Compilation of RISC-V .c file results in errors
nvtby_espf
Contact:
Postby nvtby_espf » Mon Mar 22, 2021 1:25 pm
Hi!
I've a problem with compilation of .c file for ESP32-S2 for ULP-RISC-V. I suppose build system doesn't treat .c file as expected. Here's excerpt from the log:
>idf.py build
[4/385] Performing build step for 'ulp_main'
FAILED: esp-idf/main/ulp_main-prefix/src/ulp_main-stamp/ulp_main-build ... riscv-single/build/esp-idf/main/ulp_main --target build"
[1/6] Generating x_inc.ulp.S
[2/6] Building ASM object CMakeFiles/ulp_main.dir/x_inc.ulp.S.obj
FAILED: CMakeFiles/ulp_main.dir/x_inc.ulp.S.obj
esp32s2ulp-elf-as ...  -o CMakeFiles/ulp_main.dir/x_inc.ulp.S.obj -c x_inc.ulp.S
x_inc.ulp.S: Assembler messages:
x_inc.ulp.S:1: Error: syntax error. Input text was typedef.
x_inc.ulp.S:2: Error: syntax error. Input text was typedef.
x_inc.ulp.S:67: Error:
x_inc.ulp.S:68: Error: syntax error. Input text was }.
[6/385] Building C object esp-idf/app_update/CMakeFiles/__idf_app_update.dir/esp_app_desc.c.obj
ninja failed with exit code 1
The RISC-V file "main/ulp/x_inc.c" is pretty simple:
#include <stdint.h>
volatile unsigned int edge_count;
int main (void)
    edge_count += 33;
    return 0;
The file in question "riscv-single/build/esp-idf/main/ulp_main/x_inc.ulp.S" looks like this:
typedef signed char __int8_t;
typedef unsigned char __uint8_t;
typedef __int8_t int8_t ;
typedef __uint8_t uint8_t ;
  typedef long long unsigned int uint_fast64_t;
int main (void)
    edge_count += 33;
    return 0;
From my point it looks like misconfiguration of ESP-IDF but I have no idea what. I employ version 4.2 on Windows 10. Here's what has been installed:
>idf_tools.py list
* xtensa-esp32-elf: Toolchain for Xtensa (ESP32) based on GCC
  - esp-2020r3-8.4.0 (recommended, installed)
* xtensa-esp32s2-elf: Toolchain for Xtensa (ESP32-S2) based on GCC
* esp32ulp-elf: Toolchain for ESP32 ULP coprocessor
  - 2.28.51-esp-20191205 (recommended, installed)
* esp32s2ulp-elf: Toolchain for ESP32-S2 ULP coprocessor
* cmake: CMake build system
  - 3.16.4 (recommended, installed)
* openocd-esp32: OpenOCD for ESP32
  - v0.10.0-esp32-20200709 (recommended, installed)
* ninja: Ninja build system
  - 1.10.0 (recommended, installed)
* idf-exe: IDF wrapper tool for Windows
  - 1.0.1 (recommended, installed)
* ccache: Ccache (compiler cache)
  - 3.7 (recommended, installed)
* dfu-util: dfu-util (Device Firmware Upgrade Utilities)
  - 0.9 (recommended, installed)
From a sample on the forum for Kaluga board (https://github.com/Ebiroll/esp32s2_kalu ... ple_main.c) everything is fine. Some people recommend installing toolchain "riscv-none-embed-gcc" but this information doesn't help. Also, include files in working examples refer to "esp32s2/ulp_riscv.h" but I can't find such file in the installation "esp-idf/components/...". And, the doc hints to set option "CONFIG_ESP32S2_ULP_COPROC_RISCV=y" but there's no such option in menuconfig. Manual setting of it in "sdkconfig.defaults" has no effect.
The main question is: Is RISC-V supported in version 4.2 or after?
Does it require extra installation efforts beyond default setup?
Does it needs another commands to build?
Please help. Any idea matters.
Thank you
Angus
Re: Compilation of RISC-V .c file results in errors
Postby Angus » Tue Mar 23, 2021 2:04 am
Hi nvtby,
Sorry for all the trouble you've had with this.
There are 3 things going on here:
1) ESP-IDF v4.2 doesn't support the RISC-V ULP in ESP32-S2. This support will be added in the v4.3 release, so at present your best options are to git checkout either "v4.3-beta1" or "master" branch and build from there.
2) In the case of your project using ESP-IDF v4.2, the "FSM ULP" toolchain is being used. The ESP32-S2 has two ULPs: the very simple FSM ULP (almost the same as ESP32 ULP), and the RISC-V ULP. FSM ULP only supports assembly, not C code.
3) The build system will always build a .S file as assembly code, not as C code.
After updating to a newer version, you can read more about writing code for the RISC-V ULP here:
https://docs.espressif.com/projects/esp ... isc-v.html
and/or by following this example:
https://github.com/espressif/esp-idf/tr ... /ulp_riscv
EDIT: Updated reply, as original reply missed some information in the post.
nvtby_espf
Contact:
Postby nvtby_espf » Tue Mar 23, 2021 9:55 am
Thank you, ESP_Angus! Things got clear.
Users browsing this forum: ChatGPT-User, PerplexityBot, Semrush [Bot] and 5 guests
