addr.sin_addr, addr_str, sizeof(addr_str) - 1);
		int sock = socket(addr_family, SOCK_DGRAM, ip_protocol);
		if (sock < 0)
			ESP_LOGE(TAGCLIENT, "Unable to create socket: errno %d", errno);
			return ESP_FAIL;
		else
			ESP_LOGI(TAGCLIENT, "Socket created, sending to %s:%d", HOST_IP_ADRESS, PORT_CLIENT);
			int err = sendto(sock, payload, strlen(payload), 0, (struct sockaddr *)&dest_addr, sizeof(dest_addr));
			if (err < 0)
				ESP_LOGE(TAGCLIENT, "Error occurred during sending: errno %d", errno);
			ESP_LOGI(TAGCLIENT, "Message sent");
			ESP_LOGI(TAGCLIENT, "Shutting down socket.");
			return ESP_OK;
		shutdown(sock, 0);
		close(sock);
void udp_server_start(char *scandata, uint16_t max_scandata_len)
	int32_t l_free;
	uint8_t is_first=1;
	char sep[]=",";
	char rx_buffer[128];
	char addr_str[128];
	//char tmp[50];
	int addr_family;
	int ip_protocol;
	struct timeval timeout={2,0}; //set timeout for 2 seconds
	dest_addr.sin_addr.s_addr = htonl(INADDR_ANY);
	dest_addr.sin_port = htons(PORT_SERVER);
	if (sock < 0)
		ESP_LOGE(TAGSERVER, "Unable to create socket: errno %d", errno);
	else
		ESP_LOGI(TAGSERVER, "Socket created");
		int err = bind(sock, (struct sockaddr *)&dest_addr, sizeof(dest_addr));
		if (err < 0)
			ESP_LOGE(TAGSERVER, "Socket unable to bind: errno %d", errno);
		else
			ESP_LOGI(TAGSERVER, "Socket bound, port %d", PORT_SERVER);
			setsockopt(sock,SOL_SOCKET,SO_RCVTIMEO,(char*)&timeout,sizeof(struct timeval));
			if(udp_client_receive()==ESP_OK)
				while (1)
					ESP_LOGI(TAGSERVER, "Waiting for data");
					struct sockaddr_in6 source_addr; // Large enough for both IPv4 or IPv6
					socklen_t socklen = sizeof(source_addr);
					int len = recvfrom(sock, rx_buffer, sizeof(rx_buffer) - 1, 0, (struct sockaddr *)&source_addr, &socklen);
					// Error occurred during receiving
					if (len < 0) {
						ESP_LOGE(TAGSERVER, "recvfrom failed: errno %d", errno);
					// Data received
					else
						// Get the sender's ip address as string
						if (source_addr.sin6_family == PF_INET)
							inet_ntoa_r(((struct sockaddr_in *)&source_addr)->sin_addr.s_addr, addr_str, sizeof(addr_str) - 1);
						else if (source_addr.sin6_family == PF_INET6)
							inet6_ntoa_r(source_addr.sin6_addr, addr_str, sizeof(addr_str) - 1);
						rx_buffer[len] = 0; // Null-terminate whatever we received and treat like a string...
						ESP_LOGI(TAGSERVER, "Received %d bytes from %s:", len, addr_str);
						ESP_LOGI(TAGSERVER, "%s", rx_buffer);
						if(strncmp(rx_buffer,"name=",5)==0 && strlen(rx_buffer)<=25)
							l_free=max_scandata_len-(30+len+strlen(addr_str)+strlen(scandata)+1);
							ESP_LOGI(TAGSERVER, "Free scanbuffer: %d of %d ",l_free, max_scandata_len);
							if(l_free<=0)
								ESP_LOGE(TAGSERVER, "Can't add aditionnal data, scanbuffer is full");
						else
							ESP_LOGE(TAGSERVER, "Invalid data returned");
						if(is_first==0) strcat(scandata,sep);
						sprintf(scandata+strlen(scandata),"{\"name\":\"%s\",\"ip\":\"%s\"}",&rx_buffer[5],addr_str);
						is_first=0;
						int err = sendto(sock, rx_buffer, len, 0, (struct sockaddr *)&source_addr, sizeof(source_addr));
						if (err < 0)
							ESP_LOGE(TAGSERVER, "Error occurred during sending: errno %d", errno);
				ESP_LOGI(TAGSERVER, "Shutting down socket.");
			else
				ESP_LOGE(TAGSERVER, "Shutting down socket cause client errors");
	shutdown(sock, 0);
	close(sock);
Thank you for help.
eliott
Re: Problems with sockets and HTTP server
Postby eliott » Tue Jan 26, 2021 9:58 pm
Hello again,
I took back the exemple of udp_client and coded my function with a bind() to allocate source port. This way I don't have to create a udp client/server I only use an udp client with the good source port I'm compatible with my devices who expect data on specific port.
I really don't hunderstand the link with RTOS task and sockets:
If I start a task, open, use data in/out and close a socket, I can execute my function many times.
If I start a task, open, use data in/out and close a socket, close the task, then open again the task I get errno 118.
Maybe it's a init problem, but I initialised all my data to "0" includes structures...
Please find my simplified code to expose the problem:
This code working, without closing the task:
static void udp_client_task(void *pvParameters)
	//vars init
	while(1)
		//function call
		int sock = socket()		//open socket
		if (sock < 0) { ESP_LOGE(TAG, "Unable to create socket: errno %d", errno); break; }
		ESP_LOGI(TAG, "Socket created, sending to %s:%d", HOST_IP_ADRESS, PORT_TO);
		while (1)
			int err = sendto() //send data
			if (err < 0) { ESP_LOGE(TAG, "Error occurred during sending: errno %d", errno); break; }
			ESP_LOGI(TAG, "Message sent");
			len=recvfrom()
			if (len < 0)
				ESP_LOGE(TAG, "recvfrom failed: errno %d", errno);
				break;//stop the task
			else
				ESP_LOGI(TAG, "Received %d bytes from %s:", len, addr_str);
		if (sock != -1) {
			ESP_LOGE(TAG, "Sock == %d. Shutting down socket and restarting...",sock);
			shutdown(sock, 2);
			close(sock);
		//IF I CLOSE THE TASK HERE WITH vTaskDelete(NULL); AND RESTART IT by calling "init_udp()", I CAN'T SEND ANYMORE UDP DATA
		//IS THAT BECAUSE THE OLD AND NEX TASK HAS THE SAME NAME ?
	vTaskDelete(NULL);
void init_udp()
	xTaskCreate(udp_client_task, "udp_client", 4096, NULL, 5, NULL);
LOG working code:
I (455404) [UDP CLIENT]: Socket created, sending to 192.168.1.255:1900
I (456664) [HTTPD GET]: File name: /devicescan
I (456664) [HTTPD GET]: Send 16 bytes (UDP /NOTIFY-V5
) to app_udp_send
I (457404) [UDP CLIENT]: Message sent
I (457684) [UDP CLIENT]: Received 10 bytes from 192.168.1.221:
I (457684) [UDP CLIENT]: UDP /221
I (457684) [UDP CLIENT]: Received 10 bytes from 192.168.1.193:
I (457694) [UDP CLIENT]: UDP /193
I (457694) [UDP CLIENT]: Received 10 bytes from 192.168.1.208:
I (457704) [UDP CLIENT]: UDP /208
E (459704) [UDP CLIENT]: recvfrom failed: errno 11
E (459704) [UDP CLIENT]: Sock == 58. Shutting down socket and restarting...
I (459704) [UDP CLIENT]: Socket created, sending to 192.168.1.255:1900
I (460144) [HTTPD GET]: File name: /devicescan
I (460144) [HTTPD GET]: Send 16 bytes (UDP /NOTIFY-V5
) to app_udp_send
I (461704) [UDP CLIENT]: Message sent
I (461984) [UDP CLIENT]: Received 10 bytes from 192.168.1.221:
I (461984) [UDP CLIENT]: UDP /221
I (461984) [UDP CLIENT]: Received 10 bytes from 192.168.1.193:
I (461994) [UDP CLIENT]: UDP /193
E (463994) [UDP CLIENT]: recvfrom failed: errno 11
E (463994) [UDP CLIENT]: Sock == 58. Shutting down socket and restarting...
I (463994) [UDP CLIENT]: Socket created, sending to 192.168.1.255:1900
I (465064) [HTTPD GET]: File name: /devicescan
I (465064) [HTTPD GET]: Send 16 bytes (UDP /NOTIFY-V5
) to app_udp_send
I (465994) [UDP CLIENT]: Message sent
I (466284) [UDP CLIENT]: Received 10 bytes from 192.168.1.193:
I (466284) [UDP CLIENT]: UDP /193
I (466294) [UDP CLIENT]: Received 10 bytes from 192.168.1.208:
I (466294) [UDP CLIENT]: UDP /208
I (466294) [UDP CLIENT]: Received 10 bytes from 192.168.1.221:
I (466304) [UDP CLIENT]: UDP /221
E (468304) [UDP CLIENT]: recvfrom failed: errno 11
E (468304) [UDP CLIENT]: Sock == 58. Shutting down socket and restarting...
I (468304) [UDP CLIENT]: Socket created, sending to 192.168.1.255:1900
I (469574) [HTTPD GET]: File name: /devicescan
I (469574) [HTTPD GET]: Send 16 bytes (UDP /NOTIFY-V5
) to app_udp_send
I (470304) [UDP CLIENT]: Message sent
I (470584) [UDP CLIENT]: Received 10 bytes from 192.168.1.221:
I (470584) [UDP CLIENT]: UDP /221
I (470584) [UDP CLIENT]: Received 10 bytes from 192.168.1.193:
I (470594) [UDP CLIENT]: UDP /193
I (470594) [UDP CLIENT]: Received 10 bytes from 192.168.1.208:
I (470604) [UDP CLIENT]: UDP /208
E (472604) [UDP CLIENT]: recvfrom failed: errno 11
E (472604) [UDP CLIENT]: Sock == 58. Shutting down socket and restarting...
I (472604) [UDP CLIENT]: Socket created, sending to 192.168.1.255:1900
LOG not working code:
I (1764) [WIFI]: got ip:192.168.1.244
I (1764) [WIFI]: connect to the AP success
I (1764) [TIME]: Timezone loaded from NVS: -1
I (1764) [TIME]: Timezone set to UTC-1
I (1774) tcpip_adapter: sta ip: 192.168.1.244, mask: 255.255.255.0, gw: 192.168.1.254
I (8734) [HTTPD GET]: File name: /createtask
I (8734) [UDP CLIENT]: Network is 192.168.1.255
I (8744) [UDP CLIENT]: Socket created, sending to 192.168.1.255:1900
I (11994) [HTTPD GET]: File name: /devicescan
I (11994) [HTTPD GET]: Send 16 bytes (UDP /NOTIFY-V5
) to app_udp_send
I (12744) [UDP CLIENT]: Message sent
I (13014) [UDP CLIENT]: Received 10 bytes from 192.168.1.221:
I (13014) [UDP CLIENT]: UDP /221
I (13024) [UDP CLIENT]: Received 10 bytes from 192.168.1.208:
I (13024) [UDP CLIENT]: UDP /208
I (13024) [UDP CLIENT]: Received 10 bytes from 192.168.1.193:
I (13034) [UDP CLIENT]: UDP /193
E (15034) [UDP CLIENT]: recvfrom failed: errno 11
E (15034) [UDP CLIENT]: Sock == 59. Shutting down socket and restarting...
I (27974) [HTTPD GET]: File name: /createtask
I (27974) [UDP CLIENT]: Network is 192.168.1.255
I (27974) [UDP CLIENT]: Socket created, sending to 192.168.1.255:1900
I (30834) [HTTPD GET]: File name: /devicescan
I (30834) [HTTPD GET]: Send 16 bytes (UDP /NOTIFY-V5
) to app_udp_send
E (31974) [UDP CLIENT]: Error occurred during sending: errno 118
E (31974) [UDP CLIENT]: Sock == 59. Shutting down socket and restarting...
Thank you for help.
Postby Sprite » Wed Jan 27, 2021 12:40 am
Can you post your *actual* code instead, if possible whittled down to something as small as possible that still exhibits the issue? What you posted unfortunately is simplified to the point of uselessness.
eliott
Postby eliott » Thu Jan 28, 2021 11:12 pm
this is my full code *blocking code* with no sys task, unable to run twice cause errno 23;
 (6771) [HTTPD GET]: File name: /images/NavCron.png
I (6791) [HTTPD GET]: File name: /wifistatus
I (8461) [HTTPD GET]: File name: /devicelist
I (8471) [HTTPD GET]: File name: /devicescan
I (8471) [UDP CLIENT]: Network is 192.168.1.255
I (8471) [UDP CLIENT]: Socket created, sending to 192.168.1.255:2000
I (8481) [UDP CLIENT]: Message sent
I (8861) [UDP CLIENT]: Received 11 bytes from 192.168.1.183:
I (8861) [UDP CLIENT]: name=Bureau
I (8871) [UDP CLIENT]: Free scanbuffer: 700 of 768
E (10871) [UDP CLIENT]: recvfrom failed: errno 11
E (10871) [UDP CLIENT]: Sock == 63. Shutting down socket and restarting...
I (15631) [HTTPD GET]: File name: /devicescan
I (15631) [UDP CLIENT]: Network is 192.168.1.255
I (15631) [UDP CLIENT]: Socket created, sending to 192.168.1.255:2000
E (15631) [UDP CLIENT]: Error occurred during sending: errno 118
I (15651) [HTTPD GET]: File name: /devicelist
I (19111) [HTTPD GET]: File name: /devicescan
I (19111) [UDP CLIENT]: Network is 192.168.1.255
E (19111) [UDP CLIENT]: Unable to create socket: errno 23
I (19121) [HTTPD GET]: File name: /devicelist
I (21571) [HTTPD GET]: File name: /devicescan
I (21571) [UDP CLIENT]: Network is 192.168.1.255
E (21571) [UDP CLIENT]: Unable to create socket: errno 23
I (21581) [HTTPD GET]: File name: /devicelist
I (23821) [HTTPD GET]: File name: /images/IconLoader.gif
I (23841) [HTTPD GET]: File name: /devicescan
I (23841) [UDP CLIENT]: Network is 192.168.1.255
E (23841) [UDP CLIENT]: Unable to create socket: errno 23
I (23851) [HTTPD GET]: File name: /devicelist
#define PORT_TO 2000
#define PORT_FROM 2000
static const char *TAG = "[UDP CLIENT]";
esp_err_t app_udp_send(char * payload, size_t len, char * scandata, uint16_t max_scandata_len)
	char rx_buffer[128]={0};
	char addr_str[128]={0};
	int addr_family=0;
	int ip_protocol=0;
	uint8_t is_first=1;
	int32_t l_free;
	char sep[]=",";
	uint8_t i;
	if(i==5)
		ESP_LOGI(TAG, "Can't match network with IP %s",HOST_IP_ADRESS);
		return ESP_FAIL;
	else
		//set source port
		struct sockaddr_in from_addr;
		memset(&from_addr, 0, sizeof(from_addr));
		from_addr.sin_addr.s_addr = inet_addr(HOST_IP_ADRESS);
		from_addr.sin_family = AF_INET;
		from_addr.sin_port = htons(PORT_FROM);
		ESP_LOGI(TAG, "Network is %s",HOST_IP_ADRESS);
		memset(&dest_addr, 0, sizeof(dest_addr));
		dest_addr.sin_port = htons(PORT_TO);
		if (sock < 0)
			return ESP_FAIL;
		bind(sock, (struct sockaddr *)&from_addr, sizeof(struct sockaddr)); //set source port
		setsockopt(sock,SOL_SOCKET,SO_RCVTIMEO,(char*)&timeout,sizeof(struct timeval)); //set timeout 2 secs
		if (err < 0)
			return ESP_FAIL;
		while (1)
			struct sockaddr_in source_addr; // Large enough for both IPv4 or IPv6
			if (len < 0)
			// Data received
			else
				if (source_addr.sin_family == PF_INET)
				else if (source_addr.sin_family == PF_INET6)
					inet6_ntoa_r(source_addr.sin_addr, addr_str, sizeof(addr_str) - 1);
				ESP_LOGI(TAG, "%s", rx_buffer);
					ESP_LOGI(TAG, "Free scanbuffer: %d of %d ",l_free, max_scandata_len);
					if(l_free<=0)
						ESP_LOGE(TAG, "Can't add aditionnal data, scanbuffer is full");
					is_first=0;
				else
					ESP_LOGE(TAG, "Invalid data returned");
		if (sock != -1)
			shutdown(sock, 2);
			close(sock);
		if(errno!=11)
			return ESP_FAIL;
		else
			return ESP_OK;
Thank you.
Postby Sprite » Fri Jan 29, 2021 6:48 am
That still is not something where 1. I can look at how you start up and kill your tasks, or 2. that I can put in an ESP32 here to try and replicate the issue.
eliott
Postby eliott » Fri Jan 29, 2021 7:17 pm
I changed my code with minimum function for udp_app. Working with call function in main.
I put my previous code, working now, I really don't hunderstand the difference, certainly a full clean helped.
I noticed that my bind is working once, after sending from "PORT_FROM" = 2100 the port is incremented: 60226,20227,62228 etc...
Maybe it was the source of the problem ?
		//set source port
Users browsing this forum: ChatGPT-User and 7 guests
