ESP32 Secure Boot failed
Yuvaraj1867
Contact:
Postby Yuvaraj1867 » Fri Apr 02, 2021 6:29 am
Dear Team,
I am trying to use secure boot feature. But i cannot. Here is my problem description.
Module: ESP-Wroom-32D (XX0H64)
IDF Version: ESP-IDF-V3.3
Debug log:
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:9268
load:0x40078000,len:18428
load:0x40080400,len:6664
csum err:0x20!=0x3b
ets_main.c 371
Steps I did to enable secure boot:
1. Generated .PEM key file using openssl command.
2. In menuconfig -> Enabled secure boot and Mode- Reflashable . Changed partition table to 8MB.
3. Executed “make bootloader”
4. Then flashed secure-bootloader-key-256.bin, bootloader.bin, bootloader-reflash-digest.bin files based on the instructions given after building bootloader. This was done without any error.
5. Then Executed “make flash”. Next i got the above error.
For reference download the sdkconfig, bootloader files and efuse summary from this link.
https://we.tl/t-DrNcpbnQYN
Kindly help me to solve this issue.
WiFive
Re: ESP32 Secure Boot failed
Postby WiFive » Fri Apr 02, 2021 7:04 am
Yuvaraj1867
Contact:
Postby Yuvaraj1867 » Fri Apr 02, 2021 7:46 am
Hello WiFi,
Thanks. After reducing bootloader log level it works.
Can i use 0xE000 as partition offset? But nvs offset starting form 0X9000. Can you guide me.
