Regarding ADC2 pins
newbie_007
Regarding ADC2 pins
Postby newbie_007 » Fri Apr 30, 2021 2:32 pm
Hello every one,
Thank you for reading my post. I would like to ask a question. The API reference mentioned that "Since the ADC2 module is also used by the Wi-Fi, only one of them could get the preemption when using together". What happened if ADC2 pins are used as digital input/output pins? Did they give the same effect to WiFi as when they are used as ADC pin?
Thank you very much
Minatel
Re: Regarding ADC2 pins
Postby Minatel » Fri Apr 30, 2021 3:32 pm
No. This happens only when the ADC2 peripheral is used.
newbie_007
Postby newbie_007 » Sat May 01, 2021 2:00 am
Dear ESP_Minatel,
Thank you very much for your useful answer.
Be healthy and safe.
Best regards.
