Any risk to have the esp32 stuck in case of power on reset problems ?
charles-edouard
Postby charles-edouard » Fri Feb 12, 2021 11:18 am
From what I understand from the datasheets, there is a risk to have boot failure if the esp32 is connected to a battery / power source that is near the voltage limit of the esp32, and if no supply voltage supervisor is used to control the EN pin.
However, I was wondering exactly what is the criticality of having the esp32 switching on/off and having power on reset failure.
1) Is there a risk to have the esp32 stuck ?
If for example, there is a boot failure, and that the supply voltage becomes stable, will the esp32 will be rebooted automatically by the internal watchdog ?
Is there a risk to have the watchdog badly initialized because of a bad power on reset, and having the esp32 that will stay into its error without being rebooted ?
2) Why is it a problem ?
I understand that the ESP32 will continuously switch ON and OFF, and have power on failure.
On my application (stateless, reading sensors data and sending them to a server over wifi), I don't however see why it is a problem.
Thanks,
Charles
Minatel
Re: Any risk to have the esp32 stuck in case of power on reset problems ?
Postby Minatel » Thu Feb 18, 2021 11:37 am
To avoid that (critical low voltage) we have the Brownout detector. See reference: Brownout
You can change the voltage threshold in the project configuration using menuconfig.
