I have used NTP configurations to set time and it works fine without any issue. But, I need total List of Timezone configurations used for all over world to set time for any specific area.
Right Now, I have used following configurations as per my requirement.
// Set timezone to UTC Time
setenv("TZ", "UTC", 1);
// Set timezone to Indian Standard Time
setenv("TZ", "UTC+05:30", 1);
// Set timezone to Eastern Standard Time
setenv("TZ", "EST5EDT,M3.2.0/2,M11.1.0", 1);
// Set timezone to China Standard Time
setenv("TZ", "CST-8CDT-9,M4.2.0/2,M9.2.0/3", 1);
So, Please provide me List of standard timezone to be used world wide to set corresponding time according to setenv API. Also, Let me know if anyone has included all those timezones into single array because our application can be used in any place across world and we want to configured timezone according to that from application.
Let me know if anyone has any confusion for above use-case.
Need Help for NTP Configurations for ESP32
Re: Need Help for NTP Configurations for ESP32
This is likely what you are looking for:
https://www.iana.org/time-zones
This was referenced here:
https://www.gnu.org/software/libc/manua ... iable.html
Thanks for providing informations.This is likely what you are looking for:
I will check and will let you know if need any further help for that.
Regards,
Ritesh Prajapati
Ritesh Prajapati
We just created a GitHub project to maintain posix time zone strings DB.
https://github.com/nayarsystems/posix_tz_db
- martinayotte
jaracil: this is super useful, thank you for sharing. Would you mind to amend Readme mentioning what license is the project distributed under?
Same TZ as Toronto, right? To have the most compact db you only want to list the largest city per time zone. Although there are 8 cities listed in Indiana for some reason.The DB is missing "America/Montreal" ...
martinayotte: Added America/Montreal.
ESP_Igrr: Just Added LICENSE file (MIT).
- martinayotte
Thanks, jaracil !
https://www.timeanddate.com/time/map/
Right ! But the same is true for Ottawa/Detroit/Boston/Washington/New York/Philadelphia/Atlanta/Indianapolis/Miami ...Same TZ as Toronto, right?
Right but these are not on the list either Ottawa/Boston/Washington/Philadelphia/Atlanta/Miami
To make it as compact as possible, it should be only one listing per time zone per country/region and use the largest city.
