Hey,
I tried to use UART DMA on lowest level (using only registers, because of performance reasons), which also works. But I cannot change the idle time of the UART DMA. It seems that the idle time is fixed to 185 bytes. I have activated this idle time by setting UHCI.uart_idle_eof_en, but did not found anything related to change the idle time to my use cases.
Best Regards
trawgz
UART DMA Change Idle Time
Re: UART DMA Change Idle Time
Problem solved - Never searched in UART struct for something related to this (UART.idle_conf.rx_idle_thrhd).
Hi Trawgz,
would you please share any example on how to configure UART with DMA
best regards,
Elhawy
best regards,
Elhawy
Users browsing this forum: ChatGPT-User, meta-externalagent, PetalBot, Qwantbot and 6 guests
