Weak Security (WPA)
WPA is not considered secure. Learn More.
If this is your Wi-Fi network, configure the router to use WPA2/WPA3 Personal (AES) security type for this network.
I have set .authmode = WIFI_AUTH_WPA2_PSK
Why do I get this warning? Why isn't my setting recognized? I can not test WPA3 because "Currently, WPA3 is supported only in Station mode". So, is my setting not working or is macOS wrong? How to test this?
wifi_config_t wifi_config = {
.ap = {
.ssid = AP_WIFI_SSID,
.ssid_len = strlen(AP_WIFI_SSID),
.channel = AP_WIFI_CHNL,
.password = AP_WIFI_PASS,
.max_connection = AP_WIFI_MAXC,
.authmode = WIFI_AUTH_WPA2_PSK //WIFI_AUTH_WPA_WPA2_PSK
ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_AP));
ESP_ERROR_CHECK(esp_wifi_set_config(WIFI_IF_AP, &wifi_config));
ESP_ERROR_CHECK(esp_wifi_start());
