U8G2: spi_bus_initialize(500): intr flag not allowed
colinives
Postby colinives » Tue Mar 09, 2021 3:54 pm
Hi there,
Running a Devkit Wrover B using VSCode getting the U8G2 example code running an SPI SSD1306 - tested the board with Arduino and sample code there and it all works fine.
When trying to get it working for my main project:
Example code:
#include <driver/gpio.h>
#include <driver/spi_master.h>
#include <esp_log.h>
#include <freertos/FreeRTOS.h>
#include <freertos/task.h>
#include <stdio.h>
#include <string.h>
#include <u8g2.h>
#include "driver/spi_master.h"
#include "sdkconfig.h"
#include "u8g2_esp32_hal.h"
#define PIN_CLK   18  // CLK   - GPIO14
#define PIN_MOSI  23  // MOSI  - GPIO 13
#define PIN_RESET 0  // RESET - GPIO 26
#define PIN_DC    4  // DC    - GPIO 27
#define PIN_CS    12  // CS    - GPIO 15
static char tag[] = "test_SSD1306";
void task_test_SSD1306(void *ignore) {
	u8g2_esp32_hal_t u8g2_esp32_hal = U8G2_ESP32_HAL_DEFAULT;
	u8g2_esp32_hal.clk   = PIN_CLK;
	u8g2_esp32_hal.mosi  = PIN_MOSI;
	u8g2_esp32_hal.cs    = PIN_CS;
	u8g2_esp32_hal.dc    = PIN_DC;
	u8g2_esp32_hal.reset = PIN_RESET;
	u8g2_esp32_hal_init(u8g2_esp32_hal);
	u8g2_t u8g2;
		ESP_LOGI(tag, "SetupDisplay!");
		u8g2_Setup_ssd1306_128x64_noname_f(
		&u8g2,
		U8G2_R0,
		u8g2_esp32_spi_byte_cb,
		u8g2_esp32_gpio_and_delay_cb);
	u8g2_t u8g2;
		&u8g2,
		U8G2_R0,
	u8g2_InitDisplay(&u8g2); // send init sequence to the display, display is in sleep mode after this,
	u8g2_SetPowerSave(&u8g2, 0); // wake up display
	u8g2_ClearBuffer(&u8g2);
	u8g2_DrawBox(&u8g2, 10,20, 20, 30);
	u8g2_SetFont(&u8g2, u8g2_font_ncenB14_tr);
	u8g2_DrawStr(&u8g2, 0,15,"Hello World!");
	u8g2_SendBuffer(&u8g2);
	ESP_LOGD(tag, "All done!");
	vTaskDelete(NULL);
I get the following error:
E (348) spi: spi_bus_initialize(500): intr flag not allowed
E (358) err: esp_err_t = 258
assertion "0 && "spi_bus_initialize(HSPI_HOST, &bus_config, 1)"" failed: file "../main/u8g2_esp32_hal.c", line 56, function: u8g2_esp32_spi_byte_cb
The follow debug here:
ets Jun  8 2016 00:22:57
flash read err, 1000
ets_main.c 371
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0030,len:6972
ho 0 tail 12 room 4
load:0x40078000,len:14336
load:0x40080400,len:3672
0x40080400: _init at ??:?
entry 0x40080678
I (29) boot: ESP-IDF v4.4-dev-4-g73db14240 2nd stage bootloader
I (29) boot: compile time 15:43:47
I (29) boot: chip revision: 1
I (33) boot_comm: chip revision: 1, min. bootloader chip revision: 0
I (40) boot.esp32: SPI Speed      : 40MHz
I (45) boot.esp32: SPI Mode       : DIO
I (49) boot.esp32: SPI Flash Size : 16MB
I (54) boot: Enabling RNG early entropy source...
I (59) boot: Partition Table:
I (63) boot: ## Label            Usage          Type ST Offset   Length
I (70) boot:  0 nvs              WiFi data        01 02 00009000 00006000
I (78) boot:  1 phy_init         RF data          01 01 0000f000 00001000
I (85) boot:  2 factory          factory app      00 00 00010000 00100000
I (93) boot: End of partition table
I (97) boot_comm: chip revision: 1, min. application chip revision: 0
I (104) esp_image: segment 0: paddr=00010020 vaddr=3f400020 size=09f4ch ( 40780) map
I (127) esp_image: segment 1: paddr=00019f74 vaddr=3ffbdb60 size=02ba4h ( 11172) load
I (131) esp_image: segment 2: paddr=0001cb20 vaddr=40080000 size=034f8h ( 13560) load
I (138) esp_image: segment 3: paddr=00020020 vaddr=400d0020 size=1a81ch (108572) map
I (179) esp_image: segment 4: paddr=0003a844 vaddr=400834f8 size=09818h ( 38936) load
I (203) boot: Loaded app from partition at offset 0x10000
I (203) boot: Disabling RNG early entropy source...
I (214) cpu_start: Pro cpu up.
I (214) cpu_start: Starting app cpu, entry point is 0x40081150
0x40081150: call_start_cpu1 at /Users/colinives/esp/esp-idf/components/esp_system/port/cpu_start.c:143
I (0) cpu_start: App cpu up.
I (228) cpu_start: Pro cpu start user code
I (229) cpu_start: cpu freq: 160000000
I (229) cpu_start: Application information:
I (233) cpu_start: Project name:     switch
I (238) cpu_start: App version:      2.1
I (242) cpu_start: Compile time:     Mar  9 2021 15:43:27
I (249) cpu_start: ELF file SHA256:  1194fa2d6c78e63f...
I (255) cpu_start: ESP-IDF:          v4.4-dev-4-g73db14240
I (261) heap_init: Initializing. RAM available for dynamic allocation:
I (268) heap_init: At 3FFAE6E0 len 0000F480 (61 KiB): DRAM
I (274) heap_init: At 3FFC1AA0 len 0001E560 (121 KiB): DRAM
I (280) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (287) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (293) heap_init: At 4008CD10 len 000132F0 (76 KiB): IRAM
I (300) spi_flash: detected chip: gd
I (304) spi_flash: flash io: dio
I (309) cpu_start: Starting scheduler on PRO CPU.
I (318) test_SSD1306: Display
I (318) gpio: GPIO[0]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 1| Intr:0
I (328) gpio: GPIO[4]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 1| Intr:0
I (338) gpio: GPIO[12]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 1| Intr:0
abort() was called at PC 0x400dae73 on core 0
0x400dae73: __assert_func at /builds/idf/crosstool-NG/.build/HOST-x86_64-apple-darwin12/xtensa-esp32-elf/src/newlib/newlib/libc/stdlib/assert.c:62 (discriminator 8)
Backtrace:0x40085973:0x3ffb23b0 0x40085fbd:0x3ffb23d0 0x4008bc12:0x3ffb23f0 0x400dae73:0x3ffb2460 0x400d5e5e:0x3ffb2490 0x400d680b:0x3ffb2500 0x400d612a:0x3ffb2520 0x400d6b01:0x3ffb2540 0x400e99dd:0x3ffb2560 0x400d5d68:0x3ffb2580 0x400d5daf:0x3ffb2670 0x400ea560:0x3ffb2690 0x4008907d:0x3ffb26b0
0x40085973: panic_abort at /Users/colinives/esp/esp-idf/components/esp_system/panic.c:356
0x40085fbd: esp_system_abort at /Users/colinives/esp/esp-idf/components/esp_system/system_api.c:112
0x4008bc12: abort at /Users/colinives/esp/esp-idf/components/newlib/abort.c:46
0x400d5e5e: u8g2_esp32_spi_byte_cb at /Users/colinives/esp/u8g2-esp_idf-example/build/../main/u8g2_esp32_hal.c:56 (discriminator 5)
0x400d680b: u8x8_cad_001 at /Users/colinives/esp/esp-idf/esp-rainmaker/components/u8g2/csrc/u8x8_cad.c:309
0x400d612a: u8x8_d_helper_display_init at /Users/colinives/esp/esp-idf/esp-rainmaker/components/u8g2/csrc/u8x8_display.c:68
0x400d6b01: u8x8_d_ssd1306_128x64_noname at /Users/colinives/esp/esp-idf/esp-rainmaker/components/u8g2/csrc/u8x8_d_ssd1306_128x64_noname.c:321
0x400e99dd: u8x8_InitDisplay at /Users/colinives/esp/esp-idf/esp-rainmaker/components/u8g2/csrc/u8x8_display.c:100
0x400d5d68: appDisplay at /Users/colinives/esp/u8g2-esp_idf-example/build/../main/main.c:78
0x400d5daf: app_main at /Users/colinives/esp/u8g2-esp_idf-example/build/../main/main.c:51
0x400ea560: main_task at /Users/colinives/esp/esp-idf/components/freertos/port/port_common.c:133 (discriminator 2)
0x4008907d: vPortTaskWrapper at /Users/colinives/esp/esp-idf/components/freertos/port/xtensa/port.c:168
Entering gdb stub now.
$T0b#e6GNU gdb (crosstool-NG esp-2020r3) 8.1.0.20180627-git
Copyright (C) 2018 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.  Type "show copying"
and "show warranty" for details.
This GDB was configured as "--host=x86_64-host_apple-darwin12 --target=xtensa-esp32-elf".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/>.
Find the GDB manual and other documentation resources online at:
<http://www.gnu.org/software/gdb/documentation/>.
For help, type "help".
Type "apropos word" to search for commands related to "word"...
Reading symbols from /Users/colinives/esp/u8g2-esp_idf-example/build/switch.elf...done.
Remote debugging using /dev/cu.usbserial-11330
0x40085976 in panic_abort (details=0x3ffb23fb "abort() was called at PC 0x400dae73 on core 0")
    at /Users/colinives/esp/esp-idf/components/esp_system/panic.c:367
367         *((int *) 0) = 0; // NOLINT(clang-analyzer-core.NullDereference) should be an invalid operation on targets
(gdb)
Does anyone know where to look to find the problem?
I've seen a few examples of the init implementation:
	u8g2_t u8g2;
		&u8g2,
		U8G2_R0,
But none of them have worked.
Any pointers gratefully received.
Thank you
colinives
Re: U8G2: spi_bus_initialize(500): intr flag not allowed
Postby colinives » Tue Mar 09, 2021 4:30 pm
Fast and awesome result. Amazing - I need to look at why now!
I thought I had the latest version!
Thanks again
Users browsing this forum: Applebot, ChatGPT-User, PetalBot and 1 guest
