Esp32 + BLE (temperature and humidity beacon)
lucasromeiro
Postby lucasromeiro » Fri Apr 02, 2021 12:17 am
I have a small challenge:
I always used esp8266.
Now I need to connect an esp32 to a temperature and humidity (BLE) sensor.
I'm going to send a picture of him here.
I used Scan example and it worked, found the equipment!
But, I am not able to connect to the BLE beacon to receive the temperature and humidity.
I tried to use the example Client.ino but was unsuccessful.
I need a help! :( :(
As there are no instructions in the example, I did not change anything.
I don't know what to do to change and read the Beacon variables (temperature and humidity)
Thank you so much for helping us all!
Advertised Device found: Name: ThermoBeacon, Address: 70:f7:00:00:11:1a, manufacturer data: 100000001a110000f770830cef01be04c4300000, serviceUUID: 0xfff0, txPower: 0
chegewara
Re: Esp32 + BLE (temperature and humidity beacon)
Postby chegewara » Sat Apr 03, 2021 6:52 pm
There are literally hundreds examples how to work with beacons and sensors on github, blogs and youtube, but the most important question is:
- is it connectable device or just advertising data which you have to parse?
