ESP32-Korvo-DU1906 报错
wangda
Postby wangda » Sat Apr 17, 2021 2:36 am
CMake Error at components/bdsc_engine/CMakeLists.txt:9 (add_prebuilt_library):
Unknown CMake command "add_prebuilt_library".
HengYC
Re: ESP32-Korvo-DU1906 报错
Postby HengYC » Tue Apr 20, 2021 2:04 am
1. 可以提供更多的log信息吗?
2. 这个例子是稍微比其他的例子要复杂些的,建议仔细阅读 DU1906 的文档。 https://github.com/espressif/esp-adf/bl ... /README.md
wangda
Postby wangda » Tue Apr 20, 2021 5:20 am
wangda@DESKTOP-TARO438:~/esp$ export ADF_PATH=~/esp/esp-adf
wangda@DESKTOP-TARO438:~/esp$ . $HOME/esp/esp-adf/esp-idf/export.sh
Adding ESP-IDF tools to PATH...
Checking if Python packages are up to date...
Python requirements from /home/wangda/esp/esp-adf/esp-idf/requirements.txt are satisfied.
Added the following directories to PATH:
/home/wangda/esp/esp-adf/esp-idf/components/esptool_py/esptool
/home/wangda/esp/esp-adf/esp-idf/components/espcoredump
/home/wangda/esp/esp-adf/esp-idf/components/partition_table/
Done! You can now compile ESP-IDF projects.
Go to the project directory and run:
idf.py build
06/ .a@DESKTOP-TARO438:~/esp$ cp -r /home/wangda/esp/esp-adf/examples/korvo_du190
wangda@DESKTOP-TARO438:~/esp$ cd korvo_du1906/
wangda@DESKTOP-TARO438:~/esp/korvo_du1906$ idf.py menuconfig
Note: You are using Python 3.6.9. Python 3 support is new, please report any problems you encounter. Search for 'Setting the Python Interpreter' in the ESP-IDF docs if you want to use Python 2.7.
Checking Python dependencies...
Running cmake in directory /home/wangda/esp/korvo_du1906/build
Executing "cmake -G Ninja -DPYTHON_DEPS_CHECKED=1 -DESP_PLATFORM=1 --warn-uninitialized /home/wangda/esp/korvo_du1906"...
Warn about uninitialized values.
fatal: not a git repository (or any of the parent directories): .git
-- Found Git: /usr/bin/git (found version "2.17.1")
-- IDF_TARGET not set, using default target: esp32
-- Building for target esp32
-- ccache will be used for faster builds
-- The C compiler identification is GNU 5.2.0
-- The CXX compiler identification is GNU 5.2.0
-- Found assembler: /home/wangda/.espressif/tools/xtensa-esp32-elf/1.22.0-80-g6c4433a-5.2.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc
-- Check for working C compiler: /home/wangda/.espressif/tools/xtensa-esp32-elf/1.22.0-80-g6c4433a-5.2.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc
-- Check for working C compiler: /home/wangda/.espressif/tools/xtensa-esp32-elf/1.22.0-80-g6c4433a-5.2.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc -- works
-- Check for working CXX compiler: /home/wangda/.espressif/tools/xtensa-esp32-elf/1.22.0-80-g6c4433a-5.2.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-g++
-- Check for working CXX compiler: /home/wangda/.espressif/tools/xtensa-esp32-elf/1.22.0-80-g6c4433a-5.2.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-g++ -- works
-- Building empty aws_iot component due to configuration
-- Component names: soc log heap xtensa-debug-module app_trace freertos vfs newlib esp_ringbuf driver esp_event ethernet mbedtls micro-ecc efuse bootloader_support partition_table app_update spi_flash nvs_flash lwip tcpip_adapter pthread smartconfig_ack wpa_supplicant espcoredump esp32 cxx audio_sal esp_adc_cal wear_levelling sdmmc fatfs console esp-sr nghttp esp-tls tcp_transport esp-adf-libs audio_pipeline spiffs display_service esp_dispatcher nimble bt esp_peripherals audio_board audio_hal input_key_service esp_http_client wifi_service clouds dueros_service esp_actions tone_partition audio_stream bluetooth_service playlist esp_event_cast audio_player audio_flash_tone mqtt json bdsc_engine bds_light esp_https_ota ota_service main bds_private jsmn adf_utils battery_service coredump_upload_service asio aws_iot bootloader coap esp_http_server openssl esp_https_server esp_websocket_client esptool_py expat freemodbus idf_test libsodium mdns protobuf-c protocomm ulp unity wifi_provisioning
-- Component paths: /home/wangda/esp/esp-adf/esp-idf/components/soc;/home/wangda/esp/esp-adf/esp-idf/components/log;/home/wangda/esp/esp-adf/esp-idf/components/heap;/home/wangda/esp/esp-adf/esp-idf/components/xtensa-debug-module;/home/wangda/esp/esp-adf/esp-idf/components/app_trace;/home/wangda/esp/esp-adf/esp-idf/components/freertos;/home/wangda/esp/esp-adf/esp-idf/components/vfs;/home/wangda/esp/esp-adf/esp-idf/components/newlib;/home/wangda/esp/esp-adf/esp-idf/components/esp_ringbuf;/home/wangda/esp/esp-adf/esp-idf/components/driver;/home/wangda/esp/esp-adf/esp-idf/components/esp_event;/home/wangda/esp/esp-adf/esp-idf/components/ethernet;/home/wangda/esp/esp-adf/esp-idf/components/mbedtls;/home/wangda/esp/esp-adf/esp-idf/components/micro-ecc;/home/wangda/esp/esp-adf/esp-idf/components/efuse;/home/wangda/esp/esp-adf/esp-idf/components/bootloader_support;/home/wangda/esp/esp-adf/esp-idf/components/partition_table;/home/wangda/esp/esp-adf/esp-idf/components/app_update;/home/wangda/esp/esp-adf/esp-idf/components/spi_flash;/home/wangda/esp/esp-adf/esp-idf/components/nvs_flash;/home/wangda/esp/esp-adf/esp-idf/components/lwip;/home/wangda/esp/esp-adf/esp-idf/components/tcpip_adapter;/home/wangda/esp/esp-adf/esp-idf/components/pthread;/home/wangda/esp/esp-adf/esp-idf/components/smartconfig_ack;/home/wangda/esp/esp-adf/esp-idf/components/wpa_supplicant;/home/wangda/esp/esp-adf/esp-idf/components/espcoredump;/home/wangda/esp/esp-adf/esp-idf/components/esp32;/home/wangda/esp/esp-adf/esp-idf/components/cxx;/home/wangda/esp/esp-adf/components/audio_sal;/home/wangda/esp/esp-adf/esp-idf/components/esp_adc_cal;/home/wangda/esp/esp-adf/esp-idf/components/wear_levelling;/home/wangda/esp/esp-adf/esp-idf/components/sdmmc;/home/wangda/esp/esp-adf/esp-idf/components/fatfs;/home/wangda/esp/esp-adf/esp-idf/components/console;/home/wangda/esp/esp-adf/components/esp-sr;/home/wangda/esp/esp-adf/esp-idf/components/nghttp;/home/wangda/esp/esp-adf/esp-idf/components/esp-tls;/home/wangda/esp/esp-adf/esp-idf/components/tcp_transport;/home/wangda/esp/esp-adf/components/esp-adf-libs;/home/wangda/esp/esp-adf/components/audio_pipeline;/home/wangda/esp/esp-adf/esp-idf/components/spiffs;/home/wangda/esp/esp-adf/components/display_service;/home/wangda/esp/esp-adf/components/esp_dispatcher;/home/wangda/esp/esp-adf/esp-idf/components/nimble;/home/wangda/esp/esp-adf/esp-idf/components/bt;/home/wangda/esp/esp-adf/components/esp_peripherals;/home/wangda/esp/esp-adf/components/audio_board;/home/wangda/esp/esp-adf/components/audio_hal;/home/wangda/esp/esp-adf/components/input_key_service;/home/wangda/esp/esp-adf/esp-idf/components/esp_http_client;/home/wangda/esp/esp-adf/components/wifi_service;/home/wangda/esp/esp-adf/components/clouds;/home/wangda/esp/esp-adf/components/dueros_service;/home/wangda/esp/esp-adf/components/esp_actions;/home/wangda/esp/esp-adf/components/tone_partition;/home/wangda/esp/esp-adf/components/audio_stream;/home/wangda/esp/esp-adf/components/bluetooth_service;/home/wangda/esp/esp-adf/components/playlist;/home/wangda/esp/esp-adf/components/esp_event_cast;/home/wangda/esp/korvo_du1906/components/audio_player;/home/wangda/esp/korvo_du1906/components/audio_flash_tone;/home/wangda/esp/esp-adf/esp-idf/components/mqtt;/home/wangda/esp/esp-adf/esp-idf/components/json;/home/wangda/esp/korvo_du1906/components/bdsc_engine;/home/wangda/esp/korvo_du1906/components/bds_light;/home/wangda/esp/esp-adf/esp-idf/components/esp_https_ota;/home/wangda/esp/esp-adf/components/ota_service;/home/wangda/esp/korvo_du1906/main;/home/wangda/esp/korvo_du1906/components/bds_private;/home/wangda/esp/esp-adf/esp-idf/components/jsmn;/home/wangda/esp/esp-adf/components/adf_utils;/home/wangda/esp/esp-adf/components/battery_service;/home/wangda/esp/esp-adf/components/coredump_upload_service;/home/wangda/esp/esp-adf/esp-idf/components/asio;/home/wangda/esp/esp-adf/esp-idf/components/aws_iot;/home/wangda/esp/esp-adf/esp-idf/components/bootloader;/home/wangda/esp/esp-adf/esp-idf/components/coap;/home/wangda/esp/esp-adf/esp-idf/components/esp_http_server;/home/wangda/esp/esp-adf/esp-idf/components/openssl;/home/wangda/esp/esp-adf/esp-idf/components/esp_https_server;/home/wangda/esp/esp-adf/esp-idf/components/esp_websocket_client;/home/wangda/esp/esp-adf/esp-idf/components/esptool_py;/home/wangda/esp/esp-adf/esp-idf/components/expat;/home/wangda/esp/esp-adf/esp-idf/components/freemodbus;/home/wangda/esp/esp-adf/esp-idf/components/idf_test;/home/wangda/esp/esp-adf/esp-idf/components/libsodium;/home/wangda/esp/esp-adf/esp-idf/components/mdns;/home/wangda/esp/esp-adf/esp-idf/components/protobuf-c;/home/wangda/esp/esp-adf/esp-idf/components/protocomm;/home/wangda/esp/esp-adf/esp-idf/components/ulp;/home/wangda/esp/esp-adf/esp-idf/components/unity;/home/wangda/esp/esp-adf/esp-idf/components/wifi_provisioning
Loading defaults file /home/wangda/esp/korvo_du1906/sdkconfig.defaults...
-- IDF_VER: v3.3.2-107-g722043f73
-- Project version: v1.3.0
-- Found PythonInterp: /home/wangda/.espressif/python_env/idf3.3_py3.6_env/bin/python (found version "3.6.9")
-- Found Perl: /usr/bin/perl (found version "5.26.1")
-- Adding linker script /home/wangda/esp/korvo_du1906/build/esp-idf/esp32/esp32_out.ld
-- Adding linker script /home/wangda/esp/esp-adf/esp-idf/components/esp32/ld/esp32.extram.bss.ld
-- Adding linker script /home/wangda/esp/esp-adf/esp-idf/components/esp32/ld/esp32.rom.ld
-- Adding linker script /home/wangda/esp/esp-adf/esp-idf/components/esp32/ld/esp32.peripherals.ld
-- Adding linker script /home/wangda/esp/esp-adf/esp-idf/components/esp32/ld/esp32.rom.libgcc.ld
-- Adding linker script /home/wangda/esp/esp-adf/esp-idf/components/esp32/ld/esp32.rom.spiram_incompatible_fns.ld
-- /home/wangda/esp/esp-adf/components/esp-adf-libs, Chip is esp32
-- Current board name is CONFIG_ESP32_KORVO_DU1906_BOARD
See also "/home/wangda/esp/korvo_du1906/build/CMakeFiles/CMakeOutput.log".
See also "/home/wangda/esp/korvo_du1906/build/CMakeFiles/CMakeError.log".
cmake failed with exit code 1
HengYC
Postby HengYC » Fri Apr 23, 2021 9:58 am
这里操作错了, DU1906 需要特殊的 IDF 分支 audio/stack_on_psram_v3.3, 而不是 adf 内置的默认 idf 分支。
请阅读 readme,按照步骤来操作:https://github.com/espressif/esp-adf/bl ... /README.md
wangda
Postby wangda » Mon Apr 26, 2021 10:47 am
你们这个板子不支持百度的音乐技能怎么搞啊
wangda
Postby wangda » Mon Apr 26, 2021 10:48 am
能接入别的平台吗
wangda
Postby wangda » Mon Apr 26, 2021 10:53 am
能不能搞一个ZIP版的ADF啊GitHub克隆不下来
Gargamel
Postby Gargamel » Mon Apr 26, 2021 11:29 am
wangda
Postby wangda » Mon Apr 26, 2021 12:22 pm
wangda
dueros也不支持
Users browsing this forum: YisouSpider and 1 guest
