There's a question (not a problem) about ESP32-S2 RMT demodulator. I have created a learning example for it, it works well, but I met with a difficulty to explain two parameters. Their values were found experimentally because I have no guess how they work.
Parameters are located in RMT_CHn_RX_CARRIER_RM_REG register and named as RMT_CARRIER_LOW_THRES_CHn and RMT_CARRIER_HIGH_THRES_CHn. Maybe somebody has a picture how do these parameters work.
My example isn't trivial but simple. One RMT channel generates single modulated series. Next channel reads it and decodes. Also a PCNT channel counts pulses on same pin just to make sure everything works as expected.
Parameters:
APB clock in use, divider 16 makes 80/16=5 MHz 200 ns pulses.
Transmitter modulates with narrow peaks. Carrier: Low=96 (12.5*96=1200 ns) High=32 (12.5*32=400 ns), modulation at V=1, data only, idle output with V=0.
Sequence (index=hex): 0=8030 1=0010 2=8040 3=0000 (see attached picture from scope, similar encycled series). It makes a 200*48=9600 ns high signal, modulated as 9600/1600=6 pulses. Then 200*16=3200 ns low signal, as placeholder of 3200/1600=2 pulses. Terminating high signal is 200*64=12800 ns long, made of 12800/1600=8 pulses.
Receiver is able to work at next parameters:
RMT_CARRIER_LOW_THRES_CHn = 9, valid range 8-9
RMT_CARRIER_HIGH_THRES_CHn = 10, valid range 10-99
Result sequence (index=hex): 0=8032 1=0010 2=8040 3=0000
PCNT Unit 0: status=0x00 counter=+14
As you can see result is almost perfect. First "high" was found two units longer, ,not a primary question here. The question is, how can I calculate RMT_CARRIER_*_THRES_CHn parameters based on transmitter parameters? I really got stuck.
BTW, when modulator and demodulator were turned off, output sequence was full match to input sequence.
Thank you for reading long story.
How to calculate thresholds of RMT demodulator?
- nvtby_espf
- Contact:
Users browsing this forum: Baidu [Spider] and 2 guests
