How to use NVS Partition tool for esp32
roquita
Postby roquita » Sun Mar 28, 2021 11:34 pm
[/Codebox]GITHUB URL of the project: https://github.com/roquita/nvs_partition_tool
IDF VERSION: 4.1
Hello everyone,i was using NVS Partition Tool to generate a nvs image, then with parttool.py flashed this image on nvs partition. I was trying to read two strings from nvs partition but just got "ERR_NVS_NOT_FOUND".
Image of settings on NVS Partition Tool:
CSV file generated after press "Save" button:
Image of partition table to verify that is congruent with NVS Partition Tool.
PROCCES TO FLASH NVS IMAGE
  • Pressing "Generate partition" i got an "nvs.bin" (check in my github url) that was flashed using this command :
    python C:\esp41\esp-idf\components\partition_table\parttool.py --port COM18 write_partition --partition-name=nvs --input "nvs.bin"
    Result :
    C:\esp32\workspace\testing>python C:\esp41\esp-idf\components\partition_table\parttool.py --port COM18 write_partition --partition-name=nvs --input "nvs.bin"
    Running C:\Users\OWNER\.espressif\python_env\idf4.1_py3.7_env\Scripts\python.exe C:\esp41\esp-idf\components\esptool_py\esptool\esptool.py --port COM18 read_flash 32768 3072 C:\Users\OWNER\AppData\Local\Temp\tmp8n66xm53...
    esptool.py v2.9-dev
    Serial port COM18
    Connecting........_
    Detecting chip type... ESP32
    Chip is ESP32D0WDQ6 (revision 1)
    Crystal is 40MHz
    MAC: 80:7d:3a:cb:5d:84
    Uploading stub...
    Running stub...
    Stub running...
    3072 (100 %)
    3072 (100 %)
    Read 3072 bytes at 0x8000 in 0.3 seconds (85.4 kbit/s)...
    Hard resetting via RTS pin...
    Running C:\Users\OWNER\.espressif\python_env\idf4.1_py3.7_env\Scripts\python.exe C:\esp41\esp-idf\components\esptool_py\esptool\esptool.py --port COM18 erase_region 36864 24576...
    esptool.py v2.9-dev
    Serial port COM18
    Connecting......
    Crystal is 40MHz
    Uploading stub...
    Running stub...
    Stub running...
    Erasing region (may be slow depending on size)...
    Erase completed successfully in 0.2 seconds.
    Running C:\Users\OWNER\.espressif\python_env\idf4.1_py3.7_env\Scripts\python.exe C:\esp41\esp-idf\components\esptool_py\esptool\esptool.py --port COM18 write_flash 36864 nvs.bin...
    esptool.py v2.9-dev
    Serial port COM18
    Connecting....
    Crystal is 40MHz
    Uploading stub...
    Running stub...
    Stub running...
    Configuring flash size...
    Auto-detected Flash size: 4MB
    Compressed 24576 bytes to 213...
    Wrote 24576 bytes (213 compressed) at 0x00009000 in 0.0 seconds (effective 6207.8 kbit/s)...
    Hash of data verified.
    Leaving...
    Written contents of file 'nvs.bin' at offset 0x9000
  • Then i read the partition only to verify, using this command:
    python C:\esp41\esp-idf\components\partition_table\parttool.py read_partition  --partition-name=nvs --output "flashed.bin"
    Result: A file named "flashed.bin"(check github) was created and some text in command line:
    C:\esp32\workspace\testing>python C:\esp41\esp-idf\components\partition_table\parttool.py read_partition  --partition-name=nvs --output "flashed.bin"
    Running C:\Users\OWNER\.espressif\python_env\idf4.1_py3.7_env\Scripts\python.exe C:\esp41\esp-idf\components\esptool_py\esptool\esptool.py read_flash 32768 3072 C:\Users\OWNER\AppData\Local\Temp\tmp07vfnfth...
    esptool.py v2.9-dev
    Found 2 serial ports
    Serial port COM18
    Connecting........__
    Crystal is 40MHz
    Uploading stub...
    Running stub...
    Stub running...
    3072 (100 %)
    3072 (100 %)
    Read 3072 bytes at 0x8000 in 0.3 seconds (84.8 kbit/s)...
    Running C:\Users\OWNER\.espressif\python_env\idf4.1_py3.7_env\Scripts\python.exe C:\esp41\esp-idf\components\esptool_py\esptool\esptool.py read_flash 36864 24576
    flashed.bin...
    esptool.py v2.9-dev
    Serial port COM18
    Connecting.....
    Crystal is 40MHz
    Uploading stub...
    Running stub...
    Stub running...
    24576 (100 %)
    24576 (100 %)
    Read 24576 bytes at 0x9000 in 2.2 seconds (88.5 kbit/s)...
    Read partition 'nvs' contents from device at offset 0x9000 to file 'flashed.bin'
READING STRINGS FROM C CODE
  • Build and flash(using "idf.py app-flash monitor") the code below(is also in github):
    /* Hello World Example
    #include <stdio.h>
    #include <string.h>
    #include "freertos/task.h"
    #include "esp_system.h"
    #include "esp_spi_flash.h"
    #include "nvs_flash.h"
    #include "esp_err.h"
    #include "esp_log.h"
    #define TAG "MAIN"
    void init_NVS()
        //vTaskDelay(pdMS_TO_TICKS(10000));
        printf("iniciando...");
        if (ret == ESP_ERR_NVS_NO_FREE_PAGES || ret == ESP_ERR_NVS_NEW_VERSION_FOUND)
            ESP_LOGE(TAG, "%s, line %d, %s", __func__, __LINE__, esp_err_to_name(ret));
        ESP_ERROR_CHECK(ret);
    esp_err_t nvs_get_string(char *str, char *namespace, char *key)
        nvs_handle handle;
        esp_err_t err;
        err = nvs_open(namespace, NVS_READWRITE, &handle);
        if (err != ESP_OK)
            ESP_LOGE(TAG, "%s, line %d, %s", __func__, __LINE__, esp_err_to_name(err));
            return err;
        size_t size = 0;
        err = nvs_get_blob(handle, key, NULL, &size);
        if (err != ESP_OK)
            return err;
        if (size <= 0)
            return err;
        err = nvs_get_blob(handle, key, (void *)str, &size);
        if (err != ESP_OK)
            return err;
        nvs_close(handle);
        return ESP_OK;
    esp_err_t nvs_set_string(char *str, char *namespace, char *key)
        nvs_handle handle;
        esp_err_t err;
        if (err != ESP_OK)
            return err;
        err = nvs_set_blob(handle, key, (void *)str, strlen(str) + 1);
        if (err != ESP_OK)
            return err;
        err = nvs_commit(handle);
        if (err != ESP_OK)
            return err;
        nvs_close(handle);
        return ESP_OK;
    void app_main(void)
        init_NVS();
        char mistring[20] = {0};
        // STRINGS BEEN READED FROM NVS BUT WITH NO SUCCESS
        nvs_get_string(mistring, "main", "ssid");
        printf("ssid:%s\n", mistring);
        nvs_get_string(mistring, "main", "pass");
        printf("pass:%s\n", mistring);
        // PROOF THAT NVS IS WORKING OK
        nvs_set_string("string_saved", "main", "set");
        nvs_get_string(mistring, "main", "set");
        printf("mistring:%s\n", mistring);
        // STARTS HELLO WORDL EXAMPLE FROM IDF FRAMEWORK
        printf("Hello world!\n");
        /* Print chip information */
        esp_chip_info_t chip_info;
        esp_chip_info(&chip_info);
        printf("This is ESP32 chip with %d CPU cores, WiFi%s%s, ",
               chip_info.cores,
               (chip_info.features & CHIP_FEATURE_BT) ? "/BT" : "",
               (chip_info.features & CHIP_FEATURE_BLE) ? "/BLE" : "");
        printf("silicon revision %d, ", chip_info.revision);
        printf("%dMB %s flash\n", spi_flash_get_chip_size() / (1024 * 1024),
               (chip_info.features & CHIP_FEATURE_EMB_FLASH) ? "embedded" : "external");
        for (int i = 10; i >= 0; i--)
            printf("Restarting in %d seconds...\n", i);
        printf("Restarting now.\n");
        fflush(stdout);
        esp_restart();
    Result:
    I (29) boot: ESP-IDF v4.1.1-dirty 2nd stage bootloader
    I (29) boot: compile time 19:55:15
    I (29) boot: chip revision: 1
    I (32) boot_comm: chip revision: 1, min. bootloader chip revision: 0
    I (39) boot.esp32: SPI Speed      : 40MHz
    I (44) boot.esp32: SPI Mode       : DIO
    I (48) boot.esp32: SPI Flash Size : 4MB
    I (53) boot: Enabling RNG early entropy source...
    I (58) boot: Partition Table:
    I (62) boot: ## Label            Usage          Type ST Offset   Length
    I (69) boot:  0 nvs              WiFi data        01 02 00009000 00006000
    I (77) boot:  1 phy_init         RF data          01 01 0000f000 00001000
    I (84) boot:  2 factory          factory app      00 00 00010000 00100000
    I (92) boot:  3 storage          Unknown data     01 82 00110000 00010000
    I (99) boot: End of partition table
    I (103) boot_comm: chip revision: 1, min. application chip revision: 0
    I (110) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x06bb4 ( 27572) map
    I (130) esp_image: segment 1: paddr=0x00016bdc vaddr=0x3ffb0000 size=0x02014 (  8212) load
    I (134) esp_image: segment 2: paddr=0x00018bf8 vaddr=0x40080000 size=0x00404 (  1028) load
    0x40080000: _WindowOverflow4 at C:/esp41/esp-idf/components/freertos/xtensa_vectors.S:1778
    I (138) esp_image: segment 3: paddr=0x00019004 vaddr=0x40080404 size=0x07014 ( 28692) load
    I (159) esp_image: segment 4: paddr=0x00020020 vaddr=0x400d0020 size=0x181b4 ( 98740) map
    0x400d0020: _stext at ??:?
    I (197) esp_image: segment 5: paddr=0x000381dc vaddr=0x40087418 size=0x02ff8 ( 12280) load
    0x40087418: prvProcessTimerOrBlockTask at C:/esp41/esp-idf/components/freertos/timers.c:583
    I (208) boot: Loaded app from partition at offset 0x10000
    I (208) boot: Disabling RNG early entropy source...
    I (209) cpu_start: Pro cpu up.
    I (212) cpu_start: Application information:
    I (217) cpu_start: Project name:     testing
    I (222) cpu_start: App version:      1
    I (226) cpu_start: Compile time:     Mar 26 2021 19:55:19
    I (233) cpu_start: ELF file SHA256:  5fabec642c71aaa7...
    I (239) cpu_start: ESP-IDF:          v4.1.1-dirty
    I (244) cpu_start: Starting app cpu, entry point is 0x40081148
    0x40081148: call_start_cpu1 at C:/esp41/esp-idf/components/esp32/cpu_start.c:276
    I (0) cpu_start: App cpu up.
    I (254) heap_init: Initializing. RAM available for dynamic allocation:
    I (261) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
    I (267) heap_init: At 3FFB2858 len 0002D7A8 (181 KiB): DRAM
    I (274) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
    I (280) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
    I (286) heap_init: At 4008A410 len 00015BF0 (86 KiB): IRAM
    I (292) cpu_start: Pro cpu start user code
    I (311) spi_flash: detected chip: gd
    I (311) spi_flash: flash io: dio
    I (311) cpu_start: Starting scheduler on PRO CPU.
    iniciando...
    E (337) MAIN: nvs_get_string, line 51, ESP_ERR_NVS_NOT_FOUND
    ssid:
    pass:
    mistring:string_saved
    Hello world!
    This is ESP32 chip with 2 CPU cores, WiFi/BT/BLE, silicon revision 1, 4MB external flash
    Restarting in 10 seconds...
    Restarting in 9 seconds...
    Restarting in 8 seconds...
    Restarting in 7 seconds...
    Restarting in 6 seconds...
    Restarting in 5 seconds...
    Restarting in 4 seconds...
    Restarting in 3 seconds...
    Restarting in 2 seconds...
    Restarting in 1 seconds...
    Restarting in 0 seconds...
    As you can see, error is in line 51, related to "nvs_get_string" function. Reading data that was saved in C Code works very well, but reading that was flashed with NVS IMAGE doesnt work. Maybe problem is my code, i dont know.
    Can you help me with that ,please? . Thanks in advance.
Re: How to use NVS Partition tool for esp32
Postby Sprite » Mon Mar 29, 2021 3:07 am
Why are you reading string data using nvs_get_blob?
roquita
Postby roquita » Mon Mar 29, 2021 6:36 am
oh right, it was my mistake. Using nvs_get_string works. Can you help me with one thing more, please?. How can i flash nvs image after flashing app automatically?. I want to flash all partitions in one shot. Thanks
Minatel
Postby Minatel » Mon Mar 29, 2021 8:21 am
If you need to flash only the partition table image, you can use
idf.py -p PORT partition_table-flash
roquita
Postby roquita » Tue Mar 30, 2021 5:25 am
For example: spiffs_create_imagen() in the cmake file helps to flash spiffs partition after flashing app image. There is any function available to flash nvs image in the same way?
Minatel
Postby Minatel » Tue Mar 30, 2021 8:11 pm
Are you looking for some mass production automation tool to customize the configuration data in the NVS?
Take a look at this: mass_mfg.
roquita
Postby roquita » Wed Mar 31, 2021 3:59 am
okay, thank you very much esp forum team.
