Hello
I'm planning to use ESP32-S2 in a new product that has a TFT screen and I want to let a DMA controller handle the transactions between external PSRAM (holding TFT screen buffer) and SPI2 (interfacing with the LCD).
Can this be done?
Is there any other better suggestion?
ESP32-S2 DMA transactions between SPI2 and external PSRAM
polamagdygeo
polamagdygeo
Re: ESP32-S2 DMA transactions between SPI2 and external PSRAM
Can someone clarify these points to me?
1-
2-
1-
Reference https://docs.espressif.com/projects/esp ... l-ram.htmlExternal RAM cannot be used as a place to store DMA transaction descriptors or as a buffer for a DMA transfer to read from or write into. Any buffers that will be used in combination with DMA must be allocated using heap_caps_malloc(size, MALLOC_CAP_DMA) and can be freed using a standard free() call.
2-
Reference technical reference manual page 359EDMA is used by I2S0, SPI2, AES Accelerator, and SHA Accelerator. It can access both internal RAM and external RAM.
I have the same problem. Do you get it work?
ESP-IDF V4.2 is not support I2S EDMA yet. I do not know if the nonstable V4.3 support I2S EDMA or not.
polamagdygeo
Not yet ,They told me that "The driver of EDMA is under development and need more time to finish and test it."
polamagdygeo
Anyone can tell us ,Is this feature planned to be done or not and what's the expected date to release it?
Users browsing this forum: Bytespider, ChatGPT-User, markkuk and 1 guest
